Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 04-25-2018, 07:47 PM
mtncat600 mtncat600 is online now
Currently: Not set.
Basic Member
mtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond repute
Default 2017 sno pro m8000 bog
have 2 2017 m8000 both sleds still
in break in with 100:1 mix in tank
both sleds are new and have a low end
bog /hesitation just above idle anyone had this ? what is it ? thanks
Rate this post: Yes | No
  #2
Old 04-26-2018, 02:39 AM
Northlight Northlight is online now
Currently: Not set.
Basic Member
Northlight is an unknown quantity at this point
Default
Its normal, all the cats I have ridden have had that bog, alot of people say you can fix it with intake air temperature sensor relocate, haven't tried it myself.
  #3
Old 04-26-2018, 07:44 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
Default
Finish running the break in gas/oil out first. The bog is most likely an over fuel situation. If the bog is still there you can minimize it. Avoid excessive idling, check your idle speed, I keep mine 1800-1900, stay away from ethanol fuels. The engine will make full power around the 500 mile mark, it takes that long on the Suzuki. Just an fyi if you raise the idle speed to high (2100 or so i cant remember exactly) it wont go in reverse. Mine runs great and is crisp maybe not C tec crisp but nothing that will get you in trouble. Best of luck
  #4
Old 04-26-2018, 11:07 AM
sno*jet sno*jet is offline
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
could always be the TSS. make sure your throttle cable is adjusted correctly.
  #5
Old 08-05-2018, 08:23 AM
Duff Duff is offline
Currently: Not set.
Duff has a brilliant futureDuff has a brilliant futureDuff has a brilliant futureDuff has a brilliant futureDuff has a brilliant futureDuff has a brilliant futureDuff has a brilliant futureDuff has a brilliant futureDuff has a brilliant futureDuff has a brilliant futureDuff has a brilliant future
Default
I have the same thing going on with my 17. Always bogs at inopportune times.
  #6
Old 08-05-2018, 11:40 AM
BD-Xtreme's Avatar
BD-Xtreme BD-Xtreme is offline
Currently: Not set.
BD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond repute
Default 2017 bog
In 2017 Cat reshimmed the drive clutch and lowered the engagement rpm by a lot. The Suzuki motor, with the exhaust valve only on the main exhaust port and not the auxiliary exhaust ports doesn't have the power at 3500 rpm that the 2018 ctec motor has. Yet they clutched it like it does.
Add our ProShift mountain clutch kit and it will be a whole new animal! Yes we do raise the engagement some, but its still nice an smooth. Stock clutching is simply just really bad in 2017.
The clutch kit is only $269.95 with our new springs, ProMag weights, and our custom machined Helixes. This clutch kit his excellent throttle response in deep snow.
Another item that works excellent to improve the low end is our Y pipe. We really emphasized on the low end and mid range gains with the Y pipe. Easy inexpensive power. 4.5 lb/ft of torque gain and 7 hp in the mid range gain. 4-5 peak hp gain. With our clutch kit we recommend using more weight in the clutch arms when using the Y pipe to harness the extra power. Only $169 and is made of polished stainless steel.
Both our Stainless and Titanium mufflers with drop a lot of weight as well. and will make the sled run about 100 more rpm.
Utilizing dual overlapping internal mechanical baffler system that has a nice deep rumble but isn't loud like the straight through glasspack style mufflers. 15 gauge construction, and now our Titanium mufflers are polished too. Drop 17 lbs of weight with the stainless one, and almost 20 lbs with the titanium!
$229 for stainless and $449 for titanium.
http://www.bd-xtreme.com/index.php?i...oller=category
Click image for larger version
ID:	296530   Click image for larger version
Name:	SSI 10-101.jpg
ID:	296531   Click image for larger version
Name:	12-110ti polished arctic cat muffler ssi.jpg
__________________
www.BD-XREME.com
http://www.speedshopinc.com
www.SPEEDSHOPINC.com
  #7
Old 08-05-2018, 01:12 PM
Currently: Not set.
Default
I disagree that 17s had bad clutching. I ride 2500'-8000' on stock clutching. works great. I know it would not work as great with a clutch kit in that broad of a range. you can raise engagement a hair with a glide washer kit like from thunder products. That y-pipe does add a little low end-mid snap. Id have to see one on a dyno to believe the raise of top end power. I run stock weights with that Ti can and y-pipe. runs great everywhere including powder stacked on the hood. turn off your thumb warmer in those conditions or TSS will bog you.
  #8
Old 08-05-2018, 01:21 PM
Big10inch Big10inch is offline
Currently: Not set.
Basic Member
Big10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond repute
Default
I would also mention that the SSI stainless can I added to my 17 Mtn Cat is REALLY loud. Louder than any of my buddies sleds also with cans. More raspy than rumble compared to my buddies can on his 16. Probably going to change it...
  #9
Old 08-10-2018, 07:25 PM
Currently: Not set.
Default
I'm so sick of the bog on this machine.... I'll call you next week, I already have the Ti can.
  #10
Old 10-28-2018, 06:45 PM
therookie therookie is online now
Currently: Not set.
therookie is an unknown quantity at this point
  #11
Old 10-29-2018, 08:05 AM
eldereldo eldereldo is offline
Currently: Not set.
eldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond repute
Click Here to Register
  #12
Old 10-29-2018, 10:46 AM
Currently: Not set.
  #13
Old 10-30-2018, 02:46 PM
Thunder101 Thunder101 is offline
Currently: making room in the garage :)
Thunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2017 m8000 sno pro antifreeze tube leak? Thread Starter — mtncat600 Forum — Arctic Cat: Proclimb M Replies — 14 Last Post — 02-12-2018 11:11 AM
Thread — Just got a new 2017 m8000 sno pro need bar help Thread Starter — biggdaddy Forum — Arctic Cat: Proclimb M Replies — 2 Last Post — 01-20-2018 09:03 PM
Thread — new 2017 m8000 sno pro 153 ski stance trouble Thread Starter — mtncat600 Forum — Arctic Cat: Proclimb M Replies — 3 Last Post — 10-16-2017 09:11 AM
Thread — 2017 M8000 Mountain Cat 153" / 2017 ZR8000 Sno Pro 129" - Speedwerx R&D Sleds Thread Starter — SpeedwerxInc Forum — Arctic Cat (Swapmeet) Replies — 0 Last Post — 10-09-2017 03:21 PM
Thread — 2017 m8000 sno pro battery charging? Thread Starter — mtncat600 Forum — Arctic Cat: Proclimb M Replies — 2 Last Post — 09-21-2017 08:16 AM
no new posts
