Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 04-12-2018, 10:23 PM
tarpus91 tarpus91 is offline
Currently: Not set.
Basic Member
tarpus91 is an unknown quantity at this point
Default 2009 rmk 700 diy motor mount bolt repair
I was able to fix my broken front left motor mount bolt. It took a while to get the broken bolt tail out of the nutplate. Took the boot off the left steering link, but still had to cut a hole in some nearby sheet metal in order to get a vice grip on the bolt. Had to break it loose from the thread locker. Pictures attached.
I bought a grade 9 bolt locally. It was 2.5" long, so I trimmed it a little. Then, in order to get it threaded back into the nutplate, I had to grind the tip into a semi-pointed feature. This was needed to line up the parts in the stackup. I was able to tighten the bolt with a 9/16" flex head ratchet wrench. Wrapped some safety wire around the wrench so that it didn't drop under the motor. Didn't need to remove the exhaust or the drive clutch.
Click image for larger version
Name:	2018-04-08 14.25.03.jpg
ID:	295391   Click image for larger version
Name:	2018-04-08 13.59.21s.JPG
ID:	295392   Click image for larger version
Name:	2018-04-08 13.59.45s.JPG
Rate this post: Yes | No
The Following User Says Thank You to tarpus91 For This Useful Post:
retiredpop (04-13-2018)
Reply
Bookmarks
Tags
motor mount bolt
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — front motor mount bolt? Thread Starter — trappersnapper Forum — Arctic Cat: M Series Replies — 0 Last Post — 10-22-2013 08:37 PM
Thread — broken motor mount bolt! Thread Starter — tylbz Forum — Ski-Doo: XM Sleds Replies — 3 Last Post — 03-18-2013 05:35 PM
Thread — Broken motor mount bolt Thread Starter — renegade18 Forum — Polaris: Pro-Ride Replies — 4 Last Post — 03-13-2011 06:44 AM
Thread — 900 motor mount bolt Thread Starter — SnowPro Forum — Polaris: 900 Replies — 15 Last Post — 12-11-2009 08:17 AM
Thread — 2009 rmk motor mount bolts Thread Starter — Switchback06 Forum — Polaris Replies — 1 Last Post — 08-27-2009 06:15 PM
no new posts
