Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 04-10-2018, 03:30 PM
JJ_0909 JJ_0909 is offline
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
Default Season isn't over yet! Silber 850 in the "Tetons"
Just a quick video from yesterday. Few hours of riding while I played hooky from work. Here is to a few more late season storms!
https://www.facebook.com/SilberTurbo...5859543840198/
2017 G4 165 3"
2018 Gearing
2019 Silber clutching
2019 Silber exhaust setup
2018 Tom's setup
B&M Boards
SLP Mohawk Skis
5 out of 5 members found this post helpful. Rate this post: Yes | No
The Following 5 Users Say Thank You to JJ_0909 For This Useful Post:
christopher (04-12-2018), Mark's RMK (04-12-2018), mountainhorse (04-11-2018), NorthMNSledder (04-11-2018), sledsrock (04-14-2018)
  #2
Old 04-10-2018, 08:54 PM
catmanm7 catmanm7 is offline
Currently: Not set.
catmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond repute
Default
What is the 2019 clutching?
  #3
Old 04-11-2018, 08:27 AM
Currently: Not set.
Default
Quote:
Different ramps.
We've been playing with the helix we've got vs stock as well. Helix in the 18 kit was absolutely better on belts, but depending on boost/conditions, some found the straight 40 to bump them up in track speed (not everyone). This sled is running the 43/47 helix, 18 secondary spring (from Silber), prototype ramps and a 200/340 primary spring (only cause I was looking to bump up engagement - personal preference).
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #4
Old 04-11-2018, 10:21 AM
Chadly's Avatar
Chadly Chadly is offline
Currently: Not set.
Chadly has disabled reputation
Default
Sounds like you have a boost leak... That is the wimpiest sounding blow off I have ever heard!
  #5
Old 04-11-2018, 10:39 AM
Currently: Not set.
Default
Quote:
Ha.
For a number of reasons, "no".
For starters, there is no blow off valve. What you are hearing is turbo flutter or compressor surge. With the new exhaust, it might mute it a bit, but this is also a byproduct of where the GoPro was and how I adjust sound in post.
Second, logs show MAP constant with wastegate spring when barometric pressure is subtracted.
Third, my clutching is right at 8,000 - when considering what I'm throwing (weights, springs, helix) this is a good indication I have no leak
Fourth, boost leak generally shows itself down low too (sled is slow to build boost and the motor will load up)
Fifth track speed indicates "no leak" as well (50-60)
In any case, I want to see your big bad blowoff valve! Post up a video my man!
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 3 Users Say Thank You to JJ_0909 For This Useful Post:
05900 (04-12-2018), christopher (04-12-2018), mountainhorse (04-11-2018)
  #6
Old 04-11-2018, 12:45 PM
turboless terry's Avatar
turboless terry turboless terry is online now
Currently: Not set.
turboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond repute
Default
He would show it to you if it ran.
3 out of 3 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to turboless terry For This Useful Post:
rulonjj (04-11-2018)
  #7
Old 04-11-2018, 02:19 PM
Currently: Not set.
Default
Quote:
I really would love to see some video of Chadly tearing it up. He sounds like an ahhhmazing rider.
  #8
Old 04-11-2018, 02:25 PM
NorthMNSledder's Avatar
NorthMNSledder NorthMNSledder is offline
Currently: The person Elky looks up too.
NorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond reputeNorthMNSledder has a reputation beyond repute
Default
Quote:
This would be pretty good to see.........
Thanks for this video, looks like a fun place to play!!
  #9
Old 04-11-2018, 03:03 PM
Currently: Not set.
Default
Thx!
Never thought I'd be lucky enough to live 1 mile from the trailhead to a spot like that.
  #10
Old 04-11-2018, 07:19 PM
Currently: Not set.
  #11
Old 04-11-2018, 08:33 PM
Chadly's Avatar
Currently: Not set.
Click Here to Register
  #12
Old 04-11-2018, 09:02 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
  #13
Old 04-12-2018, 08:03 AM
Currently: Not set.
  #14
Old 04-12-2018, 08:16 AM
Currently: Not set.
  #15
Old 04-12-2018, 11:35 AM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is online now
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
The Following 2 Users Say Thank You to Wheel House Motorsports For This Useful Post:
christopher (04-12-2018), JJ_0909 (01-11-2019)
  #16
Old 04-12-2018, 02:32 PM
Currently: Not set.
  #17
Old 04-12-2018, 08:11 PM
live2beel live2beel is online now
Currently: Not set.
live2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond repute
  #18
Old 04-13-2018, 07:31 AM
Currently: Not set.
  #19
Old 04-13-2018, 07:10 PM
pepperhouse pepperhouse is offline
Currently: Not set.
pepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond reputepepperhouse has a reputation beyond repute
  #20
Old 04-14-2018, 01:55 PM
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Gen 4 850 skid and track 3"x165" zero miles Thread Starter — HardKor Forum — Suspension/Shocks (Swapmeet) Replies — 9 Last Post — 01-26-2017 10:39 AM
Thread — Gen 4 850 skid and track 3"x165" zero miles Thread Starter — HardKor Forum — Tracks (Swapmeet) Replies — 3 Last Post — 01-26-2017 09:45 AM
Thread — After nearly a full season of riding. Is a 153-154"" or a 162"-163" preferable? Thread Starter — Frostbite Forum — Mountain/Deep Powder Replies — 54 Last Post — 09-05-2012 05:17 PM
Thread — "When Halfway Up Isn't An Option..." Thread Starter — treemagnet03 Forum — Polaris: Pro-Ride Replies — 7 Last Post — 01-20-2011 04:41 PM
Thread — 1st Snow Of The Season In the Tetons Thread Starter — Original Tetonice Forum — Mountain/Deep Powder Replies — 0 Last Post — 09-01-2008 08:47 PM
no new posts
