Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 05-09-2018, 02:04 PM
Skis Up Skis Up is offline
Currently: Not set.
Basic Member
Skis Up is an unknown quantity at this point
Default Replacement Rollers 2008 M1000
Who makes roller kit for this clutch
I ate up a weight this last weekend
Rollers are shot
Clutch in great shape other than that
Thanks
Rate this post: Yes | No
  #2
Old 05-09-2018, 05:08 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
slp and thunder products
you will need 200.00 in tools if not your money ahead to just by a new one.
The Following User Says Thank You to kiliki For This Useful Post:
Skis Up (05-10-2018)
  #3
Old 05-10-2018, 11:28 AM
mbcat mbcat is online now
Currently: Not set.
Basic Member
mbcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond repute
Default Rollers
If it ate rollers better check hub & bushing too
The Following User Says Thank You to mbcat For This Useful Post:
  #4
Old 05-10-2018, 03:32 PM
jim jim is online now
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
I ate a roller last year for my M8 as well.
Short Story: Go to Amazon and buy a new clutch for $300.
I researched this a lot to try and save $$$. The issue is, the spider is difficult to remove...must use a lot of heat and around 1000 ft lbs (1000, not a typo). Any reputable shop who isn't trying to take your money will tell you that removing the spider may damage the clutch (lots of heat and torque). Then you have the sheaves that are worn, metal that was stressed from eating a weight, bushings are likely shot and the metal very stressed. So, you can spend about $200 to $250 to fully rebuild it or buy a new one. Just buy a new one. Yes, frustrating but that is how it goes for this clutch.
  #5
Old 05-11-2018, 05:32 AM
skidooboy's Avatar
skidooboy skidooboy is online now
Currently: titanium plate tester
skidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond repute
Default
buy a new uncalibrated clutch (about 3-350), send the old one to racin station for rebuild. then you have a spare. we have two now Ski
riding northern ontario's back country
  #6
Old 05-11-2018, 10:06 AM
Currently: Not set.
Basic Member
Default
Thanks for the update.
  #7
Old 05-12-2018, 07:35 AM
snownman snownman is offline
Currently: Not set.
snownman has a reputation beyond reputesnownman has a reputation beyond reputesnownman has a reputation beyond reputesnownman has a reputation beyond reputesnownman has a reputation beyond reputesnownman has a reputation beyond reputesnownman has a reputation beyond reputesnownman has a reputation beyond reputesnownman has a reputation beyond reputesnownman has a reputation beyond reputesnownman has a reputation beyond repute
Default Not an m8...
you will not buy a new M1000 clutch for 300.00 anytime. The m8 clutch is a lot different and you can buy them for 300.00 but NOT an m1000 The M1000 uses a 35 mm shaft and the cat part # 0746-841 you can get them from babbits or cat country for 441.00... we rebuild the M1000 clutches when we need to and use thunder products roller kits ( about $90.00) they work very well. you do need the tools to rebuild it though and a good torque wrench.
  #8
Old 05-12-2018, 08:17 AM
Currently: Not set.
Garage
Default
I most likely have weights if you need them. Would love to get them out of the stack
  #9
Old 05-12-2018, 09:22 PM
boondocker97 boondocker97 is online now
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
Also have some MDS weights kicking around for a M1000 with less than 500 miles on them if interested.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
  #10
Old 06-08-2018, 10:50 AM
Currently: Not set.
Basic Member
  #11
Old 08-05-2018, 12:25 PM
BD-Xtreme's Avatar
BD-Xtreme BD-Xtreme is offline
Currently: Not set.
BD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond repute
Click Here to Register
  #12
Old 08-08-2018, 07:38 AM
Mike from langley Mike from langley is offline
Currently: Not set.
Basic Member
Mike from langley has a reputation beyond reputeMike from langley has a reputation beyond reputeMike from langley has a reputation beyond reputeMike from langley has a reputation beyond reputeMike from langley has a reputation beyond reputeMike from langley has a reputation beyond reputeMike from langley has a reputation beyond reputeMike from langley has a reputation beyond reputeMike from langley has a reputation beyond reputeMike from langley has a reputation beyond reputeMike from langley has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M1000 reed replacement;TPS adj; drive shaft bearing replacement; tank replacement Thread Starter — Sledbrain2 Forum — Arctic Cat: M Series Replies — 0 Last Post — 01-16-2016 09:38 PM
Thread — Yamaha Clutch replacement Rollers and secondary spring New Thread Starter — vern1 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 5 Last Post — 10-08-2008 09:20 AM
Thread — Looking for After market Primary rollers 2008 Thread Starter — bigd1000 Forum — Arctic Cat: M Series Replies — 0 Last Post — 03-10-2008 04:26 PM
Thread — Wtb Rock Rollers For M1000 Thread Starter — 1100Cat Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 02-08-2008 12:39 AM
Thread — Secondary Clutch Replacement Rollers for Arctic Cat and 08 Rev XP Thread Starter — Hi-Torque Rollers Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 01-19-2008 05:12 PM
no new posts
