Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 03-18-2018, 12:18 AM
laneends laneends is offline
Currently: Working at sea
laneends has much to be proud oflaneends has much to be proud oflaneends has much to be proud oflaneends has much to be proud oflaneends has much to be proud oflaneends has much to be proud oflaneends has much to be proud oflaneends has much to be proud oflaneends has much to be proud oflaneends has much to be proud oflaneends has much to be proud of
Default Crazy enough to work?
Hello snowest, I'm fairly new to the sport as I only have a few seasons under my belt. First off, I have a 2010 summit 163 XP 800 ptek, somewhere around 4500 miles, and stock as far as I know except for a can.
So, my buddy wrecked it into a tree, and dented the pipe. I also noticed while I had it apart to fix it the pipe was split inside the bend.
I decided to replace it with the SLP kit, y-pipe, pipe, and silencer. Here comes the question. SLP recommend jetting up to a 490(is 480 stock?) No idea what's in there now. I also intend to put in boyesen reeds, they recommend jetting down. Will these two modifications cancel each other out?
Thanks in advance!
Rate this post: Yes | No
  #2
Old 03-18-2018, 09:54 PM
treeboy treeboy is offline
Currently: Not set.
Basic Member
treeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond repute
Default
Now are you doing the slp air intake too or a air box mod. I was using 500 mains with the exhaust and modded air box with the boysen reeds. Also I would shim up the needles those sled run lean in the mid range. I barely saw over 1250f on my etgs and motor lasted over 12000 kms.
The Following 2 Users Say Thank You to treeboy For This Useful Post:
laneends (03-18-2018), MountainTrashCat (07-05-2018)
  #3
Old 03-18-2018, 11:17 PM
Default
Yes, I went ahead and ordered their air intake kit. I'm still learning, but I have a mechanical background. Problem is I spend way too much time out at sea. I guess I need to order up some jets and shims. How much should I shim the needles? Do I need to run different jets in each side? I've heard it mentioned a couple times, I've basically read the entire REV and XP sub forums, and I have to admit the info is kinda blurring together.
I'm reading up on plug reading and piston wash, never done either. I'm hoping to get one more trip in when I get home, so I'm hoping I don't have to spend too much time fiddling... Will I be dangerously lean if I slap on the SLP exhaust system and go hit the hill?
My pipe is fubar, but I could probably dig up a stocker if that's safer. I have two XP sleds and a rev, but intend to have them all out on the hill. I ride in the priest lake Idaho area, so I'll be around 3500-6500 feet.
Plan for summer is to hit up winterbrew, since he's just a little south of me, and find out what I should do for clutches (never had one open) maybe he has some scissor relocation brackets for me too, as I have an 09 146" as well as an 08 154" skid I want to put in my REV. Gonna learn alot this summer... Save some spring snow for me!
The Following User Says Thank You to laneends For This Useful Post:
  #4
Old 03-19-2018, 08:38 PM
Currently: Not set.
Basic Member
Default
I was running 40thou for the shims stock was 30. I ran 500 mains in both with no problems. But my air box is heavily modded.
Where about in Washington are you?
  #5
Old 03-19-2018, 11:22 PM
Default
I live in Kent, but right now I'm bobbing around the bearing sea... Thanks for your input. Any reason you chose to go 500 over SLP's suggested 490? Why does boyesen suggest smaller jets? I have so much to learn on these machines...
  #6
Old 03-20-2018, 07:51 AM
Currently: Not set.
Basic Member
Default
I’m using 500’s cause on where I like to keep my exhaust temps at. Also how modded my air box is. Less than 500 I was running hot.
The Following User Says Thank You to treeboy For This Useful Post:
  #7
Old 03-20-2018, 11:03 AM
Default
What all have you done to the airbox? I assume EGT's should be kept under 1250 like my Cummins, since aluminium melts around there... I guess I should think about a pyro. I was hoping more people would chime in, but I guess XP riders are a dying breed...
Anybody know if the carbs are interchangeable between the REV and XP? I have a spare rack of them.
  #8
Old 03-20-2018, 11:59 AM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Most guys around here (Wa) left the stock jetting or maybe up 1 size. Just do some good throttle chop/plug checks at various throttle positions to verify. Watch for deto sensor and plugs loosening, but it never seemed to be a problem.
The Following User Says Thank You to winter brew For This Useful Post:
laneends (03-20-2018)
  #9
Old 03-20-2018, 12:12 PM
Default
Since you seem to be a highly regarded expert around here brew, are you saying try stock jetting and go from there? Or start at 490? I'm still confused as to how he reeds affect mixture. Also I'm going to need your contact info, as I would like to run your clutching in all three of my sleds, I've never touched them, and my old rev's primary is rattling (o rings?). Do you still have the relocation brackets?
Also question for anyone, is it worth it to mount an XP skid in the old rev? I have a 154" ported track I was going to put on to replace my haggard 151", already have ski doo 2.86 drivers and a big wheel setup...
  #10
Old 03-20-2018, 02:22 PM
Currently: Not set.
Basic Member
  #11
Old 03-21-2018, 02:47 PM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Click Here to Register
The Following 2 Users Say Thank You to cubby For This Useful Post:
laneends (03-21-2018), MountainTrashCat (07-05-2018)
  #12
Old 03-21-2018, 05:42 PM
  #13
Old 03-23-2018, 09:34 PM
cascadesnowjunky's Avatar
cascadesnowjunky cascadesnowjunky is online now
Currently: doing the snow dance
cascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond repute
  #14
Old 03-24-2018, 04:54 PM
Currently: Not set.
Basic Member
  #15
Old 03-28-2018, 11:48 AM
  #16
Old 03-28-2018, 10:20 PM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Am I crazy? Thread Starter — stingray719 Forum — Vipers! Replies — 9 Last Post — 06-07-2014 09:42 PM
Thread — Crazy Thread Starter — byeatts Forum — Snow bikes Replies — 16 Last Post — 03-27-2014 09:30 PM
Thread — THIS is CRAZY ! ! ! Thread Starter — Sturgis Sledder Forum — Fouled Plug Replies — 28 Last Post — 10-31-2009 04:06 PM
Thread — Going crazy with this one!! Thread Starter — SandD540 Forum — Ski-Doo Replies — 0 Last Post — 03-15-2008 12:55 PM
no new posts
