Upgrade to Premium
Polaris: IQ 2005-current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 04-25-2018, 10:33 PM
TimG TimG is online now
Currently: Prairie boondocking
TimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond reputeTimG has a reputation beyond repute
Default Calibrating TPS without TPS tester
I needed to check and calibrate the TPS on my Dragon, but it doesn’t have the plug with orange and brown wires like the Pro and Axys. What to do? After spending some quality time with the wiring diagram in the service manual, I figured it out, and you don’t need a TPS tester to calibrate the TPS. You just need a good quality multimeter and a 12v power source.
Put 12v into the pink wire on the diagnostic plug, ground to the black/ dark blue in the same plug. Then follow the same procedure as the Pro or Axys. Back probe the # 10 wire (red/white) on the smaller ECU plug. You can use a sewing needle or safety pin to back probe, and do it carefully so as to not wreck the wire seal. You should have 4.99-5.01 volts at the #10 wire. Then back probe the # 23 wire (aqua) on the same plug. This is the return signal from the TPS. Back off the idle screw till the throttle blades bottom out, and adjust the TPS until it reads .700 volts. Snap the throttle a number of times to make sure it stays there. Then adjust the idle screw till you get .95 volts for 700s, and .93 for 800s. Again, snap the throttle a bunch of times to make sure it’s stable. Done!
An advantage of doing it this way is that you’re reading everything off the ECU, so you’re seeing what it sees. This helps eliminate wiring trouble between the TPS and ECU. And you don’t have to go buying a TPS tester. Make sure you have a good quality multimeter though. Don’t trust a cheapie for this. I check with a couple of meters to make sure.
Tim
Rate this post: Yes | No
The Following User Says Thank You to TimG For This Useful Post:
guidoxpress (05-06-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — TPS tester ??? Thread Starter — Rixster Forum — Arctic Cat: M Series Replies — 1 Last Post — 10-14-2015 09:41 PM
Thread — TPS tester Thread Starter — Laundryboy Forum — Polaris: Pro-Ride Replies — 10 Last Post — 09-25-2014 07:59 AM
Thread — TPS tester Thread Starter — Ghuds Forum — Polaris: IQ Replies — 1 Last Post — 02-19-2013 10:18 PM
Thread — Need help calibrating TPS on PCV Thread Starter — Sula Tom Forum — Polaris: IQ Replies — 19 Last Post — 03-02-2010 10:01 PM
Thread — calibrating tps w/ pcv? Thread Starter — randy542 Forum — Polaris: IQ Replies — 3 Last Post — 02-20-2010 02:38 PM
no new posts
