Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 04-17-2018, 05:51 PM
kje5e kje5e is offline
Currently: Not set.
Basic Member
kje5e is an unknown quantity at this point
Default 2016 axys silber low compression
2016 axys with 2000 miles on motor. Before the turbo I was fighting rpms. So I went through the common motions while installing the turbo I put new motor mounts in then brought it to the dealer to check tps also asked them to check compression which I found out they never did. New belt all new clutching. Checked ves. Changed clutching all over. Anyway no luck on rpms. So I just rode at 8100 all year. So I did the tps myself and decided I better check compression. Mine is 92 per side at 1500ft. Checked my buddies new 18 and his is 120. Both sleds sitting side by side same gauge. So now that I am aware of this do i just put pistons in or do I do the shim kit and reliability from bikeman or ssi? Thanks sorry about the life story
Rate this post: Yes | No
  #2
Old 04-18-2018, 08:31 AM
AKFULLTHROTTLE's Avatar
AKFULLTHROTTLE AKFULLTHROTTLE is offline
Currently: Waiting for my Polaris 850!
AKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond repute
Default
Replace with stock!!! Do not run one of those kits, if you need cylinder work give Indy Specialty a call as they can sell you a complete kit.
__________________
Full Throttle Customs
Alaska Silber Turbos Dealer
http://www.silberturbos.com/
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 04-18-2018, 10:43 AM
JJ_0909 JJ_0909 is offline
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
Default
Quote:
At Silber we like stock Pistons. That said, we've had a few customers go to Kelsey (KelseyTek - two stroke heads) and have great success. He's got a complete turbo package that seems to work just fine with our kit. Have a few customers who have put 4000 miles on his top end...WOW.
  #4
Old 04-18-2018, 08:14 PM
Sage Crusher's Avatar
Sage Crusher Sage Crusher is offline
Currently: Power Clawing the Axys....
Sage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond repute
Default
Seems like we are having better luck running 2015 pro pistons than the stock Axys Pistons...
Many on here will agree.
__________________
Dealers for:
Silber Turbos.
GGB Exhaust.
TKI.
F-N-I.
K-Mod.
2016 Axys 3" 162 P/C Track W/Silber Turbo/K-Mod Gen III/TKI
  #5
Old 04-19-2018, 08:32 AM
madmax's Avatar
madmax madmax is offline
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
Default
MY rpm problems went away after I started using the gates belt recommended by TRS.
I’ve also had very good success with the RKT Polaris products
__________________
19’ Alpha 800 turbo
18, MC 153 stock
18’ axys 155 stock
18' axis 163 stock
  #6
Old 04-19-2018, 01:09 PM
BD-Xtreme's Avatar
BD-Xtreme BD-Xtreme is offline
Currently: Not set.
BD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond repute
Default Polaris Pistons
Say what you want, but we have sold a lot of our durability piston kits to people using turbo kits. Boondocker and Silber. Not just using pump gas either, for motors running higher boost levels with race fuel.
We have even done our 860 big bore with the Silber turbo kit. Our 860 uses the durability kits style pistons too, taller version with the spacer plate.
There are plenty of good options for pistons. But for sure don't disregard our SSI Durability piston kits as a great option.
http://www.bd-xtreme.com/index.php?i...roller=product
Click image for larger version
Name:	durability piston kit.jpg
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Silber turbo install? 2016 Axys Thread Starter — rockin rmk Forum — Polaris: TURBO Replies — 7 Last Post — 02-19-2018 08:12 PM
Thread — 2016 Axys 155 w/ Silber Turbo and Low Miles Thread Starter — 800xtreme Forum — Polaris (Swapmeet) Replies — 3 Last Post — 07-09-2017 07:59 PM
Thread — 2016 Axys 800 compression? Thread Starter — snosumitcsr Forum — Polaris: AXYS Replies — 10 Last Post — 03-09-2017 06:37 PM
Thread — 2016 Silber axys on pump gas Thread Starter — Coldestwinter1 Forum — Polaris: TURBO Replies — 1 Last Post — 01-08-2017 11:10 AM
no new posts
