Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 03-24-2018, 04:35 AM
stmike stmike is offline
Currently: Not set.
stmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond repute
Default Over heat
My grandson blew his 2016 m8 , cracked piston dealer says it needs a complete drop in..It is still under warranty but they are saying by the report it had to many high heats. I know nothing about the cat system ,what temp does the light come on . Does the motor go to limp mode and at what temp,and will the motor shut down if over heat .
Rate this post: Yes | No
  #2
Old 03-24-2018, 06:58 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
Default
Quote:
Can't remember the exact numbers but that really doesn't matter. The temp light will flash as a warning then stay on if it gets warmer. The engine will start to stutter when the temp light starts to flash. The engine will not shut down unless it seizes. The old 800 Suzuki engine is as tough as they come so this is uncommon. What type of riding does he do trails, lakes, deep snow? Does the sled have a 2.6 or 3 in track?
  #3
Old 03-24-2018, 07:42 AM
Currently: Not set.
Default
Quote:
He does not ride trails . Only rivers, creeks ,and anywhere there is deep snow. Sled has the 2.6 track .
fix....
  #4
Old 03-24-2018, 08:17 AM
XCaSSAULT XCaSSAULT is offline
Currently: Go Wild!
Basic Member
XCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond repute
Default
He does not ride trails ,rivers, creeks ,and anywhere there is deep snow. Sled has the 2.6 track .
He doesn’t ride deep snow?
I believe temp light flashes at 168f and stays on at 190f. I think there is a sticker on clutch guard that says what it is.
Does he see the light flash a lot? Or stay on a lot? 168f is running hot but nothing the motor can’t handle. 180f plus on a regular basis would be a problem.
On these mountain sleds with small cooling system it’s something you have to be aware of. Scratchers down, get in deep snow etc. is trail ridding a m8000 possible? Yes but those things need to be in check.
I have read about some bad radiator caps that will let coolant leak out overflow and not hold pressure properly so maybe that was a issue for him?
  #5
Old 03-26-2018, 06:11 AM
Currently: Not set.
Default
We found the head gasket was leaking . He took it to the dealer ,they replaced the o rings for the head .Two days later it died ,broken skirt. They denied warranty because to many over heats ,but they paid for the o rings !!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — clutches and belt heat? how much is to much heat? Thread Starter — catf1000s/p Forum — Arctic Cat: Proclimb M Replies — 0 Last Post — 03-11-2012 02:34 PM
Thread — WTB crossfire rear heat exchanger or 09 or newer heat ex Thread Starter — glaciermonkey Forum — Chassis/Tunnel (Swapmeet) Replies — 2 Last Post — 05-31-2011 10:45 PM
Thread — Heat Loc Hand Guards by SkinzTM(Reference #HEAT-LOC) Thread Starter — frozen north Forum — Handlebars/Risers (Swapmeet) Replies — 6 Last Post — 02-12-2010 08:07 PM
Thread — Heat tape Heat pad or Nomex Thread Starter — donbrown Forum — Polaris Replies — 6 Last Post — 09-23-2008 08:41 PM
