Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 05-25-2018, 07:34 AM
2xturbo 2xturbo is offline
Currently: done
Basic Member
2xturbo has a reputation beyond repute2xturbo has a reputation beyond repute2xturbo has a reputation beyond repute2xturbo has a reputation beyond repute2xturbo has a reputation beyond repute2xturbo has a reputation beyond repute2xturbo has a reputation beyond repute2xturbo has a reputation beyond repute2xturbo has a reputation beyond repute2xturbo has a reputation beyond repute2xturbo has a reputation beyond repute
Default New Mountain cat
I just picked me up a new 2018 mountain cat 153 snowmobile what are some things you guys are changing to help perform better between 6 to 9000 feet elevation the gearing is 19/50 are you changing this or you leaving at stock. Looking to get rid of giant exhaust can was thinkin going GGB?? I am not looking to do any motor work or no turbo just looking at some things I could do to help it do a little better in the deep snow thanks
Rate this post: Yes | No
  #2
Old 05-25-2018, 09:35 AM
goridedoo's Avatar
goridedoo goridedoo is online now
Currently: Not set.
goridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond repute
Default
If you go GGB get the trail can, they are even almost too loud. Most will recommend to get gripper skis.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to goridedoo For This Useful Post:
2xturbo (05-25-2018)
  #3
Old 05-25-2018, 05:53 PM
ndfb35 ndfb35 is online now
Currently: Not set.
ndfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond reputendfb35 has a reputation beyond repute
Default
As far as a silencers go, it is my opinion Diamond S is the top dog. I have the quiet can and the craftsmanship and quality is great. I had loud cans before and now that I have a quiet one I will be keeping things quiet from now on. On my SO's 6000 is the Speedwerx L2 can, it's too loud for me especially when I have to give a ski tug, but besides the noise it gets the job done and it had held together well.
Last year was the first year I tried aftermarket boards. Unless Cat comes up with something different in the future, I will continue to add aftermarket boards. I went with B&M Fabrications and they are fantastic. Snow evacuates completely and the grip was too good in my case as the traction screws ripped two pairs of pants. When I add them to my 19 I will be going with traction blocks from TKI.
Quite a few people had issues with the rear tunnel section bending, so an aftermarket bumper might be necessary. I had a Rogue Concepts bumper and didn't have any issues with the rear sections.
I would also replace the controls with the stock 19 parts, throttle body and break reservoir/lever. I used the Speedwerx kit this year, and it was nice when it functioned but it didn't work all the time.
For skis I put on a pair of grippers which was my first time using them and I have no complaints. I didn't have any issues with darting or diving.
Many people will tell you just to ride it and that is defiantly an option, but for me, the absolute minimum would be a can and set of grippers.
1 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to ndfb35 For This Useful Post:
2xturbo (05-27-2018), sno*jet (05-29-2018)
  #4
Vertical-Extreme's Avatar
Vertical-Extreme Vertical-Extreme is offline
Currently: Braaaaap
Vertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond reputeVertical-Extreme has a reputation beyond repute
Garage
Default
Get a can and set up the suspension. Ride the **** out of it.
The only other thing I do is swap the steering to the laydown with a post forwarabd CFR bars. But that is personal preference.
Sent from my ONEPLUS A5000 using Tapatalk
__________________
The ultimate Stock Bore M8000 PC: Full Jaws Set up - Reaper Hood - Custom Cold Air Intake - BD Fuel Control - Arctic Edge Clutching - Arctic Edge Tuning-TKI Belt Drive W/ oil delete - Gripper Skis - 3" C3 post forward kit, PHC 7 deg. bars '16 front end.
The Following User Says Thank You to Vertical-Extreme For This Useful Post:
  #5
Old 05-25-2018, 05:54 PM
Currently: Not set.
Default
I forgot to mention, as with all air shocks don't be afraid to change the settings to what works for you, this plays a vital role in the handling of the sled.
The Following User Says Thank You to ndfb35 For This Useful Post:
  #6
Old 05-25-2018, 07:40 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
i agree with all of this but I do NOT like the laydown post and as he said personal preference for sure.
  #7
Old 05-25-2018, 07:53 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Alpha Hawk!
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
Seal the intake before u ingest snow. (By goggle bag)
Gripper skis are a huge improvement! Stock skis suck when u get a crusty layer on top of powder. Like a serious death wobble down hills.
Roll the bar riser forward till it is at 90° or a touch more forward.
Within 500 miles u will need to buy wild child's steering bushings.
If ur not yet aware, don't freak out when u first ride it. There is a rev limiter during the break in.
The Following 2 Users Say Thank You to summ8rmk For This Useful Post:
  #8
Old 05-26-2018, 08:07 PM
dunatyk's Avatar
dunatyk dunatyk is offline
Currently: Meh....
dunatyk has a reputation beyond reputedunatyk has a reputation beyond reputedunatyk has a reputation beyond reputedunatyk has a reputation beyond reputedunatyk has a reputation beyond reputedunatyk has a reputation beyond reputedunatyk has a reputation beyond reputedunatyk has a reputation beyond reputedunatyk has a reputation beyond reputedunatyk has a reputation beyond reputedunatyk has a reputation beyond repute
Default
Is the area by the google bag the only place that needs to be sealed up better?
  #9
Old 05-27-2018, 02:08 AM
summ8rmk's Avatar
Default
Quote:
Those r gaping holes but there could be small gaps where the intake plenum halves bolt together. I used black RTV up in the front on the small gaps.
  #10
Old 05-27-2018, 07:18 AM
Currently: done
Basic Member
  #11
Old 05-27-2018, 07:37 AM
Currently: Not set.
Garage
Click Here to Register
The Following User Says Thank You to kiliki For This Useful Post:
2xturbo (05-28-2018)
  #12
Old 05-28-2018, 06:58 AM
Currently: done
Basic Member
  #13
Old 05-28-2018, 08:14 AM
summ8rmk's Avatar
The Following User Says Thank You to summ8rmk For This Useful Post:
2xturbo (06-03-2018)
  #14
Old 06-03-2018, 01:11 PM
Currently: done
Basic Member
  #15
Old 06-03-2018, 02:00 PM
summ8rmk's Avatar
2xturbo (06-03-2018), fudge313 (06-05-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2017 Mountain Cat vs 2018 Mountain Cat Thread Starter — Frostbite Forum — Arctic Cat: Proclimb M Replies — 31 Last Post — 11-18-2017 11:47 AM
Thread — ARCTIC CAT STATOR, MAGNETO, FLYWHEEL TIMING SENSOR: ZR ZL Mountain Cat, King Cat Thread Starter — 98woody Forum — Engine/Engine Parts (Swapmeet) Replies — 4 Last Post — 12-28-2012 04:55 AM
Thread — ARCTIC CAT IGNITION COIL ZR ZL KING CAT POWFER SPECIAL MOUNTAIN CAT FIRECAT Thread Starter — 98woody Forum — Engine/Engine Parts (Swapmeet) Replies — 2 Last Post — 12-21-2012 05:01 AM
Thread — Acrtic Cat Mountain Cat 900 Clutches, drivers, chancase, for sale Thread Starter — dodgedart68 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 2 Last Post — 01-02-2010 01:38 PM
Thread — F/S: Arctic Cat Mountain Cat/King Cat Snowflap Thread Starter — Heavysledz Forum — Chassis/Tunnel (Swapmeet) Replies — 4 Last Post — 11-28-2008 04:30 PM
