Upgrade to Premium
Polaris: AXYS 2016 AXYS chassis
Reply
  #1
Old 03-14-2018, 09:30 AM
richracer1's Avatar
richracer1 richracer1 is offline
Currently: Loving my BMP 860
richracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond repute
Lightbulb NEW PRODUCT: TPS Test Cable Kit & Fuel Pump Prime Cable
Here's something for you guys wanting to check and adjust your TPS. The test leads have terminals on them so the meter leads will fit in them nice and snug, freeing up your hands to make the necessary adjustments.
The AXYS TPS cable will fit 2014-2018 model years.
A power up cable is included along with instructions. You will need to provide a 12V battery and a good multi-meter.
For more Info... see this thread in swapmeet:
https://www.snowest.com/forum/showth...55#post4141055
The TPS test cable
The TPS Test Kit:
__________________
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 4 Users Say Thank You to richracer1 For This Useful Post:
Brish (03-14-2018), KMOD (03-26-2018), Prayn4snow (03-21-2018), Wheel House Motorsports (03-29-2018)
  #2
Old 03-15-2018, 11:31 AM
richracer1's Avatar
Default
For those that already have a power-up cable, the TPS test cable is also available by itself.
__________________
  #3
Old 03-22-2018, 05:14 PM
richracer1's Avatar
Default
In addition to the TPS test cable kit, I now have a fuel pump prime pigtail cable that will connect to any power-up cable.
There will be a stand-alone fuel pump prime cable that has battery clamps as well. These will be made to order.
Details will be in the linked swap meet thread that's in the original post I made here.
__________________
The Following 3 Users Say Thank You to richracer1 For This Useful Post:
KMOD (03-26-2018), Sage Crusher (03-29-2018), Teth-Air (03-23-2018)
  #4
Old 03-29-2018, 10:32 AM
richracer1's Avatar
Default
This is an FYI for anyone that's interested in a TPS test cable or kit. I now have TPS test cables for the 2013 and older sleds. So the test cables will now be listed as Axys TPS Test Cable (will fit 2014-2018) and Pro-Ride TPS Test Cable (2013 and OLDER models).
Please make sure you request the correct TPS test cable or kit for your sled.
__________________
  #5
Old 04-01-2018, 10:13 AM
richracer1's Avatar
Default
FYI, per the service manual using the Fuel Pump Prime feature:
Run the fuel pump for no more than 10 seconds at a time. An audible change in the sound of the fuel pump will occur as the air is bled from the system. Disconnect battery power from the connector prior to starting the engine.
__________________
  #6
Old 08-03-2018, 12:57 PM
richracer1's Avatar
Default
I just checked the2019 Polaris parts listing and my Axys TPS test cable will fit 2014 - 2019 800 & 600 TPS sensors.
__________________
1 out of 1 members found this post helpful. Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Polaris TPS Test Cable Kits Thread Starter — richracer1 Forum — EFI & EFI Electronics (Swapmeet) Replies — 6 Last Post — 10-16-2018 10:05 AM
Thread — TPS Setting with ECU Power-up cable Thread Starter — dyrengd Forum — Polaris: 900 Replies — 1 Last Post — 01-28-2013 07:19 PM
Thread — Throttle cable or tps sensor problem? Thread Starter — adam5187 Forum — Polaris: TURBO Replies — 0 Last Post — 10-24-2011 09:17 PM
Thread — How do I test my DPM and TPS? Thread Starter — JamesS Forum — Ski-Doo Replies — 2 Last Post — 02-25-2009 10:52 PM
Thread — TPS or thottle cable problem? Thread Starter — picks Forum — Arctic Cat Replies — 2 Last Post — 12-26-2007 07:34 PM
no new posts
