Who's flying a DJI MAVEC DRONE when sledding?
NorthMNSledder
Trail Coordinator
5,610
Ham Lake / Lake of the Woods, MN
I have had the Mavic Pro for about a year now. The 3 biggest things to work around for me in the winter was:
1. Can't fly when it's snowing, would hate to get water into the motors. Also I have heard rumors that if the flakes are big enough they can mess with the flight sensors. Not sure about that but I have had the sun interfere with them during sunrise or sunset type of work.
2. Battery life can be effected if they get to cold. Easy work around is a heated handlebar bag or keep the batteries on an inside pocket.
3. Take offs and landings. You can't take off from the snow as these things kick up a ton of wind (same for sand). I have seen some people carry these large fold-able disks (think tent material) they use. But I just learned to take off and land from the seat of the sled. Lots of practice on this as your handlebars are closer then you think. I also use the truck bed cover as a landing pad in the summer a lot. Makes for a clean surface.
I picked up this case to use with the sled:
https://www.amazon.com/gp/product/B0733R49Y9/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
It's one of those hard sided cases and holds only the drone, two extra batteries and the remote. I use some extra bubble wrap inside it to keep everything solid and then just put that into my backpack or tunnel bag as it's a pretty small size. I plan to build a tunnel mount hard case at some point for it that uses the LINQ system but haven't yet as I worry about the shock it would take in that type of case.
Lots to learn but even out of the box they can take some amazing footage for even a rookie like me.
<a href="https://benwyatt.smugmug.com/2018-Grizzly-Lodge-Trip/n-WLf6Np/i-GqwHR2s/A"><img src="https://photos.smugmug.com/photos/i-GqwHR2s/0/df56610a/X2/i-GqwHR2s-X2.jpg" alt=""></a>
<a href="https://benwyatt.smugmug.com/2018-Grizzly-Lodge-Trip/n-WLf6Np/i-Xg2bnRK/A"><img src="https://photos.smugmug.com/photos/i-Xg2bnRK/0/d599fe71/X2/i-Xg2bnRK-X2.jpg" alt=""></a>
stahlecker
107
54
Western NE
Mavic Pro this last season for me. Worked well the little I used it. It wasn't too cold probably 20 degrees or so most days. I will say these little guys handle the wind surprisingly well. I would take off from my hand and land there as well.
Also my insurance company offered me full coverage and zero deductible for $38/ year. Makes it a little easier to strap that expensive of a toy onto my tunnel.
27,374
That is something i had NOT heard thus far.
27,374
https://store.dji.com/guides/winter-drone-flying-tips/
Flying a Drone in Winter: 5 Things You Must Know
Winter drone flying can sometimes be challenging in extreme conditions. Low temperatures can impact flight performance, and weather can be unpredictable. It’s possible that you will encounter rain, fog, or snow during flight. So how can you have a safe flight and capture great shots during the winter months? Here are some safety and camera
settings tips to keep in mind when flying your drone during winter.
Battery
Like many of the latest portable devices, DJI drones use Lithium Polymer (LiPo) batteries. Cold temperatures can put your batteries out of their comfort zone, decreasing the chemical activity within batteries. Follow the tips below to ensure a safe flight:
  • Only use fully charged batteries.
  • Pre-heat your battery to 20°C (68°F) or more. You can check the battery temperature in DJI GO. Use a Battery Heater if one is available for your product.
  • Hover for about a minute to allow the battery to warm up.
  • Only push the control sticks gently to prevent any battery voltage drops.
  • Batteries drain faster in cold temperatures. Always check your drone’s battery status during flight.
E
nvironment
Reduced visibility and the moisture of snow can be the hidden dangers behind shooting spectacular winter scenery. It’s essential to take the right precautions:
  • Before flying your drone, check the weather conditions. Avoid strong wind, rain, and snow.
  • Do not fly in temperatures below 0°C (32°F).
  • Avoid contact with snow. Moisture can damage the motors. It’s recommended to use a landing pad for taking off and landing your drone.
  • Ensure that the GPS signal is strong.
Stay Warm
Ever experienced your mobile device unexpectedly shutting down from the cold? As explained at the beginning, cold temperatures can shorten a LiPo battery’s life. So while taking good care of your Intelligent Flight Batteries, don’t forget to keep your mobile device warm. Additionally, watch out for frostbite. Operating a remote controller with numb hands is dangerous. It’s a good idea wear gloves when flying outdoors during winter months.
Camera Settings – Exposure and White Balance
To capture the beauty of snow, you need to manually set camera exposure and white balance. Shooting in Auto mode can result in dark images. This is because the camera’s exposure system can sometimes underexpose snow, tricked by its brightness. By adding additional stops, you will slightly overexpose your photos but get the right compensation for snow shots. Similarly, you need to adjust the white balance accordingly to get the right color balance of the snowy landscape. Otherwise, the snow may look grey.
Storage
If your drone is idle for a long time, its performance might be affected. Storing it properly is key to a safe flight. Make sure to:
  • Fully charge and discharge the battery once every three months to maintain battery health.
  • Remove the propellers and attach the gimbal clamp when storing your drone.
  • Store your drone in a dry, non-magnetic place at around 25°C (77°F).
Ready to capture a winter wonderland with your drone? Have fun with your winter flying and don’t forget to share your photos with us on our
farmboy84
330
New Prague, MN
I've had my DJI phantom 3 for almost 3 years now, but this Feb in Tog was the first time I tried it in the winter. It was no more than 20deg and snowing lightly and had no problems. I think the key to making them work in the winter is keeping the batteries and tablet warm before using.
A Mavic would be much better than mine for transport since my hard case pack is bigger than my avy bag and I wore it on my front on the trail up, took some footage, then dumped it in the woods till the end of the day. A smaller unit like a Mavic would allow it to fit in an avy bag and be used at any point during the day when conditions are the best.
If you watch the end, I even hit a tree and it survived!
https://youtu.be/AJVzKieX-b0
<iframe width="560" height="315" src="https://www.youtube.com/embed/AJVzKieX-b0" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
Sent from my SGH-M919 using Tapatalk
stumpjumper007
44
15
8
Eastern SD
Can I ask what insurance company you have?
stumpjumper007
44
15
8
Eastern SD
Was that tree you hit that short of bark before or after you hit it! Ha! Awesome video!
AK1000
62
9
8
Anchortown
Custom Iris + in a waterproof aquacopter chassis, even in the waterproof chassis it still sweats a little inside from control board heat and cold outside.
Have to leave batteries for both quad and cameras(three hero 3’s) in my pouch with mandwarmers in it or they die quick. If I put a hothands under the lipo pack in the quad it will last full flight time(22 min).
Buddy has run his mavic pro a couple times and gets low flight time without heat packs(10-12 min).Doesnt seem to have any issues with lightsnow yet.
Not sure how else to get rid of cold drain. Enough room on most rear tunnels to take off from.
NorthMNSledder
Trail Coordinator
5,610
Hey Christopher,
Another thing I forgot to mention that you might want to look into is an tablet holder and using that instead of a phone. I use my iPhone X when I'm trying to be compact in my travels but most of the time I use my iPad mini and it's way more fun to use with the larger screen.
Oh and one last BIG tip I will give you. If you haven't used your drone in a bit make sure to turn it on at home and check for updates. These like updates and sometimes you are not able to fly without them. DJI has a crazy GPS system to it that can tell when you are in restricted airspace and that has to be updated all the time. Much easier to do on the fast home internet then having to do it through a mobile device with low signal. LOL
T
Sep 10, 2009
415
354
The Mavic Pro is great. Check out the first few minutes of this. I did quite a few drone shots last year.
<iframe width="560" height="315" src="https://www.youtube.com/embed/ZMQ6cBUVpMw" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
27,374
Hey Christopher,
Thanks.
my oldest son Had a Phantom 3 for 1 winter and I flew it ONCE and then he sold it and moved on. So I really have NO personal experience on these at all. I am starting from scratch.
NorthMNSledder
Trail Coordinator
5,610
Thanks.
I've had mine for about a year now and I'm amazed how much we use it. Pretty much take it to all family functions now for cool group photos. Bring it with a lot of places.
Taking it to Iceland this October for our trip there.
Wheel House Motorsports
29,933
5,968
SW MT
They are a lot of fun but seriously, practice flying/takeoff/landing etc at home or in a park in nice weather and learn how they work. Practice locking on to people etc playing around with all the modes and features when your not actually trying to capture anything worthwhile. They software on those things and there ability is mind blowing. But hovering poorly panned drone shots were barely cool 5 years ago when they first started hitting the market, there is really no excuse now with how user friendly the software is. Its kind of like owning a 30k sled and barely being able to ride off trail.
Being comfortable with flying near things also makes for incredible shots when you fly by things. Being super high and far away really isn't that fun to watch for more then a quick shot to establish an riding area. It also defeats the purpose of filming with the drone if you don't use any of the footage.
If you put the time in to learn one and pack the proper equipment (warm batteries etc) for them they are an amazing tool for shooting, and the mavic folds up so small and packs very easily in a tunnel bag its so easy to take along.
27,374
And that is EXACTLY why I waited till SPRING and want to buy it NOW.
So I have ALL SUMMER and FALL to learn how to fly this little beast!
