Upgrade to Premium
Reply
  #1
Old 04-10-2018, 08:23 AM
galljr13 galljr13 is offline
Currently: Not set.
Basic Member
galljr13 has a reputation beyond reputegalljr13 has a reputation beyond reputegalljr13 has a reputation beyond reputegalljr13 has a reputation beyond reputegalljr13 has a reputation beyond reputegalljr13 has a reputation beyond reputegalljr13 has a reputation beyond reputegalljr13 has a reputation beyond reputegalljr13 has a reputation beyond reputegalljr13 has a reputation beyond reputegalljr13 has a reputation beyond repute
Default Tired of Sloppy Steering
Is there a good fix for this? I have replaced the piece at the bottom of the steering shaft every year I have owned this sled (3x). Last part I put in was supposed to be a new HD version. Feels like I have 45 degrees of play now after my last ride. About 600 miles on new part.
Please tell me someone has some out with a solution!?
Rate this post: Yes | No
  #2
Old 04-10-2018, 03:20 PM
eldereldo eldereldo is offline
Currently: Not set.
eldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond repute
Default
I agree, no matter how tight it is at the start of the year, by the end it always seems to be loose.
I have found that the lower nut on the steering shaft can back off, that gives a lot of slop and over time can put more torque on the bracket and crack it.
Other than that, the upper bushings seem to wear very fast, these guys sell upgraded ones. http://www.canadasledparts.com/produ...ring-bushings/
If you have the adjustable post it wears internally, replace it with a fixed post.
Finally, there seems to be a bit of slop in every Heim joint, and since there are a lot of them that’s introduces play as well. I think I am more going to look into whether I can find some better quality fittings to replace the stock ones.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to eldereldo For This Useful Post:
slomo (04-10-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Does your Proclimb have a sloppy steering post? Thread Starter — RACINSTATION Forum — Arctic Cat: Proclimb M Replies — 14 Last Post — 10-05-2013 05:41 PM
Thread — Sloppy steering post Thread Starter — J.Jensen Forum — Polaris: 900 Replies — 4 Last Post — 05-27-2010 09:19 PM
Thread — Sloppy steering Thread Starter — redneckj Forum — Ski-Doo: S-2000 and older Replies — 7 Last Post — 11-22-2009 04:16 PM
Thread — sloppy telescopic steering fix. Thread Starter — sheffield Forum — Arctic Cat: M Series Replies — 3 Last Post — 10-06-2009 07:24 AM
Thread — Sloppy steering Thread Starter — madmin Forum — Ski-Doo Replies — 3 Last Post — 03-02-2009 10:29 PM
