Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 03-04-2018, 01:11 AM
O.B. O.B. is online now
Currently: name
O.B. has a reputation beyond reputeO.B. has a reputation beyond reputeO.B. has a reputation beyond reputeO.B. has a reputation beyond reputeO.B. has a reputation beyond reputeO.B. has a reputation beyond reputeO.B. has a reputation beyond reputeO.B. has a reputation beyond reputeO.B. has a reputation beyond reputeO.B. has a reputation beyond reputeO.B. has a reputation beyond repute
Default 850 silber turbo
Has any body got a good set up for 7 psi . I put the seven pound spring in it and all the weight on longest bolt and after around 7 seconds at wot hits rev limiter. So switched 5 pound spring better but same problem. So I got heavier bolt and is way better. But don't want run 5 psi. Have stock 17 gearing and ride at 6000 to 8000 feet. I am running 70 percent 110 fuel. All set in my clutches came with the kit.
Rate this post: Yes | No
  #2
Old 03-04-2018, 01:31 AM
Devilmanak Devilmanak is online now
Currently: 2683 miles - 15-16
Devilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond repute
Default
Not sure, I may have the specs for a gold turbo. But they cost a lot more.
The Following User Says Thank You to Devilmanak For This Useful Post:
PaulAnd (03-04-2018)
  #3
Old 03-04-2018, 05:01 PM
grizzly7's Avatar
grizzly7 grizzly7 is offline
Currently: Waiting for my Silber and TKI to be installed!!
grizzly7 has a reputation beyond reputegrizzly7 has a reputation beyond reputegrizzly7 has a reputation beyond reputegrizzly7 has a reputation beyond reputegrizzly7 has a reputation beyond reputegrizzly7 has a reputation beyond reputegrizzly7 has a reputation beyond reputegrizzly7 has a reputation beyond reputegrizzly7 has a reputation beyond reputegrizzly7 has a reputation beyond reputegrizzly7 has a reputation beyond repute
Default
Never heard of a Silver Turbo?? But My Silber turbo clutching that they included with the kit is spot on!! Only thing I changed was put in Sled Head Racing adjustable weights so I can make easy adjustments at sea level or up at elevation.
  #4
Old 03-05-2018, 09:45 AM
JJ_0909 JJ_0909 is offline
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
Default
Your best option in this case is going to be gearing up a bit and going to ZRP or SHR ramps.
The Following User Says Thank You to JJ_0909 For This Useful Post:
steve vinot (10-13-2018)
  #5
Old 03-06-2018, 08:27 AM
catmanm7 catmanm7 is offline
Currently: Not set.
catmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond reputecatmanm7 has a reputation beyond repute
Default
JJ what are you recommending for a starting point on the adjustable weights per psi and elevation.
  #6
Old 03-06-2018, 02:31 PM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is offline
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
Default
IIRC we had the ZRP weights at around 98G for 7psi at 8-10k feet last spring doing some testing.
__________________
Wheelhousemotorsports@gmail.com
406-871-0955 Bozeman, MT
The Following User Says Thank You to Wheel House Motorsports For This Useful Post:
catmanm7 (03-06-2018)
  #7
Old 03-06-2018, 03:19 PM
Currently: Not set.
Default
Quote:
I must have a strong one! I'm at 98 at 5psi at 8000. 200/340 primary spring. Silber secondary. I still see 8100
  #8
Old 03-09-2018, 02:29 PM
turbo800's Avatar
turbo800 turbo800 is offline
Currently: GOT BOOST???
turbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond reputeturbo800 has a reputation beyond repute
Default
Quote:
I believe he recommended +2 grams for every psi boost over stock
__________________
Toy Box
'17 Summit SP 850 165 x 3"- MPI 200HP turbo
'09 Summit X 800R 163 (Blk/Blu)- Stocker
'05 Summit X RT1000 - CS1240 Big Bore Kit 174"
CR500AF / '14 Timbersled 120 ST - Snowbike
'98 YZ 250 - Setup for single track trails
The Following User Says Thank You to turbo800 For This Useful Post:
catmanm7 (03-10-2018)
  #9
Old 03-12-2018, 08:23 AM
Newbacon Newbacon is offline
Currently: Not set.
Basic Member
Newbacon is an unknown quantity at this point
Default Silber 850
Need a little help. Installed Silber turbo on my 2018 850 skidoo. From day one if I hold throttle open for 40 seconds it cuts out. Runs fine if i'm in and out of the throttle. Running 50% Avg Gas with 91 pump gas.. Top RMP 8000.. Running with 7 lb spring.
Thanks,
  #10
Old 03-13-2018, 08:54 AM
Currently: Not set.
  #11
Old 03-24-2018, 09:40 AM
Currently: name
Click Here to Register
  #12
Old 03-26-2018, 07:00 AM
Currently: Not set.
  #13
Old 03-26-2018, 11:08 AM
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Sonic, the Turbo Systems from Turbo Performance for your 850 is here Thread Starter — brycter Forum — Ski-Doo: TURBO Replies — 5 Last Post — 11-21-2016 09:45 PM
Thread — Sneak Peak: Turbo Performance's 850 Turbo Systems are almost here Thread Starter — brycter Forum — Ski-Doo: TURBO Replies — 5 Last Post — 11-15-2016 09:39 PM
Thread — Simmons Gen 1 Black/Silver w Silver loops, new Thread Starter — fourthmeal Forum — Skis (Swapmeet) Replies — 2 Last Post — 10-07-2008 04:33 PM
no new posts
