Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 03-05-2018, 03:42 AM
kniveton kniveton is offline
Currently: Not set.
Basic Member
kniveton is an unknown quantity at this point
Default 2009 M8 Engine Problems
Last weekend my 2009 M8 died on me. We were snowmobiling in 2-4 feet of powder. After a couple hours, the engine began having issues. When hitting the throttle from idle, the engine died. A few minutes later I was let off the throttle from full to about 1/3 and it the engine dropped down to idle and almost died. This happened again another time. The sled ran fine on full throttle for a while. About 10 minutes later I stopped on the flat and the sled was idling for about 2 minutes while I was talking to someone. When I went back to ride and squeezed the throttle, the engine died completely. It wouldn't start. It has half a tank of gas and 1/2 a tank of oil. I pulled the starter rope at least 50 times, even trying with my friend holding the throttle 1/4 and 1/2 open; nothing worked. I let the sled sit for 10 minutes and tried again. It started up on the first pull, and ran for about 2 seconds before dying. The electronics were receiving power-- I could see the speedometer light up and the odometer needle moved up during the 2 seconds it would run. After dying it would not start up again. However, if I would let the sled sit for 10 minutes it would always start up for a second or two. This happened a couple times. Nighttime was quickly approaching and we were far away from the highway so we had to leave the sled without doing any field repairs. One of my neighbors has a snowcat and agreed to tow it out. I'm planning to meet him up there soon. Before he does tow the sled out, are there any simple field fixes I could try? Thanks
Rate this post: Yes | No
  #2
Old 03-05-2018, 07:52 AM
Sledbrain2 Sledbrain2 is offline
Currently: Not set.
Basic Member
Sledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond repute
Default
sounds like ignition coil on stator, or a wire rubbing, Many times if you let the engine cool it will start then die or not run up to rpm as a sign for a bad stator.
  #3
Old 03-05-2018, 05:05 PM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
Not arguing the above, but you should also check the throttle safety switch and make sure it didn't ice up with all the powder...which sometimes happens.
  #4
Old 03-05-2018, 06:30 PM
Currently: Not set.
Basic Member
Default
I did try messing around with the throttle safety switch but that didnít seem to help. Could it be something with the kill switch? Is there a way to disconnect it? On my ~20 year old ZR you could easily disconnect the cable right on the handlebars to bypass the kill, but I didnít see any easy way to do so with the m8.
  #5
Old 03-05-2018, 06:38 PM
snowmobiler snowmobiler is offline
Currently: Not set.
snowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond reputesnowmobiler has a reputation beyond repute
Default
new plugs?
  #6
Old 03-05-2018, 06:44 PM
Currently: Not set.
Basic Member
Default
Possibly, but it didnít seem likely since during the 1-2 seconds the engine would run after sitting for a few minutes it would run normally. Before it died completely it was running fine, even after the first time it initially died. When Iíve had plugs go bad previously the engine would run awfully and/or only one cylinder would run. Is this not always the case?
  #7
Old 03-05-2018, 11:15 PM
jim jim is offline
Default
Bypass throttle safety switch and then kill button. Trace wire runs and look for grounding out. It does sound like a stator though if no grounding wires are found. I had a similar issue on m1000 before. Also check plig wires and caps.
  #8
Old 03-05-2018, 11:36 PM
corydoneen corydoneen is offline
Currently: Not set.
corydoneen has a reputation beyond reputecorydoneen has a reputation beyond reputecorydoneen has a reputation beyond reputecorydoneen has a reputation beyond reputecorydoneen has a reputation beyond reputecorydoneen has a reputation beyond reputecorydoneen has a reputation beyond reputecorydoneen has a reputation beyond reputecorydoneen has a reputation beyond reputecorydoneen has a reputation beyond reputecorydoneen has a reputation beyond repute
Default
Water in electrical connection is where I would start looking take every single one apart and put di electric grease in them. I had similar issue and thought it was stator replaced it right away same issue checked every connection and found water in a couple.
  #9
Old 03-06-2018, 03:04 PM
Currently: Not set.
Basic Member
Default
Quote:
I did briefly try and trace the cable but it went behind a panel that required torx screws to remove, which I didn't have on me. If possible, I'd like to avoid as much field disassembly as possible. Does anyone know exactly where the disconnect is?
  #10
Old 03-07-2018, 10:40 AM
Skywest Skywest is offline
Currently: Not set.
Basic Member
Skywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond repute
  #11
Old 03-07-2018, 03:44 PM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 03-07-2018, 06:00 PM
jim jim is offline
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Engine problems Thread Starter — Bert the bod Forum — Polaris: 900 Replies — 16 Last Post — 02-09-2010 10:28 PM
Thread — 800 2009 engine, 2010 pistons, 2009 head, 2009 calibration? Thread Starter — Garrett Forum — Polaris: IQ Replies — 0 Last Post — 12-23-2009 07:32 PM
Thread — Engine problems Thread Starter — RMK42 Forum — Polaris Replies — 6 Last Post — 07-27-2009 09:53 AM
Thread — '05 M6 engine problems Thread Starter — Modmo Forum — Arctic Cat Replies — 8 Last Post — 02-06-2008 11:11 AM
no new posts
