Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 03-22-2018, 10:38 PM
The Grand Pooh-Bah The Grand Pooh-Bah is offline
Currently: Not set.
Basic Member
The Grand Pooh-Bah is an unknown quantity at this point
Question Is this a problem??? VES Exhaust Valve Piston Rub
While I had the head off to replace the suspected blown head gasket I noticed that it appears the exhaust valves may have rubbed on the pistons.
Also do the marks on the cylinder walls look normal for an 04 Liberty 800 engine?
There was a lot of water in the gas tank and it took out one of the reeds and damaged several others.
Rate this post: Yes | No
  #2
Old 03-24-2018, 09:29 PM
XCaSSAULT's Avatar
XCaSSAULT XCaSSAULT is online now
Currently: Go MN Wild!
XCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond repute
Default
Cylinder marks are normal. As long as u canít catch your finger nail on them theyíre fine. Piston wash looks really good too.
There was a post awhile back in the iq section I believe were valve/piston rub was a issue. I had suggested doubling up the valve gasket to get more clearance but apparently that wouldnít work as someone chimed in and said thereís a stop on the cylinder itís self that gets worn down causing this problem. If thatís the case then only replacing the cylinders would solve this problem. I think u could file the edges down a tad and fix this problem. Worth a try.
Deffinitly take a look through the exhaust and see how scraped the piston might be. A little scratching ainít nothing to worry bout. If thatís the case then good find!
  #3
Old 03-24-2018, 09:43 PM
summ8rmk's Avatar
summ8rmk summ8rmk is offline
Currently: Stirring pots
summ8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond reputesumm8rmk has a reputation beyond repute
Default
Pull the y-pipe look at the side of the pistons and rings. Make sure the valves didn't chip a ring.
Pull out the valves and file them a bit or take them to the bench grinder. Make some clearance.
  #4
Old 04-01-2018, 06:03 PM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is offline
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default
The stop on the VES guillotine valve itself is probably pretty beat up. It certainly looks like an expensive accident waiting to happen. As in piston/ring/cylinder replacement. Some used valves can be bought cheaply on EBAY, since Edges aren't IN anymore. Hand honing of the cylinder wall catches oil to keep the ring contact surface lubricated. Honing marks wear away and need to be replaced.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 700 ves exhaust valve trouble Thread Starter — Jay Forum — Polaris: EDGE Replies — 2 Last Post — 12-16-2012 11:57 PM
Thread — How do you check to see if the power valve (exhaust valve) is working properly? Thread Starter — mx100 Forum — Ski-Doo: ZX Sleds Replies — 6 Last Post — 12-14-2012 05:35 PM
Thread — Anyone got an idea how to mount this exhaust so it don't rub? Thread Starter — Bubbles Forum — Yamaha: 4-Stroke Replies — 0 Last Post — 01-04-2012 06:48 AM
Thread — Polaris VES exhaust valve springs, lots to choose from, all brand new!!! Thread Starter — Sundance Kid Forum — Engine/Engine Parts (Swapmeet) Replies — 11 Last Post — 01-09-2010 07:52 PM
no new posts
