Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 03-13-2018, 08:48 PM
snowracer21 snowracer21 is offline
Currently: Not set.
snowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond reputesnowracer21 has a reputation beyond repute
Default Silber Turbo AXYS, oil light/low rpms
Guys,
I'm not sure where to start with this..
Sled: 2017 RMK Pro 800 155"
Silber turbo @ 5psi (non intercooled)
IS turbo 3 clutch kit
SLP torque arm
I had the sled dialed in, pulling 8350-8400 all day a few weeks ago. I had the clutching dialed in for the elevation I usually ride, so that's not it.
Now, It pulls 8050-8150.. doesn't feel nearly as strong...and on longer pulls, the oil light comes on. (not the check engine light) This is a new thing, idk what it could mean?
I made sure it wasn't because of low oil, I topped the oil tank off.
Sled feels like it still has good compression, but I haven't checked #s yet.
Rate this post: Yes | No
  #2
Old 03-14-2018, 08:41 AM
JJ_0909 JJ_0909 is online now
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
Default
Quote:
Originally Posted by snowracer21 View Post
Guys,
SLP torque arm
Few ideas...(I work for Silber)
I am yet to hear of one customer have this low oil light issue (as in the light comes on and it points to some other issue)
  • Check your primary clutch spring. It may be broken or fatigued.
  • Look at your exhaust valves. Clean them.
  • The low oil light is concerning and points to a possible electrical gremlin somewhere. This can be a pain to pinpoint.
  • Go plug your machine into digital wrench. There may be a code that shines some light on this.
  • How is the bottom end? It could be a boost leak (unlikely based off what you are describing)
  • Go ahead and look close at the oil lines. Make sure you aren't leaking somewhere (to the motor, turbo, etc)
  #3
Old 03-14-2018, 10:20 AM
AKFULLTHROTTLE's Avatar
AKFULLTHROTTLE AKFULLTHROTTLE is online now
Currently: Waiting for my Polaris 850!
AKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond repute
Default
Does the RPM only drop while the oil light is on?
Check your EV cable and then actually pull them out to inspect.
__________________
Full Throttle Customs
Alaska Silber Turbos Dealer
http://www.silberturbos.com/
  #4
Old 03-14-2018, 08:15 PM
southshore southshore is offline
Currently: Not set.
Basic Member
southshore has a reputation beyond reputesouthshore has a reputation beyond reputesouthshore has a reputation beyond reputesouthshore has a reputation beyond reputesouthshore has a reputation beyond reputesouthshore has a reputation beyond reputesouthshore has a reputation beyond reputesouthshore has a reputation beyond reputesouthshore has a reputation beyond reputesouthshore has a reputation beyond reputesouthshore has a reputation beyond repute
Default
My oil light comes on too, mainly because my sleds pointing at the sky. Love my Silber
2 out of 2 members found this post helpful. Rate this post: Yes | No
  #5
Old 03-23-2018, 10:30 AM
Currently: Not set.
Default
Sled has good compression, I haven't really dug into much else though, but I plan to this weekend.
This past weekend I was riding at about 6,000', temps were just below freezing.
On a straight stretch, at WOT, the sled would pull about 8000rpms most of the time, and then a couple times, it would pull 8250. WTF.
I attempted a long/steep side hill, a lot of throttle chopping, and after maybe 30 seconds or so into the side hill, I could feel the sled cutting out bad...the oil light was on, and the sled nearly died out, which forced me to turn out. The best way I could describe it: it felt like a dirt bike that was running wayyyy too rich and bogging out.
The oil tank was full, so IDK why the oil light is coming on... is it possible there is too much vacuum/cap isn't venting properly, in the oil tank and the engine isn't getting enough oil?
  #6
Old 03-23-2018, 11:25 AM
Default
Well I would check you exhaust valve system over good. I have heard reports of sleds detuning while oil light is on but no real evidence. Guessing it has nothing to do with it but possible. Makes sure the wires going into that sensor are not messed up.
__________________
  #7
Old 03-24-2018, 05:35 PM
Currently: Not set.
Default
is it possible to inspect/clean the EV guillotines, without using the digital wrench to relearn?
  #8
Old 03-25-2018, 01:11 PM
sumtinwong sumtinwong is offline
Currently: Not set.
Basic Member
sumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond repute
Default
yes just don't disconnect the cable. if you want to do it on the bench just take the whole assembly out as a whole. their are good detailed posts on the proses in the axys forums and I think they have picts to
  #9
Old 03-25-2018, 06:31 PM
Currently: Not set.
Default
Quote:
awesome, thank you!
just FYI, compression #s are:
PTO side: 115
Exhaust side: 118
engine was at operating temp.
  #10
Old 03-26-2018, 09:16 AM
  #11
Old 03-29-2018, 09:09 PM
Currently: Not set.
Click Here to Register
  #12
Old 04-09-2018, 08:31 PM
Currently: Not set.
  #13
Old 04-09-2018, 09:08 PM
diamonddave's Avatar
diamonddave diamonddave is offline
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
The Following User Says Thank You to diamonddave For This Useful Post:
jolly (04-16-2018)
  #14
Old 04-14-2018, 08:29 AM
xmk1080 xmk1080 is online now
Currently: Not set.
xmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond reputexmk1080 has a reputation beyond repute
  #15
Old 05-01-2018, 11:47 AM
Currently: Not set.
  #16
Old 05-01-2018, 09:44 PM
madmax's Avatar
madmax madmax is online now
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
  #17
Old 05-01-2018, 10:19 PM
madmax's Avatar
Currently: Not set.
  #18
Old 05-14-2018, 01:52 PM
Currently: Not set.
The Following 2 Users Say Thank You to snowracer21 For This Useful Post:
respic (05-21-2018), sumtinwong (05-15-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2016 Axys 155 w/ Silber Turbo and Low Miles Thread Starter — 800xtreme Forum — Polaris (Swapmeet) Replies — 3 Last Post — 07-09-2017 07:59 PM
Thread — Silber axys turbo oil supply line size Thread Starter — hanson summit Forum — Polaris: TURBO Replies — 6 Last Post — 01-20-2017 12:08 AM
Thread — 13 pro rmk 800 silber turbo studder at 7500 rpms Thread Starter — RMKVE800 Forum — Polaris: TURBO Replies — 12 Last Post — 02-08-2016 12:15 PM
Thread — oil pressure light or guage for a silber? Thread Starter — ragincajun Forum — Polaris: TURBO Replies — 6 Last Post — 12-05-2013 10:03 PM
Thread — 04 rev 800 tach and speedo drops out at low rpms no miles and oil and temp light on h Thread Starter — walker Forum — Ski-Doo Replies — 3 Last Post — 05-09-2008 09:04 AM
no new posts
