Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 03-05-2018, 08:19 PM
xpspenziv's Avatar
xpspenziv xpspenziv is offline
Currently: boooasting
xpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond repute
Default TRS Indy highbred
II have Tonys set up and happy with it. I rode a buddies sled that has a home built turbo with a Indy Mountain 1 helix. It pulled pretty good so I decided to order 1 up. John recommended a sec spring to try with it. Oh boy does it really pull hard. Night and day. It is still super smooth engagement. No more revy feeling. I thought I would share my findings. It truly is an arm stretcher now.
#7 straight av gas.. 3000-6000ft Pulls 8300-8350 consistently. Never an issue since new.
76 lightning wts. old school.
pri, almond gold poo spring.150-290
sec, black spring from Indy. Stock poo spring I believe. Its light.
Rate this post: Yes | No
The Following 2 Users Say Thank You to xpspenziv For This Useful Post:
TRS (03-05-2018), WAsledder (11-08-2018)
  #2
Old 03-05-2018, 10:50 PM
xpspenziv's Avatar
Default
It's a little steeper.
  #3
Old 03-06-2018, 09:10 PM
sledhead9825 sledhead9825 is online now
Currently: Not set.
sledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond repute
Default
What turbo kit are you running?
  #4
Old 03-06-2018, 10:55 PM
Spaarky's Avatar
Spaarky Spaarky is online now
Currently: Moved Into Maximum Security Cell
Spaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond repute
Default
Is there a number on the spring?
  #5
Old 03-07-2018, 09:04 AM
xpspenziv's Avatar
Default
It's a silber on a 2017 axys. No sparky. The spring has been re painted black. John told me it was a lighter spring than what I was running. I also when back to stock gearing. I think going up 2 teeth on the top gear was asking a little much. Belt was glazing and showing signs of heat. Torn 1 belt a little on a long bumpy on off pull. It felt like a flat spot when you forget to release ebrake. Since going back to stock gearing no glazing of the belt, no black marks in the sheaves ( never was an issue ) and dust is nearly nonexistent after 4-5 rides. Since the change my top speed went up to 81mph from 76mph. A 174-3" shouldn't go that fast across the lake in freshy. Still super responsive in the tree's on off throttle. Definitely more track speed down low. I'm having to cover the brake more and better throttle control to keep the speed over ground down. I've tried alot of different set ups helping give some input on this subject thanks to some of the guys on the TRS clutching pages. This is by far the most arm stretcher I've come up with yet since the 2016-17 season. I hope some try this and like it.
Thanks to all the guys I've poked and prodded with questions. Great group of guys on here. I have spare helix's and spring's if ya need something. I feel I've found my qwan. Hahahaha.
  #6
Old 03-07-2018, 09:09 AM
xpspenziv's Avatar
Default
Sparky. I chipped the paint and it's black under the new paint job. Without using a micrometer it's looks just like my stock black spring. Size of wire, winding and hight.
  #7
Old 03-07-2018, 11:55 AM
Spaarky's Avatar
Default
All Polaris springs come black now. Just different numbers.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — TRS clutching NA Thread Starter — Norway Forum — Polaris: AXYS Replies — 256 Last Post — 01-01-2019 11:21 PM
Thread — TRS Clutching Thread Starter — tdbaugha Forum — Polaris: TURBO Replies — 99 Last Post — 01-31-2017 09:03 AM
Thread — Get well Tony(TRS)!!!!!! Thread Starter — Spaarky Forum — Polaris: AXYS Replies — 16 Last Post — 11-26-2016 12:21 PM
no new posts
