Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 04-13-2018, 03:19 PM
ACWill530 ACWill530 is online now
Currently: Not set.
ACWill530 has a reputation beyond reputeACWill530 has a reputation beyond reputeACWill530 has a reputation beyond reputeACWill530 has a reputation beyond reputeACWill530 has a reputation beyond reputeACWill530 has a reputation beyond reputeACWill530 has a reputation beyond reputeACWill530 has a reputation beyond reputeACWill530 has a reputation beyond reputeACWill530 has a reputation beyond reputeACWill530 has a reputation beyond repute
Default Diamond drive destruction
Blew up my diamond drive. Looking at ordering a unit from Bdx. Anyone have any experience with the Bdx unit? Will it hold up any better on my turbo sled?
Sent from my SM-G950U using Tapatalk
Rate this post: Yes | No
  #2
Old 04-13-2018, 08:38 PM
Coldfinger's Avatar
Coldfinger Coldfinger is offline
Currently: Not set.
Coldfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond reputeColdfinger has a reputation beyond repute
Default
No experience with aftermarket DD units.
Just curious what yr, miles, oil changed each season, 5203 sealed bearing? Was the shoulder machined back or the trackshaft shortened prior to installing the double row bearing?
Sounds like it is turboed. Guessing M8. How many miles since installing turbo?
  #3
Old 04-13-2018, 08:59 PM
Currently: Not set.
Default
Sled is a 2011 M8 HCR with a boondocker pump gas turbo. I got it early this season, had 2300 miles on it, turbo has been on since new. I put about 500 miles on it this year and broke it last weekend.
I changed the fluid in it right after I got it before the first ride. Does not appear to have had the bearing upgrade. I was planning on looking into it during this off season...
I'm gonna try the Bdx drive and rebuild this one as a spare over the summer. I got a quote on all the parts to rebuild from arctic cat and the Bdx drive with track shaft is almost the same price.
  #4
Old 04-14-2018, 09:39 AM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
looks like it did have the double row bearing in it. you can see the race on the end of the transfer gear. now if it was just put on without taking 1.5mm off the shoulder of the gear then you will have this problem.
the bdx is a better version and you have to do it with the bdx drive shaft.
  #5
Old 04-15-2018, 01:09 AM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
If money is a factor, find a used stock unit and replace bearings. Funny thing about the diamond drive is that the gears are very hefty...the bearings have side loading and are only radial bearings...which dont take that load well. Check out diamond drive bearing thread on M series section...even double rows go with time. And, yes, your year requires 1.5mm off the end of the double row bearing shaft. Yes, BDX was known for great durability and quality. I know a few that used them in 1000 turbos...solid. But a PG 800 doesnt need that. My 09 PG 800 turbo jas stock diamond drive...just did bearing at 1200 miles...race was coming apart. And looking at your failure, the stripped gear is on the double row...likely came apart and allowed too much tooth clwarance...gear chew situation.
  #6
Old 04-15-2018, 01:14 AM
jim jim is offline
Default
BTW, thanks for the great diamond drive yard sale pics...that has gotta be a record blow up.
The Following User Says Thank You to jim For This Useful Post:
ACWill530 (04-15-2018)
  #7
Old 04-15-2018, 12:21 PM
BradM8 BradM8 is offline
Currently: Not set.
BradM8 has a reputation beyond reputeBradM8 has a reputation beyond reputeBradM8 has a reputation beyond reputeBradM8 has a reputation beyond reputeBradM8 has a reputation beyond reputeBradM8 has a reputation beyond reputeBradM8 has a reputation beyond reputeBradM8 has a reputation beyond reputeBradM8 has a reputation beyond reputeBradM8 has a reputation beyond reputeBradM8 has a reputation beyond repute
Default
Proper way is to measure if the tunnel is too narrow and puts side load on the diamond drive assembly. This was common on the 09-11 M's. I cut 0.120" total out of the driveshaft collars to make it good. People have cut the shoulder of the transfer gear but it is taking up the difference in the wrong spot and then you are not getting 100% gear contact on it. This is something that would be more of an issue if you have a done up turbo. This has been beaten to death on the forums and has alot of info if you do some searches. Also from my understanding BDX were the originators of the diamond drive and their products are way better than the production cat units.
  #8
Old 04-15-2018, 10:12 PM
Currently: Not set.
Default
I was surprised at how much metal ended up in that case. It went out on me mid hill climb and it was a long day getting it back to the trailer. Glad you enjoyed the yard sale pics...
I went ahead and ordered a bdx drive and their track shaft. Hopefully they have worked out the bearing issue and it's a drop in unit, no worrying about machining anything or swapping out ****ty bearings.
From what they told me the Bdx unit is a little lighter and holds more fluid. Looks to be a more stout unit with the option for their high torque gear set.
I'll post some pics of the new drive, should be in on Wednesday.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — RK TEK diamond drive clutch kit (fits diamond drive cats) Thread Starter — Bocephus Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 12 Last Post — 09-17-2013 06:13 PM
Thread — Black diamond diamond lite drive shaft Thread Starter — Zbros Racing1 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 2 Last Post — 11-07-2012 08:53 AM
Thread — F/S black diamond extreme diamond drive bearing kit 07-up with reverse brand new!!!!! Thread Starter — hllrazor Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 11-21-2010 09:05 PM
Thread — 2010 Black Diamond Diamond Drive Pro Lite Series/ COMPLETE Thread Starter — Polaris 711 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 4 Last Post — 10-19-2010 02:20 PM
Thread — The US has successfully completed testing of it's new weapon of mass destruction Thread Starter — gutterlicker Forum — Fouled Plug Replies — 4 Last Post — 09-25-2008 06:45 PM
no new posts
