Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 03-01-2018, 09:31 PM
k_newman66 k_newman66 is offline
Currently: Not set.
Basic Member
k_newman66 has a reputation beyond reputek_newman66 has a reputation beyond reputek_newman66 has a reputation beyond reputek_newman66 has a reputation beyond reputek_newman66 has a reputation beyond reputek_newman66 has a reputation beyond reputek_newman66 has a reputation beyond reputek_newman66 has a reputation beyond reputek_newman66 has a reputation beyond reputek_newman66 has a reputation beyond reputek_newman66 has a reputation beyond repute
Default help. sled losing power when on and off throttle
i have a 13 800 with a boondocker tial exhaust, intercooled. been having issues when I'm in the trees wide open, i let off the throttle and get back on it real quick. when i give it full throttle again it has zero power and i get stuck or go rolling down the hill. the sled never dies. if I'm doing powder turns in a meadow and i am off and on the throttle it has no power when i let off and get back into it and 2 seconds later full power. i thought it was reeds(m1000 reeds), inspected them and only two very small chips in the corner, still sealing very well. going to replace them anyway. egts are 1250 wide open. ive tried boondockers numbers, other peoples numbers. could be bad numbers, not to savy on what numbers to change if that is it. not sure where to go from here. just very frustrating. thank you in advance.
Rate this post: Yes | No
  #2
Old 03-01-2018, 09:55 PM
Currently: Not set.
Basic Member
Default
i just cleaned the exhaust valves also and still have the problem
  #3
Old 03-02-2018, 10:11 AM
xpturbo600 xpturbo600 is offline
Currently: Not set.
Basic Member
xpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond repute
Default
Inspect your clutching. It sounds like you are losing massflow on the turbine wheel from rpms falling too low. The tune does not go bad. Also, check for boost leaks. There may be a crack, tear, or poor connection between the turbo and the block. Check boots, couplers, piping, the compressor housing, etc. Finally, inspect the pipe, header Y pipe, and seals for cracks as well. If your clutching is good, you have a boost leak that is preventing spool up and holding the motor down since it cannot pull the clutching off boost.
The Following User Says Thank You to xpturbo600 For This Useful Post:
k_newman66 (03-02-2018)
  #4
Old 03-02-2018, 01:29 PM
Currently: Not set.
Basic Member
Default
Thanks. I have a new 16 primary, new mds weights loaded all the way-85 grams, new spring. Team secondary. Tore it apart and looked fine. Too much weight in the heel? I can't really take any out or I'll have to drop my boost down. I'm already at 8400 rpm at 8lbs of boost
  #5
Old 03-02-2018, 05:53 PM
Currently: Not set.
Basic Member
Default
The weight is not the issue at full pull. Possibly, the helix is too aggressive at the starting angle assuming everything else is okay. Is this a new sled with untested clutching? Or, has it gotten worse with time when it worked well originally. It is hard to answer this because I have never ridden the sled. I would rule out boost or exhaust leaks before you imply the clutching is messed up. Otherwise, you may spend a bunch of cash on something that is okay.
k_newman66 (03-04-2018)
  #6
Old 03-04-2018, 08:57 AM
Currently: Not set.
Basic Member
Default
It was my secondary clutch. there was a little play in it side to side. i didn't think it was enough to make a difference besides belt wear. through on my old clutch and ran like a champ. thanks for the replies, never would of thought about the clutch
  #7
Old 03-07-2018, 01:09 AM
Currently: Not set.
Basic Member
Default
Good to hear you got it solved.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Losing power off trail Thread Starter — sledhead_79 Forum — Polaris: Pro-Ride Replies — 7 Last Post — 03-17-2018 11:47 AM
Thread — 01 rmk 700 losing power Thread Starter — Bcorn Forum — Polaris: GEN 2 Replies — 5 Last Post — 04-02-2014 07:20 AM
Thread — Questions about 800r losing power Thread Starter — jdgleason Forum — Ski-Doo: REV Sleds Replies — 8 Last Post — 12-09-2010 04:47 PM
Thread — 2000 Indy losing RPM's at full throttle? HELP!!! Thread Starter — nicksled24 Forum — Polaris: GEN 2 Replies — 4 Last Post — 03-06-2010 02:08 AM
Thread — losing power Thread Starter — rmk.powder Forum — Polaris Replies — 4 Last Post — 01-10-2009 04:50 PM
