Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 04-01-2018, 11:02 AM
Flying Dutchman Flying Dutchman is offline
Currently: Not set.
Flying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond reputeFlying Dutchman has a reputation beyond repute
Default error code 520215
My 2015 is throwing this code. The manual reads Exhaust valve solenoid-driver circuit grounded - driver circuit short to B+. So what does that mean exactly? Is there something I can check? Wiring, broken part? Sled seems to run fine.
I do have warranty but it's a pain dropping off at dealer, when I can repair the misc stuff myself. If there's more to it, I'll bring it in. Any insight is appreciated.
Rate this post: Yes | No
  #2
Old 04-06-2018, 02:59 PM
gtwitch gtwitch is offline
Currently: Not set.
gtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond reputegtwitch has a reputation beyond repute
Default
with an ohmmeter start checking the exhaust valve solenoid and see if there is cont to ground with it unplugged and then backwards toward the ECU- backwards one side of the connector might show ground ? General electrical trouble shooting here!!
gtwitch in wyoming
The Following User Says Thank You to gtwitch For This Useful Post:
Sage Crusher (04-09-2018)
  #3
Old 04-06-2018, 03:01 PM
Currently: Not set.
Default
Could be a shorted solenoid also??
  #4
Old 04-10-2018, 12:43 PM
Currently: Not set.
Default
FWIW, I took it to the dealer who replaced the solenoid. No other codes present when they ran it through their tester. Covered under warranty.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Error code Thread Starter — ak Forum — Polaris: Pro-Ride Replies — 1 Last Post — 12-04-2017 11:34 AM
Thread — Error code 17?? Thread Starter — firecat99 Forum — Arctic Cat: M Series Replies — 7 Last Post — 03-05-2013 08:26 PM
Thread — Error Code 17 Thread Starter — mitymopar Forum — Arctic Cat: M Series Replies — 3 Last Post — 02-28-2012 10:32 AM
Thread — Error code 12 Thread Starter — CanyonRat Forum — Yamaha Replies — 7 Last Post — 01-06-2009 10:02 PM
Thread — error code 81 Thread Starter — carbondaddy Forum — Yamaha Replies — 2 Last Post — 12-30-2007 11:24 PM
