Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 03-07-2018, 08:43 AM
ncandrick ncandrick is offline
Currently: Not set.
Basic Member
ncandrick is an unknown quantity at this point
Default 1999 Vmax Sx 700 Triple Help
Hi I have a 1999 Vmax Sx 700 Triple. The engine was replace by a previous owner so it has unknown miles. It is a red top 700 triple. Fist when I was having trouble with my sled I was bogging out every time I went to go full throttle. I did a compression test and it came 90 psi in each cylinder. So I went to a dealer bought new gaskets, pistons, and rings. Took the engine apart and put the new parts in. When I put the new gasket on the top, I cut the ribbit holding them together and took the middle layer out to build more compression. When I put everything back together, I did another compression test. It came out as 100 psi in each cylinder. I figured it was bad seals in the crank. So we bought a known good crank from a sled that had bad pistons. The sled that the crank came from was a 2001 sxr red top motor. I switched the cranks. Putting everything back together I noticed that the plugs from stator was different. So I took the recoil off my original crank. I've own this sled for 2 years and its the first time I've taken the recoil off. When I taken it off I noticed the fly wheel nut was missing. So I think this is the reason why my sled wasn't running right. But any way I switched the plugs from the stator. Now every things back together. I took the sled down the street and back. Now it sounds like its running on two cylinders. The cylinder furthest from the PTO side isn't firing. So I put a never been used BR9ES spark plug in. Still sounds like its running on two cylinders. So I did another compression test and i'm still reading 100 psi. Am I doing something wrong? Everything is torque to specs. I put in new gaskets for everything. Carbs have been cleaned recently.
Rate this post: Yes | No
  #2
Old 03-07-2018, 08:21 PM
jm jm is offline
Currently: Not set.
jm is a splendid one to beholdjm is a splendid one to beholdjm is a splendid one to beholdjm is a splendid one to beholdjm is a splendid one to beholdjm is a splendid one to beholdjm is a splendid one to beholdjm is a splendid one to beholdjm is a splendid one to beholdjm is a splendid one to beholdjm is a splendid one to behold
Default
Do you have spark onbad cylinder
  #3
Old 03-07-2018, 08:39 PM
Currently: Not set.
Basic Member
Default
Quote:
yes i took all the spark plugs out and pulled it over to see if i had spark.
  #4
Old 03-07-2018, 08:40 PM
Givemeaboost's Avatar
Givemeaboost Givemeaboost is online now
Currently: Not set.
Givemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond repute
Default
Did you check the reeds ?
Ken..........
__________________
03 rx1 mtn with homebuilt turbo , 159 finger track , Rev tank and seat. 01 Mountain Max
  #5
Old 03-07-2018, 08:53 PM
Currently: Not set.
Basic Member
Default
Quote:
Ken..........
No, but my carbs have been cleaned twice now.
  #6
Old 03-07-2018, 09:47 PM
700redsled 700redsled is online now
Currently: Not set.
Basic Member
700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute700redsled has a reputation beyond repute
Default 99sx
pilot jets very small sure they are clean
  #7
Old 03-08-2018, 07:14 PM
Currently: Not set.
Basic Member
Default
Quote:
Ya there clean, but that wouldn't be my problem if I only have a 100psi of compression. I did some research online and they say to take a feeler gauge and put your rings in the jug and see what the space between the openings of the rings. Dose anyone know what I should have for space between the rings. Im not shore if my jugs are bored out. Could I go with oversize rings? Or do I try running it on the trail to see if the rings sit in?
  #8
Old 03-08-2018, 07:36 PM
Currently: Not set.
Default
You've got compression and spark. Check the reads. It's got to be a fuel problem.
Ken..........
__________________
  #9
Old 03-08-2018, 08:01 PM
Currently: Not set.
Basic Member
Default
Ken..........
I dont have the compression I should be running at 120-130 psi for a minimum.
  #10
Old 03-09-2018, 08:57 AM
..SNAKEBIT..'s Avatar
..SNAKEBIT.. ..SNAKEBIT.. is online now
Currently: waiting for snow
..SNAKEBIT.. has a reputation beyond repute..SNAKEBIT.. has a reputation beyond repute..SNAKEBIT.. has a reputation beyond repute..SNAKEBIT.. has a reputation beyond repute..SNAKEBIT.. has a reputation beyond repute..SNAKEBIT.. has a reputation beyond repute..SNAKEBIT.. has a reputation beyond repute..SNAKEBIT.. has a reputation beyond repute..SNAKEBIT.. has a reputation beyond repute..SNAKEBIT.. has a reputation beyond repute..SNAKEBIT.. has a reputation beyond repute
  #11
Old 04-25-2018, 02:35 AM
lukaskupasz lukaskupasz is offline
Currently: Not set.
Basic Member
lukaskupasz is an unknown quantity at this point
Click Here to Register
  #12
Old 10-17-2018, 08:25 AM
MD1's Avatar
MD1 MD1 is offline
Currently: Not set.
MD1 is an unknown quantity at this point
Reply
Bookmarks
Tags
yamaha engin troubles
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — WTB: Yamaha SXR- Vmax triple pipes Thread Starter — steveo6487 Forum — Pipes/Cans (Swapmeet) Replies — 0 Last Post — 10-26-2009 07:46 PM
Thread — F/S 2002 Mountain Max, 1999 VMAX 500 Thread Starter — 1slo_MM Forum — Yamaha (Swapmeet) Replies — 12 Last Post — 08-13-2008 07:19 PM
Thread — ENGINE PARTS NEEDED (1999 XCR 440 GENII and 1999 XC 700 SP) Thread Starter — leadmine_sledder Forum — Polaris Replies — 0 Last Post — 12-23-2007 08:35 PM
Thread — ENGINE PARTS NEEDED (1999 XCR 440 GENII and 1999 XC 700 SP) Thread Starter — leadmine_sledder Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 12-23-2007 08:33 PM
no new posts
