Upgrade to Premium
Trucks and Trailers Towing and hauling your sleds
Reply
  #1
Old 02-28-2018, 01:16 PM
SpencerA SpencerA is offline
Currently: Not set.
SpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond repute
Default Where to start Fuel Pump on Trailer is not working
So Pump worked fine all weekend. Got home to fill up sleds in trailer and it turned on and then shut off 2 seconds later. Tried again and nothing. Waited 10 minutes and same thing it turned on for a couple seconds then shut off. Waited again and it actually worked and I filled a couple gallons into a can. Next day same symptom's. Is it most likely a bad pump motor going out? I would rather check all my other bases first as I have about 40 gallons of fuel in my tank and really don't want to have to drain it if it might be something else.
Rate this post: Yes | No
  #2
Old 02-28-2018, 07:45 PM
Currently: Not set.
Default
Checked for power and nothing. Checked fuse and looked ok. Changed it anyways and it worked. Glad it was a easy fix!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — dtc fuel pump drive circuit? sled wont start Thread Starter — k_newman66 Forum — Polaris: Pro-Ride Replies — 2 Last Post — 03-13-2016 09:14 PM
Thread — 500 EFI won't start, fuel pump runs continiously Thread Starter — snow guy Forum — Polaris: GEN 1 and older Replies — 4 Last Post — 03-26-2014 02:29 AM
Thread — need a non working fuel pump Thread Starter — skibumsd Forum — Arctic Cat: Proclimb M Replies — 1 Last Post — 09-19-2013 01:20 PM
Thread — fuel pump stopped working on 1100t Thread Starter — CyaFox Forum — Arctic Cat: 1100 ProClimb Replies — 0 Last Post — 01-15-2012 10:24 PM
Thread — 02 800 EFI fuel pump not working? Thread Starter — Sledbrain2 Forum — Arctic Cat Replies — 10 Last Post — 12-10-2007 06:20 PM
no new posts
