Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 03-10-2018, 09:33 PM
99xc700 99xc700 is offline
Currently: Not set.
Basic Member
99xc700 is an unknown quantity at this point
Default Silber turbo clutching for wa
So after fighting the 850 silber kit since day one breaking spring perches off, blowing the air box off a lot, sending the ecu back to silber only to get zero information back out of them. Now calling to get clutching help and all you get is stack more weight on the pivot bolt. Marked the clutches today and started making pulls and doing some tree riding. Only using the first half of the secondary and leaving a 1 inch mark on the outer edge of the primary. Primary has SHR ramps loaded with tungsten and 170/300 spring secondary is set up with what silber supplies. Anybody in Washington actually get one to work? Have two doing the exact same thing. Riding between 2500 and 7000 feet.
Rate this post: Yes | No
  #2
Old 03-11-2018, 06:19 PM
islanddoo's Avatar
islanddoo islanddoo is offline
Currently: Waiting on the G4
islanddoo has a reputation beyond reputeislanddoo has a reputation beyond reputeislanddoo has a reputation beyond reputeislanddoo has a reputation beyond reputeislanddoo has a reputation beyond reputeislanddoo has a reputation beyond reputeislanddoo has a reputation beyond reputeislanddoo has a reputation beyond reputeislanddoo has a reputation beyond reputeislanddoo has a reputation beyond reputeislanddoo has a reputation beyond repute
Default
While I’m not in WA I am on the west coast riding the same snowpack. Sled and clutching have been flawless once clutched. Running pretty much the same set up as you, 170/300 primary spring with BJ’s ramps with 6g in them and 4g on the pivot bolt. Silber supplied secondary clutching grin spring and 43/47 Helix. Very consistent from Western BC to Revelstoke no belt issues just 8000 rpm all day. Running 5 psi spring.
  #3
Old 03-14-2018, 12:33 PM
Currently: Not set.
Basic Member
Default
Yeah sounds just like my setup, mine never holds rpm and leaves a 1-1/4 sharpie mark on the primary sheaves and the belts throw cords
  #4
Old 03-14-2018, 02:50 PM
JJ_0909 JJ_0909 is offline
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
Default
Sorry to hear of your troubles!
Building one clutch kit for all uses, elevations, boost levels etc can be a challenge. There are also massive differences, it seems, sled to sled as far as clutching. This is also reflected on the NA side of things.
A few things can really help what you are describing.
First, give a flat 44 a try. Keep the spring Silber sends in there.
Second, go to the ZRP weights. Go with the heavy ones (95) and load them pretty well.
Start there. Anyone having issues, this will likely clear most of them up.
  #5
Old 03-14-2018, 09:57 PM
Currently: Not set.
Basic Member
Default
I understand that clutching changes based on every sled and elevation and knew it wouldn’t come perfect but a little bit of customer service would be nice. Stacking pivot weight on a longer bolt is a ****ing joke and no where near a fix for clutching. I’d rather throw this kit away then waste more money trying to fix something Silber has no desire to help me correct.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #6
Old 03-15-2018, 08:46 AM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Any idea what the Silber helix is? A 43/47 as Islanddoo is using is a good starting point for a turbo...you should be able to work around that using the SHR ramps and your existing springs.
  #7
Old 03-15-2018, 09:16 AM
Currently: Not set.
Default
Quote:
First things first, my name and email is listed right on the website. I am positive I've never seen an email from you. I jumped on this right as I saw it hit the boards! Sorry to hear clutching has been a challenge in your case but I can't help if I don't know about it!
Second, have you tried gearing the sled differently? Have you swapped to the low elevation ramps? What belt (specifically) are you riding?
As I mentioned, ZRP weights (95 gram) will cure your issue! I'd also consider gearing up two teeth!
The rest of your setup is fine.
  #8
Currently: Not set.
Default
Quote:
Its a 43/47
SHR ramps are good, but they aren't as good at low elevation as they are higher elevation.
  #9
Old 03-15-2018, 10:13 AM
Currently: Not set.
Basic Member
Default
You are correct I have never emailed anyone off the website I prefer to call and speak directly with people to make sure all the information is exchanged and understood. I don’t know who you are on the website but the last person that actually answered a call and spoke with me was James and he told me to put the primary back to stock and go buy longer bolts at the hardware store and stack more weight on the bolt. After that exchange I decided I was done dealing with Silber and asked for information online from other sledders.
Gearing 21/51 changed from updated 21/53
Tried 531-391-and gates belts.
SHR ramps loaded up with tungsten 967 I believe
I have not geared up as that has always compounded belt issues on previous turbo’d sleds.
  #10
Old 03-15-2018, 10:19 AM
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 850 Silber Turbo clutching ?'s Thread Starter — KevinW Forum — Ski-Doo: REV Gen 4 Replies — 2 Last Post — 01-22-2018 03:37 PM
Thread — Silber turbo etec clutching and afr Thread Starter — Marcusx200 Forum — Ski-Doo: TURBO Replies — 15 Last Post — 11-28-2017 02:59 AM
Thread — Silber Axys Clutching Thread Starter — WyoPro Forum — Polaris: TURBO Replies — 115 Last Post — 01-30-2017 01:53 PM
Thread — Silber Turbo Clutching Thread Starter — Dirty10 Forum — Polaris: TURBO Replies — 2 Last Post — 12-15-2012 05:00 PM
Thread — silber 700 clutching? Thread Starter — jr700 Forum — Polaris: TURBO Replies — 13 Last Post — 04-24-2010 11:59 AM
no new posts
