Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 02-28-2018, 10:51 AM
ScurbS ScurbS is offline
Currently: Not set.
Basic Member
ScurbS is an unknown quantity at this point
Default 2014 Polaris Assault 800
needing help with fuel mapping...have a polaris assault 800 with turbo running the power commander v (19-030-PTI) elevation is at 0-2000, using 120 octane as well
any help would be appreciated
Rate this post: Yes | No
  #2
Old 03-01-2018, 01:56 PM
ez-ryder ez-ryder is online now
Currently: Not set.
ez-ryder has a reputation beyond reputeez-ryder has a reputation beyond reputeez-ryder has a reputation beyond reputeez-ryder has a reputation beyond reputeez-ryder has a reputation beyond reputeez-ryder has a reputation beyond reputeez-ryder has a reputation beyond reputeez-ryder has a reputation beyond reputeez-ryder has a reputation beyond reputeez-ryder has a reputation beyond reputeez-ryder has a reputation beyond repute
Default
Back in 2012 there was an employee of dynojet posting on here as dynojet research.
He was promoting the product and seemed to have a handle on tuning with it.
Maybe he is still around?
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 03-01-2018, 03:09 PM
Currently: Not set.
Basic Member
Default thanks
im hoping to find any sort of help or direction on where to start on a baseline with the fuel mapping...
  #4
Old 03-02-2018, 11:14 AM
Currently: Not set.
Default
https://www.snowest.com/forum/showthread.php?t=397877
The person who posted here using it on a 700 might be a good resource.
Did dynojet research give you a starting point for fuel increase per pound of boost?
I was looking into running one of these on my d7. I thought the dynojet poster said they had a good starting point for fuel increase.
  #5
Old 03-02-2018, 07:32 PM
Currently: Not set.
Default
https://www.snowest.com/forum/showthread.php?t=410437
Another thread of somebody running that system.
  #6
Old 03-07-2018, 09:37 AM
Currently: Not set.
Basic Member
Question thanks
i have it hooked up, its just the whole fuel mapping im having issues with, i have tried dynojet and they dont have anything for me...she runs it just doesnt have have full power and there seems to be bog/hesitation on low end 2-4500rpm...top end has a pop which to me seems like its running lean, but as i add more fuel top end it bogs worse...
  #7
Old 03-07-2018, 10:21 AM
Currently: Not set.
Basic Member
Default
they basically give you a flat starting point, but i seem to be having trouble dialing in the right ratios and such...
  #8
Old 03-08-2018, 06:27 PM
Kenny B's Avatar
Kenny B Kenny B is offline
Currently: Boosted on the Rock!! :)
Kenny B has a reputation beyond reputeKenny B has a reputation beyond reputeKenny B has a reputation beyond reputeKenny B has a reputation beyond reputeKenny B has a reputation beyond reputeKenny B has a reputation beyond reputeKenny B has a reputation beyond reputeKenny B has a reputation beyond reputeKenny B has a reputation beyond reputeKenny B has a reputation beyond reputeKenny B has a reputation beyond repute
Default
Hey Scrubs, I have had just about every issue known I think... But may be I can help, Are you taking any timing out of the motor? What boost you running? 3.5-4 is about all your going to support at sea level. I'm running a viper now, but in the earlier days, I had a BD Timing chip, take three degrees out up top. Will help your detonation problem. Gap your plugs down to. Give us abit more info, I'll check back.
  #9
Old 03-09-2018, 11:39 AM
Currently: Not set.
Basic Member
Default ...
800 assault with the silber turbo (reflashed ECU as well) had 76g weights in it, dialed back to about 60-70ish cant remember exact weight, helped with the low end bog, i have the 5-6lbs boost in now...i do believe im heading in the right direction now as i raced a 1100 cat turbo on 16boost...i believe i had him...but we would see for sure tomorrow at the local snow drags...
  #10
Old 03-09-2018, 05:59 PM
Kenny B's Avatar
  #11
Old 03-10-2018, 09:48 AM
diamonddave's Avatar
diamonddave diamonddave is online now
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2014 Polaris Switchback Assault 800 parts Thread Starter — snowplease Forum — Gauges/Instrumentation (Swapmeet) Replies — 0 Last Post — 09-10-2017 11:11 PM
Thread — 2014 Polaris 800 Switchback Assault LE Thread Starter — dboe03 Forum — Polaris (Swapmeet) Replies — 3 Last Post — 10-29-2016 07:38 AM
Thread — 2014 polaris assault 800, 155 Thread Starter — matluc9doe Forum — Polaris (Swapmeet) Replies — 9 Last Post — 03-02-2015 11:24 PM
Thread — 2014 Polaris 800 Assault - Stock Thread Starter — c-dubwilf Forum — Polaris (Swapmeet) Replies — 0 Last Post — 08-27-2014 07:26 PM
Thread — 2014 Polaris Assault 800 155 Thread Starter — tluellen Forum — Polaris (Swapmeet) Replies — 0 Last Post — 04-02-2014 06:03 AM
no new posts
