Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 02-27-2018, 07:06 PM
rags319 rags319 is online now
Currently: Not set.
rags319 has a reputation beyond reputerags319 has a reputation beyond reputerags319 has a reputation beyond reputerags319 has a reputation beyond reputerags319 has a reputation beyond reputerags319 has a reputation beyond reputerags319 has a reputation beyond reputerags319 has a reputation beyond reputerags319 has a reputation beyond reputerags319 has a reputation beyond reputerags319 has a reputation beyond repute
Default Need some advice on cylinder.
Sled is a 2011 800 Pro. Pistons got scored . Almost certain from snow injestion. Here is a pic of cylinder. I can only feel one of those lines with my finger nail barely. Took it to most reputable shop around here that I know off. He said it's not ideal but would work with no ill effects. Measured it and deglaze it for me. What do you guys think. Does it need to be redone.
Click image for larger version
Rate this post: Yes | No
  #2
Old 02-27-2018, 07:42 PM
diamonddave's Avatar
diamonddave diamonddave is online now
Currently: <<In-House PolarisTechnician not as involved in the shop
diamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond reputediamonddave has a reputation beyond repute
Default
Honestly, I am more concerned with how many miles are on it with stock pistons. Why? Because those loose fitting stock pistons have been hammering on those thinner (2011-2012) cylinder skirts for however long.
Check very closely for cracks. Too many stories of replacement pistons followed by cracked skirts. And then 100% of the blame has fallen on the replacement pistons.
The Following User Says Thank You to diamonddave For This Useful Post:
rags319 (02-27-2018)
  #3
Old 02-27-2018, 08:38 PM
Currently: Not set.
Default
I hear you there. Sled had 1300 miles on stock pistons. Put rkt drop-ins in at that time. Now has 1900 miles. Took pics of skirts to magnify them. Don't see any viable cracks anywhere.
  #4
Old 02-27-2018, 10:07 PM
05rmksteve's Avatar
05rmksteve 05rmksteve is online now
Currently: Buying parts
05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute
Default
Put new pistons in it and run it.
  #5
Old 03-08-2018, 03:10 PM
raleigh111 raleigh111 is offline
Currently: Not set.
Basic Member
raleigh111 has a reputation beyond reputeraleigh111 has a reputation beyond reputeraleigh111 has a reputation beyond reputeraleigh111 has a reputation beyond reputeraleigh111 has a reputation beyond reputeraleigh111 has a reputation beyond reputeraleigh111 has a reputation beyond reputeraleigh111 has a reputation beyond reputeraleigh111 has a reputation beyond reputeraleigh111 has a reputation beyond reputeraleigh111 has a reputation beyond repute
Default
Quote:
agree!
  #6
Old 03-10-2018, 03:52 AM
Drewd Drewd is offline
Currently: Work schedule not compatible with sledding
Drewd has a reputation beyond reputeDrewd has a reputation beyond reputeDrewd has a reputation beyond reputeDrewd has a reputation beyond reputeDrewd has a reputation beyond reputeDrewd has a reputation beyond reputeDrewd has a reputation beyond reputeDrewd has a reputation beyond reputeDrewd has a reputation beyond reputeDrewd has a reputation beyond reputeDrewd has a reputation beyond repute
Default
don't deglaze the cylinders. Just clean really well with some brake cleaner and scotch brite plads instead of a honing tool.
The Following User Says Thank You to Drewd For This Useful Post:
rags319 (03-10-2018)
  #7
Old 03-11-2018, 08:34 AM
Default
It's going to be a risk not replacing the monoblock with brand new. But I get it, there now $1,200.
But, please make sure you replace the injectors. 2011's were problematic and have been updated. Injector location lends itself to carbon deposits on the tip's. Which then results in fuel pattern spray issues. Which then leads to issues just like you are seeing right now.
May not have been snow ingestion.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #8
Old 03-12-2018, 12:22 PM
Currently: Not set.
Default
I did have injectors ultra sonic cleaned by indy specialties 4-500 miles ago which was sevel years ago that seem to cure a cutout/stumble issue. They are blue so I was under impression they were updated version. They are ones sled came with new. Maybe there is a more updated one?
0 out of 1 members found this post helpful. Rate this post: Yes | No
  #9
Old 05-18-2018, 08:48 AM
sledtahoe sledtahoe is offline
Currently: waiting for the big dump!
Basic Member
sledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond reputesledtahoe has a reputation beyond repute
Default replace
call indydan and get it done right.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Pro Cylinder Wash Pic Questions...Advice appreciated! Thread Starter — Vincenthdfan Forum — Polaris: Pro-Ride Replies — 4 Last Post — 02-26-2017 12:51 PM
Thread — '07 600 RMK scored cylinder - need advice Thread Starter — mark Forum — Polaris: IQ Replies — 5 Last Post — 03-25-2014 05:14 PM
Thread — 2012 cylinder Vs. 2013 Cylinder 800 Pro Thread Starter — RKT Forum — Polaris: Pro-Ride Replies — 56 Last Post — 10-12-2012 12:47 PM
Thread — 800R meltdown need advice and cylinder Thread Starter — xpsledder Forum — Ski-Doo: XP Sleds Replies — 3 Last Post — 04-25-2012 10:24 AM
Thread — Cylinder down, need advice Thread Starter — goforbroke Forum — Polaris: IQ Replies — 25 Last Post — 12-03-2011 12:37 AM
no new posts
