Upgrade to Premium
Reply
  #1
Old 05-07-2018, 12:19 PM
TNTCOPP's Avatar
TNTCOPP TNTCOPP is online now
Currently: Back to selling.....
TNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond reputeTNTCOPP has a reputation beyond repute
Default 2017 Arctic Cat M8000 162 Limited Proclimb - BRAND NEW! - $11200
Brand new 2017 M8000 162 LIMITED PROCLIMB - yes zero miles!! Decided to go another route.
Save on freight, tax, set-up, license, and doc fees! 2-Year full factory warranty until 04/01/2020!
2017 Arctic Cat® M 8000 Limited (162)
Features may include:
• 8000 ENGINE
160-class HP makes this 794cc 2-stroke the most powerful 800 engine in the industry. It features a lightweight, quick-revving crankshaft, twin spark plugs per cylinder and weight-saving engine reverse technology. The engine knock sensor provides octane recognition, giving you more fuel options.
• ARCTIC DRIVE SYSTEM WITH TEAM RAPID RESPONSE DRIVE AND TEAM RAPID RESPONSE BOSS DRIVEN CLUTCHES
The Arctic Drive System™ features a lightweight magnesium chaincase. The design incorporates a large TEAM® driven clutch and TEAM drive clutch. By eliminating belt skid, these clutches reduce temperature and transfer more power to the track. In addition to their incredible strength, these clutches are known for their easy and precise tuning.
• ARCTIC MOUNTAIN FRONT SUSPENSION WITH FOX FLOAT 3 EVOL SHOCKS
The Arctic Mountain front suspension packs the essentials. The ProClimb-7 mountain ski is 7" at the tip, tapering to 6.5" at the center to enhance your carving. Single-post, angled-out spindles help you shed some sled weight while maximizing quality and strength. The premium FOX FLOAT® 3 EVOL shocks offer lightweight design, simplified adjustment and premium bump control features of the FLOAT 3, but with improved resistance to bottoming and reduced cornering "roll" thanks to the added EVOL air chamber.
• FLOAT-ACTION REAR SUSPENSION WITH FOX FLOAT 3 EVOL FRONT AND FOX FLOAT 3 EVOL R REAR SHOCKS
The FLOAT-ACTION Rear Suspension features revised rails that shed 1.25 pounds, giving optimal suspension travel and a better ride quality in all conditions. The FLOAT-ACTION suspension incorporates mountain-specific geometry, delivering consistent track tension. The FOX FLOAT® 3 EVOL ski and front track shocks, plus the FOX FLOAT 3 EVOL R rear track shocks, are engineered as a lightweight design, with the simplified adjustment and premium bump control features of the FLOAT 3 shocks, but with the improved resistance to bottoming and reduced cornering "roll" that comes with the added EVOL air chamber.
• DELUXE DIGITAL ANALOG GAUGE
The deluxe gauge lets you choose between digital and analog speed and tachometer readouts. There's also an odometer, two trip meters, engine hour meter, reverse indicator and warning lights. Like we said, it's deluxe.
• 12V OUTLET
Need to charge your phone or another electrical device? We've got you covered. Just plug in and power up while you ride.
• HAND & THUMB WARMERS
Say goodbye to cold hands. Our hand and thumb warmers provide plenty of warmth and comfort on long rides.
• 162-IN. POWER CLAW TRACK WITH 2.6-IN. LUGS
This lightweight, ultralong 162" single-ply track with a 3-in. pitch sets the standard for deep snow performance. Stagger-set, curved-forward paddle towers won't fold over. This track features a powder-devouring 2.6" lug height.
• HCR-TYPE HEAT EXCHANGER
Proven on our HCR model for the past four seasons, this exchanger is nearly 4 lbs. lighter than full-length versions. Plus it reduces snow build up to reduce even more weight.
• ICE SCRATCHERS
As part of the heat exchange system, ice scratchers can save the day when there's minimal snow but plenty of ice. In that kind of riding condition, lowering the ice scrapers kicks up ice to help prevent your engine from overheating.
• MOUNTAIN STRAP
Want to shift your weight? This puts the extra leverage you need right in your hands.
• PROCLIMB - 7 SKIS
The new ProClimb-7 mountain ski is 7" at the tip, tapering to 6.5" at the center. The wider skis enhance your carving abilities and prevent unintended downhill braking. A wider ski damper featuring a longer axle and bolt increases lateral adjustability.
Click image for larger version
ID:	295914   Click image for larger version
ID:	295915   Click image for larger version
ID:	295917   Click image for larger version
__________________
2019 ALPHA 165 SLP Stage II , 2COOL VENTS , ALL GREEN REMOVED!
2017 ProClimb M8000 162 LE - SLP Stage II
2017 ProClimb M8000 162 LE ES, SLP can
Rate this post: Yes | No
  #2
Old 07-26-2018, 09:00 AM
TNTCOPP's Avatar
Default
TTT
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 2017 Arctic Cat M8000 SnoPro 162 Thread Starter — YMS-YHD Forum — Arctic Cat (Swapmeet) Replies — 3 Last Post — 10-08-2018 11:05 AM
Thread — 2016 Arctic Cat M8000 Limited Sno Pro 162 Thread Starter — Joks79 Forum — Arctic Cat (Swapmeet) Replies — 12 Last Post — 12-03-2017 03:58 PM
Thread — 2014 Arctic Cat M8000 Limited 162"- $6975. b/o Thread Starter — Rock Hound Forum — Arctic Cat (Swapmeet) Replies — 2 Last Post — 12-30-2016 11:46 AM
Thread — 2014 ARCTIC CAT M8000 LIMITED 162" $7995 Thread Starter — Speed Shop Inc. Forum — Arctic Cat (Swapmeet) Replies — 0 Last Post — 11-03-2015 04:05 PM
Thread — 2014 Arctic Cat M8000 Limited 162 $4000 Thread Starter — h2arctic Forum — Arctic Cat (Swapmeet) Replies — 0 Last Post — 12-29-2014 01:37 PM
no new posts
