Upgrade to Premium
Reply
  #1
Old 03-24-2018, 03:26 PM
skiutahcabin skiutahcabin is offline
Currently: :)
skiutahcabin has a reputation beyond reputeskiutahcabin has a reputation beyond reputeskiutahcabin has a reputation beyond reputeskiutahcabin has a reputation beyond reputeskiutahcabin has a reputation beyond reputeskiutahcabin has a reputation beyond reputeskiutahcabin has a reputation beyond reputeskiutahcabin has a reputation beyond reputeskiutahcabin has a reputation beyond reputeskiutahcabin has a reputation beyond reputeskiutahcabin has a reputation beyond repute
Default Nytro Impulse MPI Boondocker hybrid turbo
$5900
For sale is an amazing sled... pump gas managed fuel, custom build to eliminate all the known issues, you can actually sidehill, turn and throw this sled around; in trees and climb chutes, its been built to the same specs as the polaris axys numbers to create nimble handling.
Has a turbo nytro motor, engine work, head shim, low compression set up. MPI /impulse / Boondocker turbo hybrid- rear mount 2871 garrett turbo, fuel management system with dual injectors and boondocker computer, pull and go. Runs on pump gas up to 9-10lbs of boost, then you go racegas up to 15. Depending on what you are running its estimated putting out 225-300hp. Has copper doughnuts in the exhaust, new manifold last year and tunnel dump exhaust. Has mountain tec protection panel under it and snow eliminators on the side, the motor has 2200 miles, most of the rest of everything has been exchanged out. All electrical unions are sealed up right.
Suspension is top of the line KMOD with Kmotion, raptor and evol and fox floats, perfectly balanced setup.
Altered track angle, so no trenching issue
Steering relocate, extended tunnel, custom mountaintec a-arms 34” width up front so you can turn on a dime, sidehill and lay it over.
Everything synthetic amsoil.
The motor is an '08 fx genesis.
Just back from LCC, tuned up to perfection.
Has reverse, also has headlight delete and mesh panels, tether, rollover valve and relocated main pod so you can see gauges, also has AFR and turbo gauges, temp gauge, runs at 185 temp wide open.
Wide open the sled just ran 0-80 mph in 3 sec in a foot of powder w boost on the lowest setting,
Super fast, reliable, everything done right. Comes with CA Pro skis and a fatboy deep pow 10” wide set of floaters. Custom seat too, track is 163 and not missing any lugs.
Ive torn up a shoulder and will be out for a couple seasons, thus the sale. I've put 10 miles on it this winter, before the injury, it needs good home.
For an extra grand the custom trailer comes with it. Over 25k in this build, this machine rips.
In Cottonwood Heights Utah
txt me at 801-859-2535
Rate this post: Yes | No
  #2
Old 03-24-2018, 04:16 PM
Snowmow's Avatar
Snowmow Snowmow is online now
Currently: Not set.
Snowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond repute
Default
All that. And not one picture
  #3
Old 03-24-2018, 09:20 PM
Currently: :)
Default wow- forgot pics! thanks
pics...
Click image for larger version
ID:	294750   Click image for larger version
ID:	294751   Click image for larger version
ID:	294753   Click image for larger version
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Impulse turbo nytro Thread Starter — 1100 Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 4 Last Post — 02-14-2013 09:00 PM
Thread — Impulse turbo nytro ???? Thread Starter — Sledneck_1987 Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 2 Last Post — 01-18-2011 08:00 AM
Thread — F/S Impulse Turbo Nytro Thread Starter — Tookes Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 5 Last Post — 03-04-2010 08:02 PM
Thread — Impulse Turbo VS MPI Stage 3 Supercharger Thread Starter — 08_Nasty_Nytro Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 58 Last Post — 10-20-2009 05:29 PM
Thread — impulse turbo nytro Thread Starter — Liv4snow Forum — Yamaha Replies — 23 Last Post — 01-06-2008 10:00 PM
no new posts
