Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 04-20-2018, 07:31 AM
Skis Up Skis Up is offline
Currently: Not set.
Basic Member
Skis Up is an unknown quantity at this point
Default New to M1000 replaced Case, reassembled NO Spark
Hello and thanks for any help,
purchased 08 M1000 with broken Case I replaced it..... I reassembled everything but now no Spark.
There is a Ground wire from Recoil attached to Frame
There are 2 connections not used off the ECU is this correct?
1 white 6 wire plug
1 black 2 wire plug
1 When I pull over (everything ON) and when with key off and kill off
the Red light (glow) shows up in the Tach???
2 Fuel pump is creating pressure
3 checked all 4 plugs no spark?
Click image for larger version
Name:	08 M1000.jpg
Rate this post: Yes | No
  #2
Old 04-20-2018, 09:06 AM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
down by the stator you have 2 other plugs they are the crank triggers did you plug them back in?
also when you pulled the fly wheel i have seen guys run the 3 bolts from the puller all the way in, when you do this they hit the windings of the stator and kill it. 5 turns per is all you need.
  #3
Old 04-23-2018, 11:28 AM
mbcat mbcat is online now
Currently: Not set.
Basic Member
mbcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond reputembcat has a reputation beyond repute
Default
But then he wouldn't be getting power to the gauge either. Try disconnect your kill switch
  #4
Old 04-24-2018, 10:26 AM
Currently: Not set.
Basic Member
Default
So I forgot to bolt the 2nd Crank Trigger back in.......
It has 4 plug wires.... DUH>>>
This sled has 80 gram weight's and it is very responsive.....
I also have a 07 1000 crossfire so I already fixed the Major Alignment problem they both have...
This Sled is Going to be fun...
My first trip with it I am going to Rabbit Ear for the End of Year party .... kinda risky for my shakedown run but I'm not scared....
Thanks for Listening
Craig
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Some insight to no spark on m1000 Thread Starter — tylersnowest Forum — Arctic Cat: M Series Replies — 9 Last Post — 02-27-2013 11:52 AM
Thread — 2007 M1000....No Spark Thread Starter — Sno Junkie Forum — Arctic Cat: M Series Replies — 22 Last Post — 01-30-2013 02:33 PM
Thread — Spark Plug - dual spark vs single spark Thread Starter — SledsWest Forum — Fouled Plug Replies — 2 Last Post — 08-19-2012 12:36 AM
Thread — Video on diagnosing no spark, low spark or intermitten spark condition on 1990's Cats Thread Starter — Blaine Forum — Arctic Cat: Powder Special and older Replies — 0 Last Post — 12-29-2009 09:56 PM
Thread — m1000--no spark? Thread Starter — AndyM7 Forum — Arctic Cat Replies — 2 Last Post — 01-11-2009 10:39 PM
no new posts
