Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 03-13-2018, 12:34 AM
TreeThrasher TreeThrasher is offline
Currently: Not set.
Basic Member
TreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond repute
Default Drivers on 850 turbo
What are you guys using for drivers? 6 tooth avids or going up to 7 tooth?
I have to have the track fiddle string tight and it still ratchets if I hit something and load the track hard in boost
Thanks
Rate this post: Yes | No
  #2
Old 03-13-2018, 03:18 AM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Default
Of note... a 7 tooth driver will reduce the lug tip clearance by more than 1/2" (.55")
__________________
Signature:
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 03-13-2018, 09:20 PM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
Default
Got myself a set of seven tooth, seams to be pretty common with boost, even on NA it's gotta be pretty dam tight.. Lots of loss to friction with stock drivers and brutal attack angle.. Way to go brp
  #4
Old 03-14-2018, 06:22 PM
Chadly's Avatar
Chadly Chadly is offline
Currently: Not set.
Chadly has disabled reputation
Default
I run the 6 tooth Avid drivers with about a half inch of sag off the rail. They have never ratcheted. Before I had them I ran the track banjo tight and it ratcheted anytime I landed under power.
The Following User Says Thank You to Chadly For This Useful Post:
PaulAnd (03-14-2018)
  #5
Old 03-14-2018, 09:01 PM
Currently: Not set.
Basic Member
Default
So with the loss of .55 inch of clearance with the 7 tooth driver how tight does that put the clearance of paddle to tunnel?
Anyone care to ponder what is more effective...a smaller driver that bends the track tighter but has additional tunnel clearance, or a larger driver for less rolling resistance but less clearance in the tunnel?
Thanks
The Following User Says Thank You to TreeThrasher For This Useful Post:
mountainhorse (03-15-2018)
  #6
Old 03-15-2018, 02:10 AM
Default
Now that.... is a good question !
__________________
Signature:
2 out of 2 members found this post helpful. Rate this post: Yes | No
  #7
Old 03-15-2018, 02:13 PM
madmax's Avatar
madmax madmax is offline
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
Default
Probably not a question we will ever get a legit answer to. I only know when you put a 3” track in a proclimb Cat with 8t drivers there is very little track to tunnel clearance and the sled performs a lot better than with the 2.6 lug track and 8t that has over .5” clearance.
__________________
19’ Alpha 800 turbo (on the way)
18, MC 153 stock
18’ axys 155 stock
17’ axys 800 sidekick 162x3
17’ Cat 800 snow pro 153 alpha
  #8
Old 03-15-2018, 06:16 PM
Ox's Avatar
Ox Ox is offline
Currently: Drainin' the swamp!
Ox has disabled reputation
Default
Isn't the stock track fully clipped so that you can run extro's?
Am I behind the times?
__________________
Looks like I lost my old post count ... AGAIN....
Hey - it was a good run while it lasted...
Ask me about aftermarket Doo recoils.
Life Insurance
Death Insurance
  #9
Old 03-15-2018, 06:26 PM
Currently: Not set.
Basic Member
Default
It has Stock extroverts but the teeth are rounded over and with the single ply flexible tracks and only 6 drive teeth it wants to ratchet bad
  #10
Old 03-15-2018, 06:52 PM
rab rab is offline
Currently: Not set.
rab has a reputation beyond reputerab has a reputation beyond reputerab has a reputation beyond reputerab has a reputation beyond reputerab has a reputation beyond reputerab has a reputation beyond reputerab has a reputation beyond reputerab has a reputation beyond reputerab has a reputation beyond reputerab has a reputation beyond reputerab has a reputation beyond repute
  #11
Old 03-15-2018, 07:45 PM
Chadly's Avatar
Currently: Not set.
Click Here to Register
  #12
Old 03-15-2018, 08:34 PM
Ox's Avatar
Ox Ox is offline
  #13
Old 03-15-2018, 08:37 PM
Currently: Not set.
Basic Member
  #14
Old 03-15-2018, 08:59 PM
Ox's Avatar
Ox Ox is offline
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Doo stock sixth tooth drivers garbage for turbo sleds on 850 Thread Starter — fredw Forum — Ski-Doo: TURBO Replies — 11 Last Post — 11-28-2017 09:42 PM
Thread — Sneak Peak: Turbo Performance's 850 Turbo Systems are almost here Thread Starter — brycter Forum — Ski-Doo: TURBO Replies — 5 Last Post — 11-15-2016 09:39 PM
Thread — installed new drivers for my turbo sled, rails hit drivers? Thread Starter — rmk700rules Forum — Polaris: TURBO Replies — 4 Last Post — 11-20-2010 09:37 PM
