Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 05-14-2018, 09:23 AM
knocksum knocksum is offline
Currently: Not set.
Basic Member
knocksum has a reputation beyond reputeknocksum has a reputation beyond reputeknocksum has a reputation beyond reputeknocksum has a reputation beyond reputeknocksum has a reputation beyond reputeknocksum has a reputation beyond reputeknocksum has a reputation beyond reputeknocksum has a reputation beyond reputeknocksum has a reputation beyond reputeknocksum has a reputation beyond reputeknocksum has a reputation beyond repute
Default Poor Man Coupler and Wheelie control
Installing a camso x3 track this summer. I want to keep the skis down and not spend alot. What has worked for you? I have searched and came up with a couple options.
3/4 skid setback as seen in the thread below - Post #18
https://www.snowest.com/forum/showthread.php?t=416648
OR
Poor Man's coupler
Click image for larger version
Rate this post: Yes | No
  #2
Old 05-14-2018, 11:58 AM
Teth-Air's Avatar
Teth-Air Teth-Air is online now
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
Works great only not easy to adjust. Here is an easier way.
http://www.sourceinnovations.ca/prod...nsion-coupler/
About 3/4 price shown if you are buying with US dollars.
__________________
Home of the "Cordless Teth-Air" and NEW "Phantom Teth-Air"
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
  #3
Old 05-14-2018, 06:25 PM
Currently: Not set.
Basic Member
Default
Your products are great but I just want to spend minimal cash.
The Following User Says Thank You to knocksum For This Useful Post:
Teth-Air (06-16-2018)
  #4
Old 05-14-2018, 08:54 PM
Spaarky's Avatar
Spaarky Spaarky is online now
Currently: Moved Into Maximum Security Cell
Spaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond repute
Default
I can fully understand not wanting to spend a lot. After having ARC, it would be really tough to give it up though.
Moderate hill with moguls, one click to keep her under control. In the trees and need ski lift, then no clicks. Spring snow and steeper than I thought, grab both clicks. Trails are rough coming in, give it a click.
I will adjust mine as I go through terrain. Plus the infinite adjustment of the air shock.... even some of my stock buddies run it.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Spaarky For This Useful Post:
Scott (05-15-2018)
  #5
Old 08-14-2018, 04:15 PM
PSI 800 PSI 800 is offline
Currently: waiting to tear up the mtns
Basic Member
PSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond repute
Default
The Arc from Skinz is a lil pricey but I highly recommend it. I have had mine 2yrs now and lovin it
  #6
Old 08-14-2018, 08:12 PM
SRXSRULE SRXSRULE is offline
Currently: Not set.
SRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond repute
Default
Crank up the spring pre-load on the rear track shock. Costs ZERO and will do exactly what your looking to do.
This is the only change I did on my old pros when I went from the 2.4" to a 3"
The ride will suffer if you have to ride any trails, but it will keep the front end down.
  #7
Old 08-14-2018, 10:28 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default
OR
Poor Man's coupler
Pretty sure that's my photo.
I took that strap off a couple years ago.
__________________
What's up Sparky?
OEM parts from Free Agent
Ambassador
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Poor man's intake Thread Starter — tannerloeffen Forum — Arctic Cat: Proclimb M Replies — 5 Last Post — 01-23-2015 07:54 PM
Thread — Wheelie control? Thread Starter — Matte Murder Forum — Arctic Cat: Proclimb M Replies — 74 Last Post — 10-21-2013 10:27 PM
Thread — Poor Man's Hot Rod (Turbo) Thread Starter — BlowinSmoke Forum — Polaris (Swapmeet) Replies — 0 Last Post — 10-12-2012 10:46 AM
Thread — OVS / Simmons wheelie coupler for sale Thread Starter — Vertical-Extreme Forum — Suspension/Shocks (Swapmeet) Replies — 4 Last Post — 08-30-2011 09:05 AM
Thread — Poor man's Nytro tunnel clean-up Thread Starter — samsquatch47 Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 0 Last Post — 11-01-2010 08:55 PM
