Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 04-10-2018, 08:52 PM
kidwoo's Avatar
kidwoo kidwoo is online now
Currently: schmurrently
kidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond reputekidwoo has a reputation beyond repute
Default Longer tunnel cooler for 2014+ sleds?
It looks like like AC only sells the full assembly and they're one gigantic piece of non modular aluminum that involves a full tear down.
Is there anyway to get an extended cooler on these things? I thought about just putting one on from a 141 XF but having to completely tear down the front of the tunnel doesn't sound too inviting. This shouldn't be that hard. Is there a clean way to cut into the existing mid positioned cooler to add an extension?
And spare me the 'get off the trails' BS, it's april.
Got some friends with some ascender sleds that need it more than I do apparently.
__________________
www.sierrasnowmobilefoundation.com
Your loud can sounds stupid
Rate this post: Yes | No
  #2
Old 04-10-2018, 09:03 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
2 sets of scratchers
And add water wetter to the coolant
  #3
Old 04-10-2018, 09:04 PM
kidwoo's Avatar
Default
Quote:
I looked and can't figure out a stout place to mount them.
__________________
  #4
Old 04-10-2018, 09:06 PM
Currently: Not set.
Garage
Default
Some of the old school sets you could mount to the skis
  #5
Old 04-10-2018, 09:09 PM
kidwoo's Avatar
Default
Was trying to avoid the ski scratchers.
Just wondering if there was a sane way to tap into the existing cooler.
If not I guess I could mount some second scratchers with a backplate. That's kind of cheesy though.
__________________
  #6
Old 04-10-2018, 09:15 PM
XCaSSAULT's Avatar
XCaSSAULT XCaSSAULT is offline
Currently: Go MN Wild!
XCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond repute
Default
I’m real interested in more cooling as well. I had a poo 800 that ran 130-160f and did a bypass t-stat system that put it down to 104-118f which the motor liked soooo much more. My 15 m8000 runs 130-160f and I know that’s range is fine blah blah. But cooler temps are flat out better for performance and reliability.
Looking at the coolant system diagram everything is tight. Could possibly cut somthing in on the hose that goes to the over flow(red arrow) but to what and how well it would work???
If your wanting to keep temps under 160f then scratchers would do it or some have tried the bolt through the ski thing
Click image for larger version
  #7
Old 04-10-2018, 10:19 PM
sno*jet sno*jet is online now
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
youguys running a full stock flap?
just curious, heard that helps. i run a shorty flap and have no problems before my polaris buddies do, so everytime we stop for them i kick a little snow in the skid and also run no goggle bag in spring, lets more heat out
  #8
Old 04-10-2018, 10:28 PM
kidwoo's Avatar
Default
Mostly a full flap. Just cut off the bottom part with the logo. That little shouldn't matter that much.
__________________
  #9
Old 04-11-2018, 05:23 AM
Cat00's Avatar
Cat00 Cat00 is online now
Currently: Not set.
Cat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond repute
Default
Replacing the cooler isn't as bad as you would think. The book says it should take 5 hours. The last one I did took me around 6 hours. If you had two guys that new what they were doing you could prob have it done in 4 hours or less
The Following User Says Thank You to Cat00 For This Useful Post:
kidwoo (04-11-2018)
  #10
Old 04-11-2018, 07:39 AM
XCaSSAULT's Avatar
  #11
Old 04-11-2018, 07:51 AM
Cat00's Avatar
Currently: Not set.
Click Here to Register
  #12
Old 04-11-2018, 09:19 AM
kidwoo's Avatar
  #13
Old 04-11-2018, 09:49 AM
Cat00's Avatar
Currently: Not set.
kidwoo (04-11-2018)
  #14
Old 04-11-2018, 12:46 PM
Currently: Not set.
The Following User Says Thank You to sno*jet For This Useful Post:
kidwoo (04-11-2018)
  #15
Old 04-11-2018, 05:02 PM
eldereldo eldereldo is online now
Currently: Not set.
eldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond repute
  #16
Old 04-11-2018, 05:09 PM
kidwoo's Avatar
  #17
Old 04-11-2018, 06:13 PM
MTN_VIPER's Avatar
MTN_VIPER MTN_VIPER is online now
Currently: Making roll-over valve kits since 2008
MTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond repute
  #18
Old 04-12-2018, 06:42 PM
kidwoo's Avatar
  #19
Old 04-12-2018, 07:02 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Stirring pots
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
  #20
Old 04-12-2018, 07:03 PM
Woody67's Avatar
Woody67 Woody67 is offline
Currently: Digging the Alpha One
Woody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond reputeWoody67 has a reputation beyond repute
Garage
The Following 2 Users Say Thank You to Woody67 For This Useful Post:
Bills R.E. Repair (04-14-2018), MTN_VIPER (04-12-2018)
  #21
Old 04-24-2018, 08:34 AM
bgraff1's Avatar
bgraff1 bgraff1 is offline
Currently: patiently waiting for snow
bgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond repute
  #22
Old 04-24-2018, 06:44 PM
kidwoo's Avatar
  #23
Old 04-25-2018, 06:07 PM
Currently: Not set.
  #24
Old 04-26-2018, 07:59 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
  #25
Old 04-27-2018, 06:45 AM
High Country's Avatar
High Country High Country is offline
Currently: my Alpha One is here
High Country has a reputation beyond reputeHigh Country has a reputation beyond reputeHigh Country has a reputation beyond reputeHigh Country has a reputation beyond reputeHigh Country has a reputation beyond reputeHigh Country has a reputation beyond reputeHigh Country has a reputation beyond reputeHigh Country has a reputation beyond reputeHigh Country has a reputation beyond reputeHigh Country has a reputation beyond reputeHigh Country has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — WTB: MTX tunnel cooler or aftermarket tunnel cooler Thread Starter — Phyxius Forum — WTB (Swapmeet) Replies — 2 Last Post — 11-16-2012 02:02 PM
Thread — U cooler or tunnel cooler wanted Thread Starter — lshobie Forum — WTB (Swapmeet) Replies — 8 Last Post — 04-16-2012 11:05 PM
Thread — Running Board Coolers, Rear Tunnel cooler, and front cooler Thread Starter — underdogg_ks7 Forum — Misc. Sled Parts Replies — 1 Last Post — 01-17-2012 12:52 AM
Thread — 08 mseries 153 rear half of tunnel, snowflap, tail light, cooler, and tunnel edges Thread Starter — hd4rob Forum — Chassis/Tunnel (Swapmeet) Replies — 0 Last Post — 10-04-2010 03:51 PM
Thread — Keep those clutches cooler and running longer with vent kits Thread Starter — 1100Cat Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 01-04-2009 09:01 PM
no new posts
