Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 03-03-2018, 10:26 AM
polarisboyc polarisboyc is offline
Currently: Not set.
polarisboyc has a reputation beyond reputepolarisboyc has a reputation beyond reputepolarisboyc has a reputation beyond reputepolarisboyc has a reputation beyond reputepolarisboyc has a reputation beyond reputepolarisboyc has a reputation beyond reputepolarisboyc has a reputation beyond reputepolarisboyc has a reputation beyond reputepolarisboyc has a reputation beyond reputepolarisboyc has a reputation beyond reputepolarisboyc has a reputation beyond repute
Default Silber Axys keeps detonating
I've got a '17 axys running a silber kit and i've been fighting it all year with detonating. I've ran it anywhere from 7,000-10,000 ft. With race gas and without race gas, on eth mode and off eth mode, 3 lb, 5lb, and 7lb. I've changed springs and helix and weights and for some reason just wants to det when I'm in and out of the throttle. Wide open pulls are fine but whenever I'm boondocking it wants to do it. I'm currently running a a lime green spring in the front, black and silver in the back with a 48 straight helix. Weights are venom, loaded lightest in the middle, second lightest at the heel, and heaviest at the toe weighing at 76 grams. I want to put an almond spring in the front and was thinking of moving the weight around from the heel to the mid. Any insight would be very much appreciated!!
Rate this post: Yes | No
  #2
Old 03-03-2018, 10:49 AM
doudea's Avatar
doudea doudea is offline
Currently: waiting.......
doudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond reputedoudea has a reputation beyond repute
Default
If you have run it on race gas, im assuming it is not an octane issue. With that i prefer av gas 100ll, as it is more stable than race fuel. Race fuel loses its octane ratting relativly quickly. At 7lbs im mixing 2gal of 100ll to 3gal of 91non ethonal. I am also premixing 100:1 with injection oil for insurance purposes. Running in the ethonal mode on the sled.
I would suspect that the det sensor may have issues. I dont know off the top of my head but the sensor needs to be torqued to a specific range to function properly. It also has a specific angle that it needs to be oriented too, with relation to the cylinder head. I would research those two to make sure your not getting a false det reading. This is where i would start.
Checking that the waste gate is operating smothly is something else i would check. With the spring out, you should be able to pull it up and push it down with out any resistance.
As far as my clutching set up at 7lbs, im running team almond primary spring with venoms at 74g red slugs in the tip and heel, blue in the middle. Secondary i have settled on 40/46 helix with the team black/silver spring.
  #3
Old 03-03-2018, 10:52 AM
doudea's Avatar
Default
With that i know just enough to be dangerous.......,
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #4
Old 03-03-2018, 10:54 AM
Currently: Not set.
Default
Thanks for the feedback! I'll check my waste gate and the det sensor. I put my 3 lb spring in this last weekend riding around 8,000 ft with premium and it was still detonating. Thats why I'm not sure if octane is the problem but maybe I should start running 100 just to be safe.
  #5
Old 03-03-2018, 10:58 AM
doudea's Avatar
Default
It most definitely shouldn’t be detonating with the 3lb spring. With that I highly suspect the sensor is throwing false det readings.
The Following User Says Thank You to doudea For This Useful Post:
Snowman.PRO. (09-21-2018)
  #6
Old 03-03-2018, 11:00 AM
Currently: Not set.
Default
Thats kind of what I'm thinking too. Have you heard of any det sensors going out on these sleds?
  #7
Old 03-03-2018, 11:11 AM
doudea's Avatar
Default
Honestly not, but on my previous turbo pro which uses the same Det sensor I experienced false det codes. Because I didn’t get it torqued properly. I know it is very sensitive to angle and proper torque. I believe it works off changing electrical resistance that reacts to harmonics put off by the engine. So when det is occurring in the engine a significantly different harmonic is occurring which is what the det sensor triggers off of. So with improper setup it can be inaccurate.
Again don’t take this to the bank, because I honestly know just enough to confuse myself.
  #8
Old 03-03-2018, 11:17 AM
Currently: Not set.
Default
No thats some good info, I appreciate it. I'm almost to the point of taking the stupid thing off and wrapping some foam around it or something
  #9
Old 03-03-2018, 11:57 AM
turboless terry's Avatar
turboless terry turboless terry is online now
Currently: Not set.
turboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond reputeturboless terry has a reputation beyond repute
Default
Shouldn't have det with 5 pound spring at that elevation. I built a 16 silber axys and ran 5 pound spring on pump. I sold it to my buddy and he still runs it the same. Unless they changed compression or timing or something, on the 17, you have over rev or something else going on.
  #10
Old 03-03-2018, 12:02 PM
Currently: Not set.
  #11
Old 03-03-2018, 12:29 PM
Currently: Not set.
Click Here to Register
  #12
Old 03-03-2018, 01:32 PM
Octanee Octanee is offline
Currently: Not set.
Octanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond repute
  #13
Old 03-03-2018, 02:16 PM
Currently: Not set.
  #14
Old 03-03-2018, 02:18 PM
Dazzler's Avatar
Dazzler Dazzler is offline
Currently: Not set.
Dazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond repute
  #15
Old 03-03-2018, 02:43 PM
Currently: Not set.
  #16
Old 03-03-2018, 03:18 PM
snoballssnoglory's Avatar
snoballssnoglory snoballssnoglory is offline
Currently: Not set.
snoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond repute
The Following User Says Thank You to snoballssnoglory For This Useful Post:
revrider07 (03-03-2018)
  #17
Old 03-03-2018, 04:47 PM
Currently: Not set.
  #18
Old 03-03-2018, 05:10 PM
Currently: Not set.
  #19
Old 03-03-2018, 05:58 PM
Currently: Not set.
  #20
Old 03-03-2018, 06:00 PM
Currently: Not set.
  #21
Old 03-03-2018, 06:02 PM
Currently: Not set.
  #22
Old 03-03-2018, 09:55 PM
Sage Crusher's Avatar
Sage Crusher Sage Crusher is offline
Currently: easing into Winter......
Sage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond repute
  #23
Old 03-04-2018, 01:15 AM
icr icr is offline
Currently: on another forum
Basic Member
icr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond repute
The Following User Says Thank You to icr For This Useful Post:
Spaarky (03-04-2018)
  #24
Old 03-04-2018, 06:34 AM
Spaarky's Avatar
Spaarky Spaarky is online now
Currently: Moved Into Maximum Security Cell
Spaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond reputeSpaarky has a reputation beyond repute
  #25
Old 03-04-2018, 06:37 PM
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Why would you not have a Silber turbo axys? Thread Starter — Wheel House Motorsports Forum — Polaris: TURBO Replies — 32 Last Post — 12-01-2017 08:41 PM
Thread — 2015 pro W/ Silber Detonating Thread Starter — snowcheck163 Forum — Polaris: TURBO Replies — 17 Last Post — 01-09-2017 09:42 PM
Thread — New Silber kit for the Axys!! Thread Starter — Boston Racing Forum — Polaris: TURBO Replies — 8 Last Post — 04-19-2016 04:18 AM
Thread — why is it detonating Thread Starter — mr990 Forum — Arctic Cat Replies — 7 Last Post — 02-13-2008 09:28 AM
