Upgrade to Premium
Ski-Doo: REV Gen 4 For the 2017 and newer REV Gen 4 Sleds
Reply
  #1
Old 05-22-2018, 12:08 PM
donbrown's Avatar
donbrown donbrown is offline
Currently: Let it snow !!!
donbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond repute
Default HOW much amps for a single headlight?
Looking at aftermarket LED bulbs.
How much amps does the 850 supply to a single headlight socket ?
Looking at LED bulbs .... can get 0.2 to 3.2 AMP LED bulbs.
Obviously more power more light. Or go a variable amp bulb? Is there a resistor in the circuit?
__________________
www.CNSA.NET lifetime member
Rate this post: Yes | No
  #2
Old 05-22-2018, 06:34 PM
sledsrock sledsrock is offline
Currently: SUMMER SUCKS!
sledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond repute
Default Wattage
You have to remember light bulbs are rated/measured in wattage. A circuit will only pull "X" amount of AMPS depending on the load, in this case the light bulb. AMPS can be calculated by using a simple formula, P=IxE
P = Wattage
I = AMPs or Current
E = Voltage
Take the original bulbs Wattage and divide by the Voltage and leaves you with the AMP draw of that bulb/circuit.
LED's pull fewer AMPs but are a bit more Voltage sensitive (although not normally an issue).
The Following User Says Thank You to sledsrock For This Useful Post:
donbrown (05-30-2018)
  #3
Old 05-23-2018, 12:22 PM
donbrown's Avatar
Default
E = 12
P= ?
Whats the wattage of the factory installed bulb ? .... Are factory bulbs wattage out put congruent with a LED wattage out ? The technologies have different operating efficiencies?
Does SKIDOO offer a LED bulb replacement? What is the specs on a LED replacement from manufacturer?
SKIDOO offers an LED strip add on ... is this on the same circuit so to add and have more wattage on the primary headlight?
__________________
  #4
Old 05-29-2018, 12:17 PM
eddy's Avatar
eddy eddy is online now
Currently: Dirt Bike Season!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
Default Headlight
Stock incandescent: 5 Amps 60 Watts
LED high performance: 3 Amps 36 Watts
Careful on the LED, make sure you get a quality product!
Best for SKI DOO H4 application:
https://www.racesportinc.com/rsh4ledhl.html
The Following User Says Thank You to eddy For This Useful Post:
  #5
Old 05-30-2018, 01:33 AM
donbrown's Avatar
Default
h4 or h13 for an 850 Summit ?
__________________
  #6
Old 06-01-2018, 02:22 PM
eddy's Avatar
Default G4 Headlight
You are correct G4 takes a H13 fitment
Link to best H13 for this application:
https://www.racesportinc.com/catalog.../?q=rsh13ledhl
donbrown (06-01-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — how to check fual pump amps Thread Starter — purepolaris600 Forum — Polaris: Pro-Ride Replies — 3 Last Post — 11-17-2013 07:14 PM
Thread — MM 700 Single or Dual Headlight Thread Starter — octanefam Forum — Yamaha: 2-stroke Replies — 1 Last Post — 12-03-2009 07:04 PM
Thread — Guitars and Amps Thread Starter — yammerhammer Forum — Fouled Plug Replies — 18 Last Post — 06-11-2009 02:05 PM
Thread — How many Amps Thread Starter — extremedesigndave Forum — Performance/Modified Replies — 6 Last Post — 04-07-2009 02:14 PM
Thread — 2-rockford fosgate amps Thread Starter — NOSNOSUKS Forum — Other (Swapmeet) Replies — 1 Last Post — 01-07-2008 05:07 PM
no new posts
