Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 03-11-2018, 07:13 PM
Ddub's Avatar
Ddub Ddub is offline
Currently: Not set.
Ddub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond repute
Default 1100 4 stroke clutch on m1000
I know they are both 35mm taper but does it work?
Rate this post: Yes | No
  #2
Old 03-12-2018, 02:25 PM
Ddub's Avatar
Currently: Not set.
Default
Someone must of tried this and no if it works or not.
  #3
Old 03-13-2018, 07:42 AM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
if I remember the offset was too far off to make it work. set them on the bench next to each other and you will see the fixed chive is about 1/2" off.
FWIW this was a long time ago.
  #4
Old 03-13-2018, 07:58 AM
Ddub's Avatar
Currently: Not set.
Default
That's what I was thinking, I don't have one to compare. Would be nice to put the team primary on. Wonder if you could have a 800 team cut to work on the 1k?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — ProClimb 1100 4-stroke side panel Thread Starter — TNTCOPP Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 0 Last Post — 12-26-2014 06:52 PM
Thread — 800 clutch puller same as 1100? Thread Starter — JBIZ Forum — Arctic Cat: 1100 ProClimb Replies — 6 Last Post — 01-21-2013 01:08 PM
Thread — Stainless 2-brothers racing pipe for 1100 four stroke AC Thread Starter — Jeff C Forum — Pipes/Cans (Swapmeet) Replies — 2 Last Post — 12-14-2012 09:07 AM
Thread — 4-stroke Clutch Balancing Thread Starter — justinkredible56 Forum — Yamaha: 4-Stroke Replies — 14 Last Post — 10-15-2011 09:13 AM
Thread — HMMMMMM! 800 OR 1100 TURBO 4 STROKE WHAT U BUYIN! Thread Starter — martin1200 Forum — Arctic Cat: Proclimb M Replies — 17 Last Post — 03-18-2011 09:09 PM
no new posts
