Upgrade to Premium
Reply
  #1
Old 04-10-2018, 12:34 PM
BD-Xtreme's Avatar
BD-Xtreme BD-Xtreme is offline
Currently: Not set.
BD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond repute
Default SILBER TURBO SNOWCHECK
SNOWCHECK YOUR NEW SILBER TURBO FOR YOUR ARCTIC CAT 8000 DSI FROM BDX!!!
SILBER TURBOS SPENT THIS WHOLE SEASON TESTING AND TUNING AND PERFECTING THIS KIT. ITS THE ONLY KIT THAT OFFERS A REFLASH OF THE STOCK ECU FOR PRECISE TUNING. SNOW CHECK PRICE FOR THE TURBO KIT WITH CLUTCHING IS ONLY $2995!! ONLY $500 DOWN NOW. FREE SHIPPING IN THE LOWER 48 STATES!!
(though we can ship anywhere)
Kit Highlights
•Fueling: We introduced our proprietary ECU reflash on the 4th generation Pro RMK kit and have further refined it for the Arctic Cat CTEC2. Reflashing the sled's stock ECU with a custom map specific to our turbo kit is the game changing technology that has brought turbo reliability and performance to never before seen levels. With the Silber kit there is no monkeying around with control boxes or worrying about punching buttons as you change elevation, temperature, snow conditions or even boost levels. Our custom, dynamic map brings multiple variables into account and adjusts parameters to keep your sled running without a hiccup and without touching a thing. Pull. Go. Have fun.
•Engine Protection: We are the only manufacturer that has the capability to turn the oil pump up to allow your engine proper lubrication while running a turbo. As additional fuel and air is run through the motor, oil demand is heightened. The stock ECU is designed to lessen oiling as air thins out (you rise in elevation and theoretically load drops). Our propriety tuning software allows us to increase oil volume regardless of air pressure to provide adequate protection for the engine. Remember, pre mixing gas is not an option with these fuel injected motors as the lubrication via fuel will make it to the key areas of the motor.
•Turbo: The heart of any turbo kit is the turbo setup itself. Our kit includes an internal wastegate kPa ceramic ball bearing turbo specific to the 800cc two stroke engine size plumbed with a recirculating BOV. This means you'll build boost quickly, smoothly and keep your turbo spooled incredibly well when on/off the throttle in tighter more technical terrain.
•No Cut Installation: Our system is designed to quickly install without modification of the sled. Our exhaust system is constructed of 304 SS and fully polished. The system was designed to enhance performance while minimizing noise. The exhaust exits the OEM location in the belly pan allowing for simple installation.
•Silicone Charge air is fed to the engine through a custom molded silicone charge tube. We use custom silicone because it’s the smoothest flowing, doesn’t conduct heat like aluminum and allows for an OEM like fit.
•Intake: The intake air is routed to the turbocharger through plastic cold air intake. The custom high impact modular pllastic intake is feather light and adapts seamlessly to the OEM hood. This allows for cold air to be drawn through the stock hood vents
http://www.bd-xtreme.com/index.php?i...roller=product
Click image for larger version
Name:	Silber Cat 8000 Dsi turbo.jpg
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to BD-Xtreme For This Useful Post:
Old & slow (04-11-2018), ranger12 (04-12-2018)
  #2
Old 08-07-2018, 08:57 PM
snopro11's Avatar
snopro11 snopro11 is online now
Currently: Alpha One!
snopro11 has a reputation beyond reputesnopro11 has a reputation beyond reputesnopro11 has a reputation beyond reputesnopro11 has a reputation beyond reputesnopro11 has a reputation beyond reputesnopro11 has a reputation beyond reputesnopro11 has a reputation beyond reputesnopro11 has a reputation beyond reputesnopro11 has a reputation beyond reputesnopro11 has a reputation beyond reputesnopro11 has a reputation beyond repute
Default
Any haydays specials?
  #3
Old 08-10-2018, 02:43 PM
BD-Xtreme's Avatar
Currently: Not set.
Default silber turbo specials
Yes. I will PM you
Or anyone else, PM me too
__________________
www.BD-XREME.com
http://www.speedshopinc.com
www.SPEEDSHOPINC.com
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2017 Silber SnowCheck Program Thread Starter — Boston Racing Forum — Polaris: TURBO Replies — 7 Last Post — 04-10-2016 12:28 AM
Thread — 2014 Silber Turbo Snowcheck / Groupbuy Thread Starter — Boston Racing Forum — Turbos/Superchargers (Swapmeet) Replies — 20 Last Post — 09-07-2013 03:09 PM
Thread — 2013 Silber Snowcheck program Thread Starter — Boston Racing Forum — Polaris: TURBO Replies — 12 Last Post — 07-13-2012 12:11 PM
Thread — Silber snowcheck orders.. Thread Starter — 800poodragon Forum — Polaris: TURBO Replies — 20 Last Post — 12-20-2011 01:10 PM
Thread — Silber 2012 snowcheck Thread Starter — m1kflyingtiger Forum — Polaris: TURBO Replies — 77 Last Post — 09-17-2011 11:19 AM
no new posts
