Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 04-26-2018, 06:45 AM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default Burn down question
So I bought a 2000 summit 700 HM for a summer project. The guy I bought it from said he got it on a trade deal and it had a top end rebuild done to it just before he got it. While he was breaking it in it locked up. He took the head off and decided he didn't want to mess with it so I bought it. I tore it down and this is what I found. What do you think caused this. Lack of oil, to hot, or not letting it warm up before hammering down?
Click image for larger version
ID:	295721   Click image for larger version
ID:	295722   Click image for larger version
ID:	295724   Click image for larger version
ID:	295725   Click image for larger version
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
Rate this post: Yes | No
  #2
Old 04-26-2018, 12:01 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
a buddy had a 2000. when his stuck a piston the dealer said there was an update to the oiler that was never done. basically just turning up the oil injector i believe.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to sno*jet For This Useful Post:
cubby (04-26-2018)
  #3
Old 04-27-2018, 03:21 PM
cubby's Avatar
Default
Pretty sad at how slow this site has gotten over the years. Hell I posted on dootalk and have lots of comments and advise as to what to do. Seems like if a guy doesn't have a 850 no one cares around here. Or it's just the same 10 people everywhere on here.
__________________
2016 T3 154"
2013 Polaris 850xp
2015 Polaris 1000xp
  #4
Old 04-27-2018, 08:18 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Stirring pots
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
I had a 2000 summit 700..
The only issue i had with the stock oiler setting is crank bearings. Locked up at 1,756miles. After rebuild, turned up oiler and my brother still has that sled with over 5k miles now. I know he rebuilt it again just after it hit 5k. Bearing again...
To me, it looks like it wasn't warm enough before riding...
The Following User Says Thank You to summ8rmk For This Useful Post:
cubby (04-28-2018)
  #5
Old 05-01-2018, 10:31 AM
skidoome skidoome is online now
Currently: ready for snow!
Basic Member
skidoome has a reputation beyond reputeskidoome has a reputation beyond reputeskidoome has a reputation beyond reputeskidoome has a reputation beyond reputeskidoome has a reputation beyond reputeskidoome has a reputation beyond reputeskidoome has a reputation beyond reputeskidoome has a reputation beyond reputeskidoome has a reputation beyond reputeskidoome has a reputation beyond reputeskidoome has a reputation beyond repute
Default
If the engine was using the correct amount of oil I think it could be:
Forged vs Cast piston clearance issue.
Forged pistons grow faster then the stock Cast pistons and are easy to cold seize.
If the bore wasn't sized to the forged piston this will happen unless extreme care is used.
Have seen this issue a lot with back yard mechanics.
  #6
Old 05-03-2018, 09:16 PM
eddy's Avatar
eddy eddy is online now
Currently: Dirt Bike Season!
eddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond reputeeddy has a reputation beyond repute
Default 700 Bore
If the motor go real hot with the previous owner the bore may be out of round. Clean the aluminum off the bore and check the fit of your new pistons. Check ring gap in several places as well. BTW we have used that exact piston in that motor and they work great. Set the oiler to spec (maybe the 2001 and after spec?), use premix until you can verify the oiler is set to deliver at 36/1 or so while in use.
BTW looking at the pictures: if the previous rebuild had a buggered base gasket union surface you may have found a problem. Also check the water pump impeller, or just replace, as when a meltdown happens: the impeller may have caused it or is damaged by it. Best stuff to use for cleaning the base gasket surface is a Loctite product called Chisel.
The Following User Says Thank You to eddy For This Useful Post:
cubby (05-04-2018)
  #7
Old 05-04-2018, 06:48 AM
cubby's Avatar
Default
Thanks Eddy for your advise, I will check into all of that so I can ensure that it runs like a top long after I'm done
__________________
2016 T3 154"
2013 Polaris 850xp
2015 Polaris 1000xp
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Burn down, question on these pictures, please comment Thread Starter — Lank Forum — Arctic Cat: 1M Replies — 26 Last Post — 12-05-2011 09:50 AM
Thread — M7 Burn Down Cause? Thread Starter — GBrown Forum — Arctic Cat: M Series Replies — 19 Last Post — 03-23-2011 02:57 PM
Thread — 09 M8 Burn Down Thread Starter — butch1969 Forum — Arctic Cat: M Series Replies — 33 Last Post — 12-07-2010 04:05 PM
Thread — Burn down!!!!! Thread Starter — aktrucker Forum — Alaska Replies — 23 Last Post — 01-28-2010 11:59 PM
Thread — so if I burn down twice.... Thread Starter — ACG Forum — Utah Replies — 6 Last Post — 04-19-2009 11:29 PM
no new posts
