Upgrade to Premium
Arctic Cat: Powder Special and older 2000 and older, all models in the Powder Special chassis and older chassis models
Reply
  #1
Old 04-08-2018, 08:34 PM
Proteus88 Proteus88 is offline
Currently: Not set.
Basic Member
Proteus88 is an unknown quantity at this point
Question Advice: Replacing Throttle Assemly and Ignition-370 Panther
Hi,
I need your advice: How complicated would this repair be?
I bought a used 2006 370 Panther that had a faulty ignition. I was able to enjoy the machine all season this year (as long as kill switch "UP" no key was needed) until today. I rolled the machine on a cut line and the kill switch broke off. Minutes later I actually almost hit a Caribou that came blasting out of the trees (eventful morning!)
So I need to order a new ignition+key which I imagine is quite an easy installation that I can do.
Do you think the throttle assembly and kill switch (part seen here: https://www.countrycat.com/arctic-ca...no-2w-w-on-off ) is a task a guy with basic mechanical skills can handle or better left to a proper mechanic?
Thanks guys!
Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 93 Panther need help(advice) Thread Starter — Disco Dan Richter Forum — Arctic Cat: Powder Special and older Replies — 2 Last Post — 01-09-2014 09:48 PM
Thread — 2002 Z 370 Thread Starter — Saddle sore Forum — Arctic Cat (Swapmeet) Replies — 1 Last Post — 12-25-2010 08:14 PM
Thread — Wtb z 370 Thread Starter — Beeline Forum — Arctic Cat (Swapmeet) Replies — 1 Last Post — 12-15-2009 07:43 PM
Thread — replacing stock heated grips any advice on install? Thread Starter — Cheynespub Forum — Ski-Doo: REV Sleds Replies — 7 Last Post — 12-13-2009 04:04 AM
Thread — Replacing throttle valve on 2003 (late) AC 900 1m Thread Starter — Bovine Doc Bob Forum — Arctic Cat: 1M Replies — 3 Last Post — 01-12-2009 12:46 AM
no new posts
