Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 04-16-2018, 07:58 PM
mtncat600 mtncat600 is offline
Currently: Not set.
Basic Member
mtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond reputemtncat600 has a reputation beyond repute
Default 2017 m8000 primary spring change?
wanting to change primary spring in primary
clutch. it appears i can just remove cover put in new spring
or does the whole clutch have to come off? thanks
Rate this post: Yes | No
  #2
Old 04-16-2018, 08:17 PM
Pow-Shredder's Avatar
Pow-Shredder Pow-Shredder is online now
Currently: Waiting for the pow
Pow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond reputePow-Shredder has a reputation beyond repute
Default
You can do it on the sled. Easier off the sled for sure. But it can be done on the sled.
__________________
18 Arctic Cat Mountain Cat, TKI Belt Drive, SLP Exhaust, Grippers
  #3
Old 04-17-2018, 05:54 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
Default
Just the outer cover is all you need to remove. It should be marked with a X make sure it lines up with the other marks. This is for balancing purposes. It is under pressure so remove it carefully and try to keep it straight as possible on the shaft.I remove every other bolt then the last 3 remove evenly and hold spring pressure by hand for final removal. The bolt torque for the cover is 120 in-lb.
The Following 2 Users Say Thank You to Old & slow For This Useful Post:
mtncat600 (04-17-2018), Sledbrain2 (04-17-2018)
  #4
Old 04-17-2018, 07:22 PM
Allseasons Allseasons is offline
Currently: Counting the days
Allseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond repute
Default
Emphasis on inch lbs. Not foot lbs ha.
  #5
Old 04-17-2018, 07:42 PM
Snowmow's Avatar
Snowmow Snowmow is online now
Currently: Not set.
Snowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond repute
Quote:
120 inch lbs
10 ft lbs.
13.56 newton meters
Let’s not over think this.
Just get em tight with a 1/4” ratchet. That’s good nuf
The Following 2 Users Say Thank You to Snowmow For This Useful Post:
Allseasons (04-17-2018), kiliki (04-17-2018)
  #6
Old 04-18-2018, 12:16 AM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
i think i did 8 foot pounds with on my old a$$ wrench. iirc it took about 6 pounds to get them to back off so...
i used blue loctite.
id clamp it up somehow next time, shes spring loaded for sure!
careful how you thread them in on re-assembly, i could see somebody doing this all wrong.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — primary spring change Thread Starter — kylant Forum — Arctic Cat: Proclimb M Replies — 8 Last Post — 01-09-2014 04:35 PM
Thread — how to change the primary spring Thread Starter — ullose272 Forum — Arctic Cat: M Series Replies — 10 Last Post — 09-09-2010 04:11 PM
Thread — how to change primary spring Thread Starter — nunuexpress Forum — Polaris: IQ Replies — 10 Last Post — 02-18-2010 07:53 PM
Thread — M7 primary spring change Thread Starter — bigjb Forum — Arctic Cat: M Series Replies — 6 Last Post — 01-21-2009 07:11 PM
Thread — How to change primary spring on m7 Thread Starter — ReTodd Forum — Arctic Cat Replies — 4 Last Post — 12-19-2007 09:21 PM
no new posts
