Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 05-07-2018, 10:01 PM
TRS's Avatar
TRS TRS is offline
Currently: Waiting for winter
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
Default Fuel filter/pickup
Looking at eliminating the stock fuel filter on my PRO Ride.
Then replacing the tank pickup with the AXYS sock filter/pickup. They are available from SPI for less than $60.
Anyone try this?
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to TRS For This Useful Post:
Mark's RMK (05-09-2018), ZRP Engineering (05-09-2018)
  #2
Old 05-08-2018, 11:20 AM
TRS's Avatar
TRS TRS is offline
Default
Guess Iíll be the first. Iíll report back.
The Following 5 Users Say Thank You to TRS For This Useful Post:
05900 (05-09-2018), Hellsledder (05-08-2018), Mark's RMK (05-09-2018), Sheetmetalfab (05-08-2018), ZRP Engineering (05-09-2018)
  #3
Old 05-09-2018, 11:02 AM
gtwitch gtwitch is offline
Currently: Not set.
gtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond repute
Default
Tony : let us know here as I think I would like to do this also! If it works for the AXYS it should be OK on the PRO chassis I would think.
gtwitch in wyoming
  #4
Old 05-09-2018, 10:05 PM
ZRP Engineering's Avatar
ZRP Engineering ZRP Engineering is offline
Currently: Not set.
ZRP Engineering has a reputation beyond reputeZRP Engineering has a reputation beyond reputeZRP Engineering has a reputation beyond reputeZRP Engineering has a reputation beyond reputeZRP Engineering has a reputation beyond reputeZRP Engineering has a reputation beyond reputeZRP Engineering has a reputation beyond reputeZRP Engineering has a reputation beyond reputeZRP Engineering has a reputation beyond reputeZRP Engineering has a reputation beyond reputeZRP Engineering has a reputation beyond repute
Default
This is an outstanding idea!
Sent from my SM-G950U using Tapatalk
__________________
  #5
Old 05-10-2018, 06:25 PM
TRS's Avatar
TRS TRS is offline
Default
Itíll be Wednesday before it gets here.
Should be on the snow Friday. Iíll test it on the Ď12 turbo.
2 out of 2 members found this post helpful. Rate this post: Yes | No
Scott (05-10-2018), Spaarky (05-10-2018)
  #6
Old 05-16-2018, 08:10 PM
TRS's Avatar
TRS TRS is offline
Default
Itís here, Iíll try to get it in tomorrow. Iíll take pics.
  #7
Old 05-17-2018, 05:20 PM
TRS's Avatar
TRS TRS is offline
Default
Here it is.
I removed the hard line from the sock and installed the sock on the original hose from the pump.
I removed the fuel rail fitting from a stock filter assembly and ran 5/16 fuel injection hose to the tank. Napa had the Dorman fuel line connector.
Used 15.3 oetiker clamps on the assembly. Polaris part 7081502, Doo part 293650047.
I’ll test it this weekend. It runs the same in the shop so......I think this is going to work great.
Edit: added a pic
Click image for larger version
ID:	296037   Click image for larger version
ID:	296038   Click image for larger version
ID:	296040   Click image for larger version
The Following User Says Thank You to TRS For This Useful Post:
Spaarky (05-17-2018)
  #8
Old 05-18-2018, 08:00 PM
TRS's Avatar
TRS TRS is offline
Default
Headed to Cooke in the morning.
I believe there is a benefit fund raiser for the Avalanche Center in Cooke tomorrow.Cooke City Sled Fest - May 19
Posted on the Centers site.
Sledders, mark your calendar for May 19, the 2nd Annual Sled Fest in Cooke City. It’s a fundraiser for the Friends of the Avalanche Center and there will be a DJ, raffle prizes and BBQ on the mountain.
  #9
Old 05-19-2018, 07:05 PM
TRS's Avatar
TRS TRS is offline
Default
Yep, works just fine. I think this is a great upgrade to the PRO fuel system.
Great turnout for the Avy Center fund raiser. Lots of wobble pop getting consumed.
Spaarky (05-20-2018)
  #10
Old 05-19-2018, 09:19 PM
kanedog kanedog is online now
Currently: resident jackass #2
kanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond reputekanedog has a reputation beyond repute
Garage
The Following User Says Thank You to kanedog For This Useful Post:
TRS (05-20-2018)
  #11
Old 05-20-2018, 03:39 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Currently: Never enough snow!!!
BILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond repute
Click Here to Register
  #12
Old 05-20-2018, 06:57 PM
TRS's Avatar
TRS TRS is offline
  #13
Old 05-20-2018, 09:40 PM
SRXSRULE SRXSRULE is online now
Currently: Not set.
SRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond reputeSRXSRULE has a reputation beyond repute
  #14
Old 05-20-2018, 09:42 PM
Currently: Not set.
  #15
Old 05-21-2018, 06:46 AM
TRS's Avatar
TRS TRS is offline
Sage Crusher (05-23-2018)
  #16
Old 05-23-2018, 05:38 PM
diamonddave's Avatar
diamonddave diamonddave is offline
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
  #17
Old 06-02-2018, 02:47 AM
rydningen rydningen is online now
Currently: Not set.
rydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond reputerydningen has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — SPI FUEL FILTER: FUEL LINE ISSUE Thread Starter — jsledder Forum — Polaris: Pro-Ride Replies — 31 Last Post — 09-23-2016 09:50 AM
Thread — Adding a fuel filter from fuel pressure reg. to the carbs. Your opinions plz? Thread Starter — PJ-Hunter Forum — Ski-Doo: TURBO Replies — 4 Last Post — 02-27-2013 04:25 PM
Thread — What's the fix for the fuel pickup??? Thread Starter — Nukin futz Forum — Arctic Cat: Proclimb M Replies — 7 Last Post — 12-31-2012 02:48 PM
Thread — Fuel tank + Fuel Pump + Fuel Filter for 2006 900 RMK Thread Starter — Dogmeat Forum — Chassis/Tunnel (Swapmeet) Replies — 0 Last Post — 12-06-2010 07:48 PM
Thread — 97 XLT fuel Pickup Problem Thread Starter — Dartos Forum — Polaris Replies — 1 Last Post — 01-14-2009 07:43 PM
no new posts
