Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 04-09-2018, 09:41 PM
BJorgy17 BJorgy17 is offline
Currently: Riding every weekend possible
Basic Member
BJorgy17 has a reputation beyond reputeBJorgy17 has a reputation beyond reputeBJorgy17 has a reputation beyond reputeBJorgy17 has a reputation beyond reputeBJorgy17 has a reputation beyond reputeBJorgy17 has a reputation beyond reputeBJorgy17 has a reputation beyond reputeBJorgy17 has a reputation beyond reputeBJorgy17 has a reputation beyond reputeBJorgy17 has a reputation beyond reputeBJorgy17 has a reputation beyond repute
Default DET at various RPM
In Sicamous, BC this weekend my 15 pro (stock except for clutching, gear down kit and fix kit 2000 miles ago) hit DET 13 times on the PTO side and 2 times on the MAG side. Happened on the trail, in the trees and in the alpine, typically around 7000 rpm with the sled running at normal operating temp of 125. Checked all the spark plug wires and caps, they look good. Replace plugs, replaced fuel filter and am still hitting DET. Has anyone experienced this and found what was causing the issue. My thoughts are
- Loose/smooth belt causing clutch to over rev. Unlikely
- Bad fuel, however I put about 60 litres of shell premium in this weekend and still an issue so its unlikely as well
- Sticky exhaust valves or broken VES springs?
- Fuel Pump?
- Faulty DET sensor? Havent heard of these being an issue in 13-15 pros
Please let me know what you think or if I am missing anything. Thanks
Rate this post: Yes | No
  #2
Old 04-10-2018, 11:49 AM
TRS's Avatar
TRS TRS is online now
Currently: Waiting for winter
TRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond reputeTRS has a reputation beyond repute
Default
I would start simple, inspect EV components, clean your ex valves and the port in the cylinder.
  #3
Old 04-10-2018, 12:29 PM
Spaarky's Avatar
Spaarky Spaarky is online now
Currently: Moved Into Maximum Security Cell
Spaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond repute
Default
pipe rub? or det sensor torque are a couple other easy ones.
  #4
Old 04-10-2018, 12:55 PM
gtwitch gtwitch is online now
Currently: Not set.
gtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond repute
Default
Had same issues on my PRO 11 and was fuel filter and that is all I changed and DET went away and has not come back in over a year of hard riding!! Go the easy route first!
gtwitch in wyoming
  #5
Old 04-10-2018, 07:16 PM
Basic Member
Default
Quote:
gtwitch in wyoming
Fuel filter has been changed. Unfortunately it is not that one.
  #6
Old 04-10-2018, 07:25 PM
Basic Member
Default
Quote:
Can I take the sensor off and retorque without loosing coolant?
  #7
Old 04-10-2018, 07:35 PM
cascadesnowjunky's Avatar
cascadesnowjunky cascadesnowjunky is online now
Currently: doing the snow dance
cascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond repute
Default
Could have been as simple as bad gas also, maybe some moisture got in their tanks and you were a victim.
  #8
Old 04-10-2018, 08:53 PM
Basic Member
Default
Quote:
I thought about that too...I've gone through about a tank and a half of fuel from two different fuel stations since it started doing it. I think i can rule out fuel...
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #9
Old 08-17-2018, 03:57 PM
PSI 800 PSI 800 is offline
Currently: waiting to tear up the mtns
Basic Member
PSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond reputePSI 800 has a reputation beyond repute
Default
I would check your motor mounts, rubber bumpers for your exhaust, check your exhaust to see if maybe something is loose inside, fuel filter and fuel pump. you can remove and retorque the knock sensor with out losing coolant. fuel injectors could be acting up which was the case with my 15 Pro last year.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — High RPM DET Thread Starter — Vincenthdfan Forum — Polaris: Pro-Ride Replies — 5 Last Post — 01-19-2017 06:25 PM
Thread — 11 Pro..runs good til higher rpm then kinda cuts out..drops rpm Thread Starter — OrangeKowJumper Forum — Polaris: Pro-Ride Replies — 22 Last Post — 01-12-2014 02:11 PM
Thread — 03 900 low rpm hesitation bog/high rpm loss Thread Starter — sierraclimber Forum — Arctic Cat: 1M Replies — 13 Last Post — 02-25-2011 06:15 PM
Thread — 2003 Head Det Sensor vs. non-det sensor differences? Thread Starter — snowx22 Forum — Polaris Replies — 1 Last Post — 01-18-2009 12:29 AM
Thread — 7900 rpm or 81500 rpm not 800R's are built alike Thread Starter — Original Tetonice Forum — Ski-Doo Replies — 12 Last Post — 01-09-2009 01:33 PM
no new posts
