Upgrade to Premium
Trucks and Trailers Towing and hauling your sleds
Reply
  #1
Old 04-25-2018, 12:15 PM
dallen dallen is offline
Currently: Not set.
dallen is an unknown quantity at this point
Default Logan and Trails West Heaters?
Anybody have any experience with the factory supplied heaters in a Logan or Trails West? Looking at a new Logan trailer and wondering if I need the new 70,000 BTU Hot Dawg heater? It is only available in the 2019 and apparently is now standard in the Zbroz edition. Is the basic 40,000 BTU heaters these come with enough to warm the trailer? I want to be able to hang out and sleep in this trailer at times, with young kids. Just wondering if the extra money is worth it for the dual heaters?
Rate this post: Yes | No
  #2
Old 04-25-2018, 02:46 PM
Snowmow's Avatar
Snowmow Snowmow is online now
Currently: Not set.
Snowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond repute
Default
I have a 2016 burandt 28í bumper pull. The 42k furnace is more than enough.
  #3
Old 04-25-2018, 07:54 PM
turboless terry's Avatar
turboless terry turboless terry is online now
Currently: Not set.
turboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond repute
Default
Get the hot dawg. It is the bomb. The 40k is not enough when cold. The hot dawg will warm it up and the 40k will maintain. They all have the same heater and they aren't enough.
  #4
Old 04-25-2018, 08:56 PM
Snowmow's Avatar
Currently: Not set.
Default
Btu isnít the factor In the space were talking about.
CFM Is the real issue. And air recycling. All these trailers suffer from intake and exhaust differential. They produce great heat but they donít circulate the air.
  #5
Old 04-25-2018, 08:57 PM
Snowmow's Avatar
Currently: Not set.
Default
Does the hot dawg over 40k come with a 100 gallon propane tank?
  #6
Old 04-26-2018, 11:31 AM
Currently: Not set.
Default Propane.....
Quote:
I am sure it eats up some serious propane. Comes with two 30 gallon tanks. Seems to only make sense to use it to warm the place up, then use the smaller heater to keep it warm....
  #7
Old 04-26-2018, 07:28 PM
Snowmow's Avatar
Currently: Not set.
Default
My burandt trailer will kick out on the limit switch when running a long time. To thaw sleds fast I set the thermostat at 90į and the timer for 3 hrs.
The intake for the furnace isnít adequate. Iím currently installing a intake vent right at the heaters intake... Iím also going to add a couple more directional vents and open up the outlet side of the furnace. The heat in the compartment where the heater is mounted was over heating due to restricted outlet flow and a heated intake flow.
  #8
Old 04-30-2018, 09:19 AM
cowolter cowolter is offline
Currently: Not set.
Basic Member
cowolter is an unknown quantity at this point
Default
You could do a radiant floor heat. They make small DHW heaters for off grid cabins and such. You only get about 80-120 degrees real world temp but if you put in new floor with the aluminum skin and then 1/4 marine plywood over the top it would work well If you could pitch the floor slightly to a one way valve you could drain the water as it melts. You'd loose heating capacity because you'd need a heavy glycol mix but it could work sweet. You'd use about 4-5 amps for a 12 volt pump so it may be impractical for a whole weekend.
Sorry if off topic I'm a heating service tech and this is a project that I'd love to try some day now
  #9
Old 05-07-2018, 12:24 AM
rdr99 rdr99 is online now
Currently: Not set.
Basic Member
rdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond reputerdr99 has a reputation beyond repute
Default
Could plumb into the vehicle cooling system...
  #10
Old 07-15-2018, 02:18 PM
agboy agboy is offline
Currently: Not set.
Basic Member
agboy has a brilliant futureagboy has a brilliant futureagboy has a brilliant futureagboy has a brilliant futureagboy has a brilliant futureagboy has a brilliant futureagboy has a brilliant futureagboy has a brilliant futureagboy has a brilliant futureagboy has a brilliant futureagboy has a brilliant future
  #11
Old 07-15-2018, 03:07 PM
Snowmow's Avatar
Currently: Not set.
Click Here to Register
  #12
Old 07-19-2018, 06:47 PM
Snowmow's Avatar
Currently: Not set.
  #13
Old 08-16-2018, 11:57 AM
summitriders36 summitriders36 is offline
Currently: Not set.
summitriders36 has a reputation beyond reputesummitriders36 has a reputation beyond reputesummitriders36 has a reputation beyond reputesummitriders36 has a reputation beyond reputesummitriders36 has a reputation beyond reputesummitriders36 has a reputation beyond reputesummitriders36 has a reputation beyond reputesummitriders36 has a reputation beyond reputesummitriders36 has a reputation beyond reputesummitriders36 has a reputation beyond reputesummitriders36 has a reputation beyond repute
The Following User Says Thank You to summitriders36 For This Useful Post:
Scott (01-03-2019)
  #14
Old 08-18-2018, 12:36 PM
Snowmow's Avatar
Currently: Not set.
  #15
Old 01-01-2019, 03:37 PM
Snowmow's Avatar
Currently: Not set.
  #16
Old 01-02-2019, 11:32 AM
Snowmow's Avatar
Currently: Not set.
  #17
Old 01-02-2019, 09:47 PM
Currently: Not set.
  #18
Old 01-03-2019, 07:09 AM
Snowmow's Avatar
Currently: Not set.
  #19
Old 01-03-2019, 01:02 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
  #20
Old 01-11-2019, 05:37 PM
Snowmow's Avatar
Currently: Not set.
  #21
Old 01-11-2019, 06:50 PM
Currently: Not set.
  #22
Old 01-12-2019, 09:07 AM
Snowmow's Avatar
Currently: Not set.
Reply
Bookmarks
Tags
logan, trailer heaters
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 3 Sleds in 20' Trails West? Thread Starter — mxman901 Forum — Trucks and Trailers Replies — 3 Last Post — 04-25-2018 10:25 AM
Thread — 20' Trails West. Thread Starter — TURBOXP09 Forum — Trailer/Transport (Swapmeet) Replies — 4 Last Post — 10-25-2016 10:13 PM
Thread — TRAILS WEST TRAILER Thread Starter — Snowedunder Forum — Trucks and Trailers Replies — 9 Last Post — 09-26-2015 12:55 PM
Thread — Trails West Trailers Thread Starter — Dustin_R Forum — Trailer/Transport (Swapmeet) Replies — 31 Last Post — 03-03-2015 10:19 PM
Thread — Trails West GN 28 ft Thread Starter — TheJett29 Forum — Trailer/Transport (Swapmeet) Replies — 16 Last Post — 02-24-2014 08:44 AM
no new posts
