Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 03-19-2018, 04:31 PM
wetwillii wetwillii is offline
Currently: Not set.
Basic Member
wetwillii is an unknown quantity at this point
Default 2008 m1000 shutting off when warm
2008 m1000 has slp single pipe set up. Runs great, but sometimes when it warms up it shuts off. idle and full throttle no problem, but letting off a partial throttle will shut off. Checked OHMS in stator and checked out fine. swapped out ecu and resistor. unplugged everything in handle bars(key, kill switch, tether, throttle wires) still same. Any suggestions?
Rate this post: Yes | No
  #2
Old 03-20-2018, 09:05 AM
Ddub's Avatar
Ddub Ddub is offline
Currently: Not set.
Ddub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond repute
Default
Stator could ohm out when warm. Seen them test fine cold but once warm nothing. The fuel line runs close to the pipe on that sled also, if you don't have it shielded somehow it could be getting to hot. I wrapped my line with heat tape.
  #3
Old 04-10-2018, 08:54 AM
Hardass's Avatar
Hardass Hardass is offline
Currently: Not set.
Hardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond reputeHardass has a reputation beyond repute
Default
Though im not saying its not the stater the symptoms your describing do not look like stater to me usually a stater will run a bit and shut down untill cooled some what or start missing you say you unhooked the saftey swith so thats out icheck all wiring for water mainly the ecu plugs and stater plug while looking at the stater plug look close and see if it looks dicolored in there and making good contact they were known to lose contact over time it causes lots of issues oe it can just my thoughts
__________________
M 1000 modded but no turbo no way Uh well maybe
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Rebuilding 2008 Dragon: warm or cold? Thread Starter — TheBCSledder Forum — Polaris: IQ Replies — 4 Last Post — 12-30-2012 08:44 AM
Thread — Sled shutting itself off Thread Starter — Hostile 700 mod Forum — Polaris: EDGE Replies — 6 Last Post — 12-08-2009 10:54 PM
Thread — 2009 M1000 2-2008 M1000 2-2007 M1000 snow pro Thread Starter — ctillman Forum — Arctic Cat (Swapmeet) Replies — 10 Last Post — 05-01-2009 10:41 AM
Thread — 08 m1000 no spark when warm.....1600mi Thread Starter — powderpatrol Forum — Arctic Cat Replies — 10 Last Post — 02-23-2009 04:49 AM
Thread — sled shutting down.. Thread Starter — polaris900 Forum — Polaris Replies — 1 Last Post — 02-03-2008 09:59 PM
no new posts
