Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 04-21-2018, 08:54 PM
m8magicandmystery's Avatar
m8magicandmystery m8magicandmystery is offline
Currently: [Too Long]
m8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond reputem8magicandmystery has a reputation beyond repute
Default REAL STRANGE PROBLEM
OK folks...hope someone can help me. My engine turns over extremely tough and if im lucky enough to get it started it runs fine all day and starts warm but thats only if im lucky enough to get it started and even in plus 50F she is a monster to turn over...and this problem started a year ago and this unit has very few miles.
I take the belt off...no difference...i take the starter recoil off and wrap a rope around hub and still the same.
I have removed power valves and pipe and still the same.
If i remove one plug at a time still the same but with a plug removed from each cylinder then she rolls easy.
The pistons and cylinders are in awesome shape from what i see through the plugs\powervalves and exhaust.
I have never blown a belt on this machine but is it possible still my crank ended up out of phase..?? any help appreciatted..
__________________
07/m8 141 900 bigbore, Stm valves, Bdx oil delete, adj fuel reg, bumper kit ,Rock rollers, light hub and rotor and post brace, Fastlane no snows and 9 inch 2 wheel kit ,Dayton weights, Shift assist, Timbersled intake, Mtn tamer and Barkbuster with fox evols , Diamond s hood, Boss shorty seat ,Rox risers, Koso egts , a/r , water temp guage .Mod ski's. 911 cover
400 pounds...!!!!!!!
Rate this post: Yes | No
  #2
Old 04-21-2018, 09:43 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Alpha Hawk!
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
Stock primary clutch or P-85?
Lighter clutch makes it harder to pull over.
The Following User Says Thank You to summ8rmk For This Useful Post:
m8magicandmystery (04-23-2018)
  #3
Old 04-22-2018, 03:53 PM
Default
its a stock clutch with the thunder cover upgrades and adjustable weights...all seems fine...its not just hard to turn over...its a real tug and its a chore to get over center...but i have done nothing to change my compression...and she rolls easy with the plugs out...and when it is lucky enough to start it runs fine for hours and my egts and air/fuel and temps are in the zone. I am possibly going to put back the stock recoil hub that bolts onto the mag as i had put on a bdx titanium a couple years back and maybe out of round or something...don;t think its a bent connecting rod as all looks good. Its real strange...pulls hard like pulling up a deep well pump with a 3/4hp pump 100 feet down..
__________________
  #4
Old 04-22-2018, 09:27 PM
MountainCat1 MountainCat1 is online now
Currently: Falling off in the Powder
Basic Member
MountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond reputeMountainCat1 has a reputation beyond repute
Garage
Default
I'd pull the recoil starter housing to see if something is binding or loose. My 2 cts.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to MountainCat1 For This Useful Post:
  #5
Old 04-23-2018, 06:40 AM
mbcat mbcat is offline
Currently: Not set.
Basic Member
mbcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond repute
Default Tough to turn over
You have a bdx oil delete eh? Could the shaft be seizing?i have an old f7/800 rktek with bdx oil delete & out of the blue it almost stops when trying to pull it over. It runs killer though.
The Following User Says Thank You to mbcat For This Useful Post:
  #6
Old 04-23-2018, 02:16 PM
tjcatman tjcatman is offline
Currently: Not set.
tjcatman has a reputation beyond reputetjcatman has a reputation beyond reputetjcatman has a reputation beyond reputetjcatman has a reputation beyond reputetjcatman has a reputation beyond reputetjcatman has a reputation beyond reputetjcatman has a reputation beyond reputetjcatman has a reputation beyond reputetjcatman has a reputation beyond reputetjcatman has a reputation beyond reputetjcatman has a reputation beyond repute
Default oil
What oil are you using? I used to use Amsoil in my sled and it was hard as hell to pull over when first starting. Of course that was a 990 kk and not a 800 but the oil when cold was really gummy. Good luck
The Following User Says Thank You to tjcatman For This Useful Post:
  #7
Old 04-23-2018, 09:42 PM
Default
the oil is fine...and outside temps above 50...i have the recoil off as i thought under load the rope was "wedging" in the pulley..but no such luck..and if the oil delete shaft was an issue i would expect it to turn over tight even with the plugs out but it rolls easy with the plugs out....but with one plug in she rolls hard...both plugs in its a friggen tug of war...oh well i will tinker this weekend some more ...lol..what a mystery though..
__________________
  #8
Old 04-23-2018, 09:57 PM
summ8rmk's Avatar
Default
Easiest way to solve that ........
Trade it in on an Alpha.... lol
m8magicandmystery (04-24-2018)
  #9
Old 04-23-2018, 11:38 PM
89sandman's Avatar
89sandman 89sandman is offline
Currently: Meadow Muffin
89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute
Default
Any sign of excessive fuel coming out of the spark plug holes when you pull it over with the plugs out? Seems like you are getting too much compression and if the float or needle and seat in one or both of the carbs is leaking fuel into the engine when it sits this could raise the compression. I'd do a compression test first thing.
The Following User Says Thank You to 89sandman For This Useful Post:
  #10
Old 04-24-2018, 08:19 AM
Betterview Betterview is offline
Currently: Not set.
Betterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond reputeBetterview has a reputation beyond repute
The Following User Says Thank You to Betterview For This Useful Post:
  #11
Old 04-24-2018, 04:01 PM
01ZRTCAT 01ZRTCAT is offline
Currently: Waiting for snow
01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute01ZRTCAT has a reputation beyond repute
Click Here to Register
  #12
Old 04-24-2018, 09:17 PM
  #13
Old 04-24-2018, 09:19 PM
  #14
Old 04-25-2018, 09:39 AM
snowmobiler snowmobiler is offline
Currently: Not set.
snowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond repute
  #15
Old 04-25-2018, 09:27 PM
  #16
Old 04-29-2018, 11:37 PM
KMMAC KMMAC is offline
Currently: KEEP AN EYE OPEN WHILE YOU SLEEP
KMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond reputeKMMAC has a reputation beyond repute
  #17
Old 04-30-2018, 11:14 AM
Currently: Not set.
Basic Member
  #18
Old 05-03-2018, 09:22 PM
  #19
Old 07-03-2018, 03:22 PM
sledbasher M7 sledbasher M7 is offline
Currently: Not set.
Basic Member
sledbasher M7 has a reputation beyond reputesledbasher M7 has a reputation beyond reputesledbasher M7 has a reputation beyond reputesledbasher M7 has a reputation beyond reputesledbasher M7 has a reputation beyond reputesledbasher M7 has a reputation beyond reputesledbasher M7 has a reputation beyond reputesledbasher M7 has a reputation beyond reputesledbasher M7 has a reputation beyond reputesledbasher M7 has a reputation beyond reputesledbasher M7 has a reputation beyond repute
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — strange problem,, any ideas? Thread Starter — hcrider Forum — Arctic Cat: TURBO Replies — 17 Last Post — 03-13-2013 01:54 PM
Thread — strange problem, 2012 M8 turbo. Thread Starter — bgraff1 Forum — Arctic Cat: TURBO Replies — 25 Last Post — 11-16-2012 11:38 AM
Thread — Strange electrical problem with EGTs Thread Starter — Mike from langley Forum — Arctic Cat: M Series Replies — 3 Last Post — 11-20-2011 09:58 AM
Thread — Strange problem 09 M1000 Thread Starter — El Gringo Forum — Arctic Cat: M Series Replies — 18 Last Post — 04-30-2011 03:11 PM
Thread — strange problem, M1000 Thread Starter — hellclimber Forum — Arctic Cat Replies — 13 Last Post — 01-30-2008 07:50 AM
