Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 05-25-2018, 11:34 AM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is offline
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default Polaris Perc Reverse
Polaris Edge parts
Perc reverse kit SOLD
Rear torque arm red 1541615-067 $65
Mikuni Twin Carburetor 800cc 1253464 $100
Water pump and housing $45
19T hyvo top gear $15
20T hyvo top gear $15
21T hyvo top gear $15
38T hyvo bottom gear $20
70 Pin hyvo chain $50
Edge Coil 2 wire $25
800 VES cylinder head core 3021339 $40 each (2 available)
Rate this post: Yes | No
  #2
Old 05-26-2018, 08:17 AM
minibob minibob is offline
Currently: Not set.
minibob is on a distinguished roadminibob is on a distinguished road
Default
Good day . Regarding to the Perc parts will the parts listed work on a 2001 rmk 800 ? What would still be needed to have perc reverse on the 2001?
  #3
Old 05-31-2018, 06:40 PM
Currently: Not set.
Default
Quote:
For the 2001, you need to also change out the ignition switch, the carburetor and the voltage regulator. I have a 2004 carburetor for an 800 for $100. The other 2 can be found on Ebay for cheap.
The additional parts not listed is the oil pump. The oil pump that is used with PERC, also pumps oil when the engine goes backward. You can find those for about $45 on Ebay. The oil pump is suggested but normally reverse is not used long enough to require oil in the gas. But it doesn't hurt. If you wanted to go with the deluxe PERC conversion, then you could add the tachometer which has Blue Reverse Light that comes on when it shifts, but that may require a new electrical harness for the tach and speedo. But that is not necessary because you just goose the throttle a little, to see whether it wants to go forward or backward. The engine completely stops and restarts when you hit the reverse button, so you will definitely know whether it is in reverse or not, without having the blue light to look at. Let me know if you are still interested. The total cost would be $300 including the CDI harness. Free postage for continental U.S. Refer to your personal mail box for my email address. I am including the CDI harness for free.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Perc Reverse from an 03 Polaris rmk 800 Thread Starter — Twisted Tunnel Forum — Misc. Sled Parts Replies — 2 Last Post — 01-07-2015 10:44 AM
Thread — polaris Perc reverse on a 900 cat ??? Thread Starter — unclemark Forum — Arctic Cat Replies — 4 Last Post — 08-04-2008 11:12 AM
Thread — Polaris PERC Reverse Kits, Only a Few Left Thread Starter — Roadwarrior102 Forum — Engine/Engine Parts (Swapmeet) Replies — 2 Last Post — 03-23-2008 06:57 PM
Thread — Polaris PERC Reverse Kits, Only a Few Left Thread Starter — Roadwarrior102 Forum — Polaris Replies — 5 Last Post — 12-28-2007 05:26 PM
no new posts
