Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 05-03-2018, 11:42 PM
Skibum25 Skibum25 is offline
Currently: Not set.
Basic Member
Skibum25 is an unknown quantity at this point
Default 03 vert escape.
Im new to the snow machine world, i recently purchased this sled and I'm Looking to do an engine swap. (Currently has a 96 engine) I've worked small engines before not a crazy job, however what engines are compatible with the 03 vertical escape chassis/ engine bay? Thanks in advance.
Rate this post: Yes | No
  #2
Old 05-04-2018, 01:59 PM
BeartoothBaron BeartoothBaron is offline
Currently: Not set.
BeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond repute
Default
What you're looking for would be a Polaris Liberty twin, 600, 700, or 800 with VES (variable exhaust system). The 600 is often referred to as the "small block:" it's physically smaller than the 700 and 800. The 700 and 800, "big block" are easy to tell apart by the bigger recoil cover that houses the (belt driven) oil and water pumps. Polaris introduced those motors in the previous chassis as a 600 and 700, then 800 for a year or two, without VES. Those engines will bolt up provided you've got the correct mounts, and the only "problem" is they're less powerful than the VES variants. You can tell the VES motors at a glance, they have a casting that protrudes from the exhaust side with a black plastic cover.
The best motors in terms of reliability are the 600 and 700; the 800s tend to have a lot of crank issues. You'll want to find a complete setup (with air box, carbs, exhaust, ignition, and so on), and the clutches if you can. Buying a wrecked sled would probably be best if you can find one. Starting with a bare motor and having to buy the rest piecemeal might end up costing you as much as a comparable sled. Once you have all the right pieces, it's relatively simple to bolt it all up.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to BeartoothBaron For This Useful Post:
Skibum25 (05-04-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 04 vert escape seat Thread Starter — throttleout Forum — Seats (Swapmeet) Replies — 0 Last Post — 11-08-2009 05:53 PM
Thread — Torque on 04 vert escape Thread Starter — BPierce Forum — Polaris Replies — 2 Last Post — 01-08-2009 10:50 PM
Thread — Need help with tuning an 03 Vert. Escape... Thread Starter — Snobalz Forum — Performance/Modified Replies — 10 Last Post — 03-09-2008 12:22 PM
Thread — 03 vert escape 159 Thread Starter — bustedcrank Forum — Polaris (Swapmeet) Replies — 2 Last Post — 03-04-2008 05:09 PM
no new posts
