Upgrade to Premium
Reply
  #1
Old 03-06-2018, 06:24 PM
Nickhagen1 Nickhagen1 is offline
Currently: Not set.
Basic Member
Nickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud of
Default Is clutching a 4s the same as clutching a 2s?
Posting in leu of an argument. A buddy of mine says you have to clutch a 4s just as you would a 2s for elevation. Is he correct? To my knowledge and everything I’ve read on here.... you clutch a 4s dependent on rpm range and what you are doing with the sled. Idk, maybe I am completely wrong and need some schooling.
Please help as I want to know what to do.
Thanks
Nick
Rate this post: Yes | No
  #2
Old 03-07-2018, 10:37 AM
jim jim is online now
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
You clutch for RPMs and response and backshifting. Always a balance with any motor.
IMO, clutching a 4stroke is much easier because the powerband is much wider and more forgiving. You also don't have motor loading up issues on 4s as easy on 2s if you are not clutched correctly.
2s have to be clutched closer to hit and stay at peak RPM...they fall off the pipe easier and jetting is more sensitive.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M7 Clutching and Clutching Related Info Thread Starter — Stack Forum — Arctic Cat: M Series Replies — 4 Last Post — 03-25-2015 09:22 AM
Thread — Clutching - Clutching - MAINTENANCE (primary and ramps) Thread Starter — Dynamo^Joe Forum — Ski-Doo: XP Sleds Replies — 1 Last Post — 11-07-2013 01:41 PM
Thread — m7 clutching Thread Starter — J almont Forum — Arctic Cat: M Series Replies — 8 Last Post — 09-27-2011 05:41 PM
Thread — M7 Clutching and Clutching Related Info compiled by "Upjohn" Thread Starter — KSH Forum — Clutching Replies — 0 Last Post — 09-27-2010 07:32 PM
Thread — 07 M8 Clutching Thread Starter — offtrail Forum — Arctic Cat Replies — 10 Last Post — 12-18-2007 09:23 PM
no new posts
