Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 03-18-2018, 06:19 PM
The Grand Pooh-Bah The Grand Pooh-Bah is offline
Currently: Not set.
Basic Member
The Grand Pooh-Bah is an unknown quantity at this point
Question Mikuni TM40 Carb Rebuild Question
I am accustomed to purchasing rebuild kits before tearing carbs down. I am having trouble finding a kit for this carb. Do these carbs rarely need rebuilding or what? Is this an uncommon Carb? Should I Upgrade?
Rate this post: Yes | No
  #2
Old 03-18-2018, 06:52 PM
XCaSSAULT XCaSSAULT is offline
Currently: Go Wild!
Basic Member
XCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond repute
Default
Mikuni flat slide rack carbs?
They are very common and a very good carb. Alls u really need to do is pop the bowl off. Make sure u use a good correct size Phillips head on the lone screw, and spin the drain plug off. Take the main, pilot (careful of springs and washers) and starter jet off. Choke plunger out, fuel screw and crab cleaner through everything.
The bowl gasket is o-ring like and easily re-usable. The plastic float assembly isn’t really adjustable, just make sure needle holds pressure.
That’s it. Shouldn't need to go further
The Following User Says Thank You to XCaSSAULT For This Useful Post:
The Grand Pooh-Bah (03-18-2018)
  #3
Old 03-18-2018, 10:01 PM
BeartoothBaron BeartoothBaron is offline
Currently: Not set.
BeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond repute
Default
Yeah, unfortunately, they don't have a carb kit like you'd find with a common automotive carb. Not sure why since it'd be nice to be able to refresh all the rubber pieces. You can get the pieces through Polaris, but they're expensive.
The TM40 was fairly common on snowmobiles, Polaris used them on the 700s and 800s, several other makes used them too. It's hit or miss whether they need new pieces or not; given the prices, I'd say the best approach is the tear the carb down and see what things look like. If the rubber pieces are intact and not completely hardened up, you should be good to reuse them. A regular cleaning should be all that's necessary (especially if you avoid ethanol) until the pieces start showing signs of distress.
There aren't any upgrades, practically speaking; changing carbs around on 2-strokes, while possible, isn't as straightforward as an old small block.
The Following User Says Thank You to BeartoothBaron For This Useful Post:
  #4
Old 03-18-2018, 10:24 PM
Currently: Not set.
Basic Member
Thumbs up
When the time comes I will go with the recommended method. Thanks
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 93 jag 440 f/c mikuni carb question Thread Starter — ponchonutty Forum — Arctic Cat: Powder Special and older Replies — 3 Last Post — 10-30-2016 11:03 PM
Thread — Mikuni TM40 Rack bored to 42 by Carls Thread Starter — FactoryAir1 Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 0 Last Post — 05-12-2015 10:44 AM
Thread — Mikuni Carb tear down, cleaning, rebuild video tutorials Thread Starter — lshobie Forum — General Snowmobiling Replies — 2 Last Post — 11-23-2011 09:23 PM
Thread — TM40 mm Mikuni flatslide carbs Thread Starter — MrClean409 Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 2 Last Post — 12-23-2009 08:54 PM
no new posts
