Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 05-06-2018, 03:59 PM
ZB1988 ZB1988 is offline
Currently: Not set.
Basic Member
ZB1988 is an unknown quantity at this point
Default 05 RMK 900
Ok dudes, first time poster long time reader. Iíve been working on this 05 rmk for a few months. Iíll try to sum up the backstory quickly but I fear itís going to be a novel, but I bought this sled in the winter and rode it once. Flashed the egt probe at me. I shut it down and checked, sure enough previous owner had it disconnected. Connected the probe and carried about my ride. It was cold out. -20c. So it took a while to warm up. It was kinda funny in the low end with power cutting out but immediately ran great. Rode it for a couple hours. All seemed well. My buddy rode it the following day quickly with about the same results. Did a lot of research on the sled (a lot, I still do daily) so I thought tps or harness. I set up the tps to factory spec and proved itís functional throughout its entire band with my oscilloscope. While I had it out, I probed the harness and found the signal to drop out. Groovy I thought. Bought a new pigtail and replaced it. I replaced the throttle and oil cable at this time. I noticed many repairs in the main harness at this time. And thought I solved my original issue. While I had the sled in the shop doing this work, I also installed the slp head I bought to use as well. I thought it would compliment the slp pipe and can quite well. Fueled it up with 50/50 ethanol free 91 and VPC11 with a little premix and installed new ngk plugs and a brand new egt probe for the hell of it. Sled was ready to go otherwise. And found I had very poor performance. Plugs looked very black and oily. While I had the head off I noticed the top end looked very poor. Piston skirts and cyl walls were notably worn. So I said ok and I went ahead and bought myself a new main harness and fuel filter and tested fuel pressure. All of which was ok. So then I went and bought myself a wrecked rmk with what I was told was a good running engine. Plugs looked nice when I pulled them and the top end was looking great. So I did the swap, installed the slp head on the second engine. And idled it on the stand to op temp to bleed coolant, revved it up a few times. Noticed a few spots of oil on the shop floor. Checked the plugs and sure enough theyíre black and oily. Iím at a loss, the pump is set up and arm returns perfectly. Seems odd the same issue is happening on two engines. Any advice on where to go next with the diagnosis? This engine starts and idles just fine, as did the prior one. Perfect idle rpm.. Iím starting to think the Center seal is ironically blown on both engines...
Rate this post: Yes | No
  #2
Old 05-06-2018, 06:14 PM
Currently: Not set.
Basic Member
Default
I should add, I want to rule out the stator on engine 1, ohmed out perfect. I used engine 1s reeds in engine 2.Used engine 2s injector harness and ignition harness. They looked to be better. I also used engine 1s intake boots on engine 2 as they looked to be recently replaced and the ones on 2 were scorched. Exhaust valves functioned on both engines. I also know for a fact I did not starve either engine for oil. I bled it all perfectly. There was prior other electrical problems, shorts in the main harness from the bar riser pulling the harness into the rider select area, found this upon the third ride. And the 3x yellow connector was making poor contact. Repaired this and all electrical issues appeared to be resolved st this point. Good lights, added heated grips are working great. I wonder if the ECM took a hit from all that going on and itís just running rich for some reason. Going to swap ecms and capacitors and tps. Will rule out every electrical component to me. Engine 1 had 110 psi on both sides at 3000ft. Top end was torched for sure. Lol. Itís getting closer though. Just thought Iíd share my experience thus far and see if you all have some insight!
Click image for larger version
ID:	295876   Click image for larger version
ID:	295877   Click image for larger version
  #3
Old 05-13-2018, 05:57 PM
94fordguy's Avatar
94fordguy 94fordguy is offline
Currently: Enjoying the snow!
94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute
Default
Looks like a good project! I'd fill the oil bottle full and see if the level drops, that would indicate a bad center seal. I'm not sure how much oil it would take to foul a plug, my sled is currently running 18:1 on oil... I've tried without success to lean it out on oil, I think the pump is just worn out and puking way too much oil into the engine, however it hasn't caused me any running issues yet so I've let it be. Good luck with your project, I'm just short of 6700 mountain miles on my 05 166 now!
__________________
ARRA MEMBER - Americans for Responsible Recreational Access
WSSA MEMBER - Washington State Snowmobile Association
Yakima Ski Benders MEMBER - Washington's first snowmobile club
Support Public Access to Public Land
13 PRO RMK 800 162 VEI Custom
12 Ford F-350 Lariat C/C S/B 4x4 6.7L Powerstroke...133K
08 Polaris Scrambler 500 4x4
06 Kawasaki ZZR 600
05 RMK 900 166 Anniversary Edition #850 6,782 Miles
02 Interstate 19' Enclosed
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 755/900 fire n ice intake off 06 900 rmk Thread Starter — dktraw Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 0 Last Post — 02-22-2015 10:12 AM
Thread — 05 - RMK 900 parts: Need a front shock for a 05 RMK 900 and a right lower A arm.... Thread Starter — gunslinger770 Forum — Suspension/Shocks (Swapmeet) Replies — 5 Last Post — 11-18-2011 02:07 AM
Thread — Opinions needed:2004-900 1M or 2006 900 RMK? Thread Starter — REPO Forum — General Snowmobiling Replies — 56 Last Post — 11-21-2010 10:28 PM
Thread — WTB: Ride FX shocks from 05 900 or 06 600, 700 or 900 Polaris RMK, looking for all 4 Thread Starter — Sundance Kid Forum — Suspension/Shocks (Swapmeet) Replies — 1 Last Post — 10-08-2010 09:12 AM
Thread — WTB: Ride FX shocks from 05 900 or 06 600, 700 or 900 Polaris RMK, looking for all 4 Thread Starter — Sundance Kid Forum — Suspension/Shocks (Swapmeet) Replies — 7 Last Post — 08-30-2010 07:56 AM
no new posts
