Upgrade to Premium
Reply
  #1
Old 03-25-2018, 08:38 PM
powder79's Avatar
powder79 powder79 is offline
Currently: sick of work
powder79 has a reputation beyond reputepowder79 has a reputation beyond reputepowder79 has a reputation beyond reputepowder79 has a reputation beyond reputepowder79 has a reputation beyond reputepowder79 has a reputation beyond reputepowder79 has a reputation beyond reputepowder79 has a reputation beyond reputepowder79 has a reputation beyond reputepowder79 has a reputation beyond reputepowder79 has a reputation beyond repute
Default Flutter ctec
Has anyone had any problems with where ctec fluttering 4000-6000 rpms. It also seems to be idle rough.
Rate this post: Yes | No
  #2
Old 03-26-2018, 01:23 PM
Nextime's Avatar
Nextime Nextime is offline
Currently: Supercharged proclimb!!
Nextime has a reputation beyond reputeNextime has a reputation beyond reputeNextime has a reputation beyond reputeNextime has a reputation beyond reputeNextime has a reputation beyond reputeNextime has a reputation beyond reputeNextime has a reputation beyond reputeNextime has a reputation beyond reputeNextime has a reputation beyond reputeNextime has a reputation beyond reputeNextime has a reputation beyond repute
Default
I rode this sled last weekend, 4000 to 4500 rpm is very flutter. All most sounds like it is misfiring. Other wise the higher rpm range is good.
  #3
Old 03-26-2018, 02:51 PM
eldereldo eldereldo is offline
Currently: Not set.
eldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond reputeeldereldo has a reputation beyond repute
Default
Check the cables on the power valves.
  #4
Old 03-26-2018, 11:55 PM
tinkerjohnson tinkerjohnson is online now
Currently: Tinker till I die
tinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond reputetinkerjohnson has a reputation beyond repute
Default 18 ctec
My 18 has it too, from 3,000 rpm to about 5,000 rpm
  #5
Old 03-27-2018, 09:43 AM
sno*jet sno*jet is offline
Currently: Not set.
sno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond reputesno*jet has a reputation beyond repute
Default
did you try new plugs?
  #6
Old 03-28-2018, 01:38 AM
pruner pruner is offline
Currently: Not set.
Basic Member
pruner has a brilliant futurepruner has a brilliant futurepruner has a brilliant futurepruner has a brilliant futurepruner has a brilliant futurepruner has a brilliant futurepruner has a brilliant futurepruner has a brilliant futurepruner has a brilliant futurepruner has a brilliant futurepruner has a brilliant future
Garage
Default
Check the thread on Ctec bog and not the powder bog. Mine was really bad as in fall on your face. They put new injectors in mine and problem solved.
  #7
Old 03-28-2018, 07:58 PM
Toyotajoe Toyotajoe is offline
Currently: Not set.
Toyotajoe has a brilliant futureToyotajoe has a brilliant futureToyotajoe has a brilliant futureToyotajoe has a brilliant futureToyotajoe has a brilliant futureToyotajoe has a brilliant futureToyotajoe has a brilliant futureToyotajoe has a brilliant futureToyotajoe has a brilliant futureToyotajoe has a brilliant futureToyotajoe has a brilliant future
Default
I noticed this flutter several times last weekend. Only after stopping for a rest break for 15-20 mins and then restarting the sled and riding off. I did not notice it after a few mins and some heat built back up in the pipe/engine.
  #8
Old 04-01-2018, 09:01 AM
powder79's Avatar
Default
I took it back to the dealer. They put new plugs in they where black said it might come from over oiling during break in. They tested the injectors when they cut one side off that was how it was running when I had the bog. He said he has had it before where they did that and after they shock them. He took it outside and ran it said it ran alot better
  #9
Old 04-01-2018, 07:30 PM
Default Flutter
Mine is at the dealer now getting the injectors tested. Apparently cat is aware of a problem on this issue, mine also has been melting the skid plate so its probably been throwing flames out the exhaust also.
  #10
Old 04-10-2018, 09:10 AM
Default Flutter
Both injectors tested bad according to the dealer tech. One was worse than the other. Now injectors are on backorder
  #11
Old 05-01-2018, 11:53 PM
Click Here to Register
The Following 3 Users Say Thank You to tinkerjohnson For This Useful Post:
clutch (05-03-2018), Matte Murder (05-04-2018), Old & slow (05-02-2018)
  #12
Old 05-03-2018, 01:23 PM
Paarctic Paarctic is online now
Currently: Not set.
Basic Member
Paarctic has a brilliant futurePaarctic has a brilliant futurePaarctic has a brilliant futurePaarctic has a brilliant futurePaarctic has a brilliant futurePaarctic has a brilliant futurePaarctic has a brilliant futurePaarctic has a brilliant futurePaarctic has a brilliant futurePaarctic has a brilliant futurePaarctic has a brilliant future
  #13
Old 05-03-2018, 07:56 PM
summ8rmk's Avatar
summ8rmk summ8rmk is online now
Currently: Snow angels in dog parks
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
The Following 2 Users Say Thank You to summ8rmk For This Useful Post:
bkm20x (05-04-2018), tinkerjohnson (05-09-2018)
  #14
Old 05-03-2018, 08:46 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
  #15
Old 05-04-2018, 06:48 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
  #16
Old 05-04-2018, 10:06 AM
Matte Murder Matte Murder is offline
Currently: Loving the Alpha 165
Matte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond reputeMatte Murder has a reputation beyond repute
  #17
Old 05-09-2018, 09:06 PM
The Following User Says Thank You to tinkerjohnson For This Useful Post:
Old & slow (05-10-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Ctec bog Thread Starter — SnoPro1000 Forum — 2018 Ascender Replies — 27 Last Post — 12-25-2018 10:55 AM
Thread — CTec 2 in 800 Thread Starter — Icedog Forum — Arctic Cat: Proclimb M Replies — 5 Last Post — 11-11-2014 11:18 PM
Thread — 2 stroke engine flutter Thread Starter — hivoltagesledhead Forum — Ski-Doo: TURBO Replies — 8 Last Post — 05-17-2011 12:38 PM
Thread — 2004 M-7 153 mid-range flutter/burble Help! Thread Starter — Damon8 Forum — Arctic Cat: M Series Replies — 14 Last Post — 12-07-2010 08:36 AM
Thread — Causes for boost guage flutter? Thread Starter — Bowslayer Forum — Yamaha Replies — 7 Last Post — 01-09-2009 07:41 PM
no new posts
