Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 03-05-2018, 08:46 AM
The Grand Pooh-Bah The Grand Pooh-Bah is offline
Currently: Not set.
Basic Member
The Grand Pooh-Bah is an unknown quantity at this point
Cool What to Look For; 04 RMK 800 159
I'm going to go look at a 2004 Polaris Vertical Edge RMK 800 159 with new motor from Indy Specialties w/less than 200 miles on it. Has twin SLP pipes, fly bars, riser, powder pro skis, vent kit, 8" big wheel kit.
What should I look for that might be a problem or future problem?
Rate this post: Yes | No
  #2
Old 03-05-2018, 10:24 AM
BILTIT's Avatar
BILTIT BILTIT is online now
Currently: Never enough snow!!!
BILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond repute
Default
Overall condition and maintenance frequency/quality.
Lack of maintenance is the biggest killer of a snowmobile.
Should be a fine machine otherwise. I had a 03 800 rmk stretched to 162 with twin pipes and only 1400 miles on it. I would highly recommend putting a holtzman atacc on it and never have to rejet again!
__________________
Derek B.
2000 440 xc sp 136 (EDGE)
2003 800 RMK 162
2004 910 PRO-XR 121x1.75", Wheelie Machine!!!
2011 LRod 13.6 800 ProRMK 3"PC KMOD/Raptors kmod 37" arms Ti can
  #3
Old 03-05-2018, 12:06 PM
BeartoothBaron BeartoothBaron is online now
Currently: Not set.
BeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond repute
Default
BILTIT hit it pretty well, if it's been kept in tip-top shape, that's worth a lot. Having recently torn down an '03 800 RMK that hadn't been kept up so well (4700 miles, but still), here's what I found that wasn't obvious at first inspection: clutch weight bushings completely worn through, to the point of rubbing on the spider; driveshaft bearing nearly gone; front and rear torque arms bent (front especially; the rear I was able to massage back to shape). I'd say always do a compression check, pull the plugs and look at them and the cylinders, look over the clutches for abnormal wear. Also, look closely at trailing arms and radius arms, check for wrinkles in the tunnel, bulkhead, and belly pan – anything that would indicate a wreck. Good luck!
  #4
Old 03-05-2018, 03:02 PM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is online now
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default
Rear bogie wheels are toast at 2500 miles, if they have not been replaced with high quality bearings. Not the $2.50 bearings. The bottom of footwell may show buckling or cracks from an impact. Which would require reinforcing. The front left, motor mounts blow out faster with extra horsepower. The water pump axle end notch may be over ground from the oil pump. The oil pump may not turn smoothly. The center bolt in the chaincase lower gear, may be loose. Left side drive axle bearing may be toast because it requires regular greasing that few people do. And look for both front and the rear rear shock to need either refilling, rebuilding or replacement. And they aren't cheap.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — F/S 2005 Edge RMK 800 159 or trade for RMK 700 - WY Thread Starter — RottenScummyTroll Forum — Polaris (Swapmeet) Replies — 1 Last Post — 12-06-2010 04:03 PM
Thread — 04 800 rmk 159 Thread Starter — IDAHO HOT SHOT Forum — Polaris (Swapmeet) Replies — 0 Last Post — 02-16-2009 11:01 PM
Thread — '05 800 rmk 159 Thread Starter — flatfoot Forum — Polaris (Swapmeet) Replies — 5 Last Post — 12-15-2008 06:57 PM
Thread — 2004 Rmk 800 Vertical Escape 800 159" In Washington Thread Starter — STROKEDIESEL Forum — Polaris (Swapmeet) Replies — 4 Last Post — 03-17-2008 11:54 AM
no new posts
